Old Oct 11, 2012, 08:12 PM
narpat007 is offline
Find More Posts by narpat007
Rana
Gurgaon - India
Joined Jul 2009
Sir Alex,
Will it be corrected or go as it is. You can not say the DIY people have already tested the firmware in HIL so no need of HIL here in MPNG. Since during porting, firmware is changed, which may have new implementation bug, which can be easily found with HIL testing only else the other way is to find the bug in flight, which may result in lots of damage due to crash.
Originally Posted by Sir Alex View Post
Because some parts of HIL code was removed or not implemented in MPNG.
narpat007 is offline Find More Posts by narpat007
Old Oct 11, 2012, 09:10 PM
Mochaboy is offline
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Originally Posted by scotland101 View Post
Frig - I have a AIO the bag from RC-timer - arrived yesterday - sob,
QFT
Mine's one state away in a sorting facility.
Oh well - why buy one when you can buy two at twice the price. Work with what you got I guess.
Mochaboy is offline Find More Posts by Mochaboy
Old Oct 11, 2012, 09:51 PM
npre is offline
Find More Posts by npre
Joined Jan 2011
Originally Posted by narpat007 View Post
Sir Alex,
If you have a need for it then you can add it. It is open source.
npre is offline Find More Posts by npre
Old Oct 12, 2012, 03:31 AM
Sentinal is offline
Find More Posts by Sentinal
Sentinal's Avatar
Joined Oct 2012
Originally Posted by DVE View Post
Due to new prices of cloned APM 2.5 boards (89$) future of Megapirate seems poor to me - its much better to have fully compatible version without software problems.
Have to agree, if the quality is good on these boards the price is not far away from the Crius AIO.
They are not in stock until the 20th Oct.. will place an order for one as soon as available. Will start a new thread on my experiences
Sentinal is offline Find More Posts by Sentinal
Old Oct 12, 2012, 05:41 AM
Sentinal is offline
Sentinal's Avatar
Joined Oct 2012
Has anyone tried the JD-IO board with the Crius AIO ?
http://www.buildyourowndrone.co.uk/J...cq-ioboard.htm
In theory it should work as it MavLink 1.0 compliant and should work connected to TX3/RX3 the same as telemetry and MinimOSD.
Interested in this as it appears that their is code available that translate Mavlink to FrSky telemetry format...this will enable output to the FrSky telemetry receivers.. such as the D8R etc .....this would enable data from the Crius AIO to appear on the LCD Telemetry displays such as the DHT-U or a suitably modified 9x with ER9X and FrSky modules etc..
Thread here for more detail http://diydrones.ning.com/forum/topi...age=5#comments
Appears code is allready available to display the following..:
- Temperature
- Accels X, Y, Z
- Altitude
- Groundspeed
- Lat/Lon
- Running time
The latest software from http://code.google.com/p/arducodes/downloads/list
The JD-IO board can do a lot more though.. such as power LED's etc
Will let you know how I get on.. have ordered one to give it a try.. its only @ 20
Old Oct 12, 2012, 08:25 AM
Guru06 is offline
Find More Posts by Guru06
United States, NC, Raleigh
Joined Mar 2012
I got my Crius yesterday, it's going to be a productive weekend. Funny thing I ordered from HobbyKing's US warehouse the same day and still haven't gotten my package.
Guru06 is offline Find More Posts by Guru06
Old Oct 12, 2012, 05:21 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
sorry for the spam but
I'm selling again some FLASHED HobbyKing F-30As 30amps here in the classified section.. Its on Pre-Order right now, but I ship fast and in the US it takes like 2 or 3 days. They'll be ready for the week of Oct 22.
I participate and follow this thread
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 12, 2012, 05:44 PM
solars is offline
Find More Posts by solars
Dornbirn / Austria
Joined Mar 2008
Does anyone know how to set up EZUHF PPMSUM with megapirate-ng and this board?
I've set TX_CHANNEL_SET TX_set2 but somehow pitch/roll are swapped...
How can I correct that?
solars is offline Find More Posts by solars
Old Oct 12, 2012, 05:55 PM
Multor is offline
Find More Posts by Multor
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
i saw that you PMed me.
All the problems you could possible run in to will all be solved in this thread
I really dont like to realease my own Documented manual on this thread, the environment in here is soo bad, hope you guys can understand.
But for this particular problem
I also had the same problem at the start
On my ER9X, with frsky module i Manually changed every single Channel except 5-8
I dont know how to setup PPMsum for EZUHF
But you only have to connect ppm sum to Throttle pin which is really good cuz its next to gnd and vcc
Multor is offline Find More Posts by Multor
Old Oct 12, 2012, 05:56 PM
npre is offline
Joined Jan 2011
In the config file, uncomment the line that says #define SERIAL_PPM ENABLED
tx_channel_ set will change which order your channels are in. standard is Ail-Ele-Thr-Rud-Mode. set2 is Ele-Ail-Thr-Rud-Mode, which has pitch and roll swapped.
then enable microkopter mode in immersionrc tools on a channel, and plug that channel into the crius board so the signal goes to pin 8.
Old Oct 12, 2012, 06:06 PM
Rana
Gurgaon - India
Joined Jul 2009
Waiting to hear from Sir Alex......
Sir Alex,
Old Oct 12, 2012, 10:19 PM
Tim2 is offline
Find More Posts by Tim2
Tim2's Avatar
Devon, Alberta
Joined Apr 2003
Hey guys,need a little help.
I have a mediatek 3329 GPS and cannot seem to get it to work with the AIO. The GPS has been flashed to run at 115200 baud. I am using MW2.1 and have tried the original version and the one with the GPS patch. The GPS is getting power and the GPS is showing green on WinGUI but there is no GPS info coming through. The GPS works great on the other board I have but is a no go on the AOI. Any Ideas?
Thanks ... Tim
Tim2 is offline Find More Posts by Tim2
Old Oct 13, 2012, 01:26 AM
ferdous7466 is offline
Find More Posts by ferdous7466
ferdous7466's Avatar
Joined Mar 2010
Hi, I was following quad control board's development for long. But was out of touch for last 6 months. I would like to know whether this board is capable of performing the job of autopilot using megapirate NG? What all I need to get it on board a fixed wing ac for FPV flt. I could not make time to read the whole post. Thanks
ferdous7466 is offline Find More Posts by ferdous7466
Old Oct 13, 2012, 01:33 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
HIL does not test hardware part (hardware drivers). All another part of software is same with AC which already tested with HIL DIYd team.
Someone can add support for HIL, but I'm don't understand for what.
Sir Alex is offline Find More Posts by Sir Alex
Old Oct 13, 2012, 07:55 AM
janekx is offline
Find More Posts by janekx
janekx's Avatar
Czech Republic, South Moravian Region, Brno
Joined Aug 2012
Hi,
I got to trouble and want to ask for help.
New RC timer SimonK ESCs I install and because not try Crius with my old Plush not sure the problem was before too.
All ESCs runs well with servo tester,strong and linear, but with Crius or KK2 some ESCs goes to idle .
When I arm all motors with 1/5thorttle goes in same time but after a few seconds 2 motors stops.
Make calibration with multiwii and KK2, but nothing helped.
I make small video
FILE0051 (0 min 53 sec)
What cause it can be please?
EDIT: No metter what order I connect motor still M1 and M4 idles, and I try to power Crius by the USB only with reciever without any motor attached and arm and when I make same 1/5 -1/4 thorttle I see how the motors slow down M1 and M4
EDIT2 My mistake was not trimmed correctly on TX
janekx is offline Find More Posts by janekx
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
