Joined Aug 2008
Just to advise, I ordered from Rtimer air post and although it was shipped the next day only got a tracking number four day's later that worked. I also e-mailed before I ordered because I could not establish if there was actually stock and got a reply with in a day. In the end it arrived in 18 day's at my post office, tracking indicated my postal service had it for 10 day's this was international arrival, customs clearing to eventually my post office. So I'm very pleased and will buy from them again. All packed well with no damage.
I dont know why they were forced to work Even other Shipping companies were open during the holiday I made about 3 Orders during the holiday and shipped the next day which is still a holiday, I think EMS china was available during the time If you picked EMS it will be here this week ![]() Expecting my 3 Axis CNC kit New motors And my new Kobe 7 Shoes
Crius AIO LED status.
Hi all,
I just finished installing the card with the GPS and the anemometer. I loaded the ArduPlaneNG2xR5 sw by JLN and everything seems to work fine, so far so good. Now, i would like to know what the three LEDs (label A B C) means and which state corresponds to each LED. Thanks a lot, Enrico. |
Joined Feb 2011
Hi there,
is there a command I can enter to the terminal emulation in Mission Planer to spin up a single motor? I would like to balance my motors/props while being mounted to the airframe and it would help very much if I could run a single motor (preferably at different speeds) by entering a command at the terminal prompt. Searching for something like: Code:
\\ run_motor -addr 3 -f 200 (run Motor at address 3 with speed 200) Best regards - Thomas |
In MPNG is there any table were I can learn what A1-A4 led outputs do?
Can I also assign CH6 to control camera Trigger in mission planer? If not how is it controlled? Also I used sonar SR04 and DYPME007 connected to D9 and D10 but it doesn't work and doesn't do the clicking sound it does if I use it trough I2C in Multiwii. Sonar is active in MP. Any suggestion? |
some usb doesnt give enough power to the Sonars.Happened to mine. Connect usb then battery
Gurgaon - India
Joined Jul 2009
Sir Alex,
Any of the MPNG Arducopter versions of the firmware is not getting compiled for HIL (Hardware In Loop Simulation). This feature is very important as most of the bugs can be observed during HIL, prior to actual flight test, which saves crashes due to any bug in the firmware. Regards Rana |
Беларусь, Минская область, Минск
Joined Sep 2011
Argentina, BA, Quilmes
Joined Oct 2012
X525 with AIOP and MPNGv2.7r4
Hello, I'm a reader of the forum until now, that I could finish my own quad and luckily it flies!! That's why now i could help others to achive the goal.. I started with a HK FC and the cheap X525 V3 frame, having a lot of problems with the calibration with the HK FC. During the calibration period I read that the AIOP was affordable and I could have the possibility to make my quad more customizable. No doubt, I made the shopping list, and I did have to wait about 5 weeks for the delivery from china to Argentina, and here in the video is the result of the work
http://www.youtube.com/watch?feature...61tKzEp8&gl=US The flight was made in stabilize mode, and then in altitude hold. I have to test other modes of flight AIOP Crius MPNG 2.7R4 with sonar SR04 and Bluetooth to connect with the mission planner. I use the power of the bec from the esc, not need an external power source(with the yellow jumper plugged). Radio: Turnigy 9x with standard firmware. I still waiting the CN06 GPS module from dx.com. By sure, I will return with some questions as soon as i have the GPS module. Next objetive will be mounting of the camera gopro. If you have questions about my config i will be happy to answer. Regards, Ramiro. |
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
Btw about testing... After this crash of AIO I'm afraid to use MPNG more
Maybe in the latest Arducopter versions problem was solved.
Gurgaon - India
Joined Jul 2009
All the versions of the Arducopter & Arduplane firmware compiles well for HIL and I am using that. Same is not there in Arducopter versions of MPNG. Regards Rana |
| Thread Tools | |
| Discussion New updated Crius Multiwii SE flight controller | SGsoar | Multirotor Electronics | 72 | May 15, 2013 08:36 PM |
| Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 | pprioverde | Multirotor Talk | 29 | Nov 21, 2012 09:58 PM |
| Discussion Jim, any plans for more multi rotor flight controller? | chris24g | Xtreme Power Systems | 12 | Jun 25, 2012 08:11 PM |
| Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots | wingspinner | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | May 28, 2012 12:55 AM |
| Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) | SJackson | Multirotor Talk | 27 | Apr 30, 2012 08:51 PM |
