Old Oct 08, 2012, 02:40 PM
pm1 is offline
pm1
Find More Posts by pm1
pm1
Germany, BY, Gestratz
Joined Oct 2008
Originally Posted by x_rui View Post
Does anyone know where to solder new clips for the battery on the GPS bard.. to work again?
The other possibility is to initalize the GPS every time by Multiwii software. I do it this way...
pm1 is offline Find More Posts by pm1
Old Oct 08, 2012, 02:42 PM
x_rui is offline
Find More Posts by x_rui
aka icsss
Joined Feb 2012
baud 57600?
x_rui is offline Find More Posts by x_rui
Old Oct 08, 2012, 03:14 PM
carl1864 is offline
Find More Posts by carl1864
Joined Jan 2010
Originally Posted by carl1864 View Post
I have a question about this Ublox GPS module I got from Rctimer a few months ago.
I'm finally getting ready to install it soon. I know I have to follow some procedure to reflash the baudrate, however I remember reading in the past that it might have some sort of memory issues. That after 2 days it can loose some sort of settings or something.
Can anyone clarify this a little? Is this true? And if so, what settings does it loose? Do I have to go through the reflash procedure every time 2 days pass with no use? Or is it something simpler?
Originally Posted by astro_wanabe View Post
If you're using MPNG then just identify that you're using the UBLOX GPS module in the APM_Config.h file and it's supposed to automatically set up the GPS at power-up (I think this has been supported for a couple versions now). Just change the line that says
#define GPS_PROTOCOL GPS_PROTOCOL_NONE
To:
#define GPS_PROTOCOL GPS_PROTOCOL_UBLOX
Guess I should have clarified. I'm using multiwii. Wondering exactly which settings get lost.
carl1864 is offline Find More Posts by carl1864
Old Oct 08, 2012, 05:31 PM
nomand is offline
Find More Posts by nomand
Joined Aug 2012
I tried connecting my GPS to the GND and VCC of the serial port, and it didn't work, but connecting it to the GND and VCC of the I2C interface powers it up.
Is that a problem?
nomand is offline Find More Posts by nomand
Old Oct 08, 2012, 06:32 PM
dgonano is offline
Find More Posts by dgonano
Joined Sep 2012
Is that a problem?
no its not i dont think
i believe this is happening because your powering the board with the ESC BEC and not a external one through the 'extend power in' port. if you powered it that way the serial power pins would work.
dgonano is offline Find More Posts by dgonano
Old Oct 08, 2012, 09:12 PM
nomand is offline
Joined Aug 2012
I see, thanks, that's how I'm powering it, through ESC's BEC, so I guess I'll have to route power to accessories through the I2C power port.
On the motor pins, should only 1 BEC be plugged into the 3 pins with only signal for the rest, or is it ok to have all of them feed power? Is that going to cause any problems or interference?
Old Oct 08, 2012, 10:10 PM
dgonano is offline
Joined Sep 2012
It can do depending on the electronics, as people have said a rule of thumb is just connect one power from the BEC and you'll be safe.
From electrical knowledge I suspect this could affect that esc because it will be the only one supplying power but I'm not sure if that will actually make a difference or not haha
Old Oct 09, 2012, 03:09 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by icah View Post
That is what I use exactly. The only problem is that my Turnigy 9x is unable to handle the F-MODE switch on channel 5, it can handle channel 6,7,8 only with the stock firmware so I f you intend to use it with this TX, beware.
Try to flash your Tx with er9x FW.http://code.google.com/p/er9x/
er9xuser is offline Find More Posts by er9xuser
Old Oct 09, 2012, 04:36 AM
x_rui is offline
aka icsss
Joined Feb 2012
Is there a way to set the fail safe function in mwii2.1 to work with RTH?
I don't have fail safe on my RX (Turnigy9X) but it stops transmitting on some channels (ie CH3). I know you can define the code to work with AUTOLEVEL and MINTHROTTLE when signal is lost, but can I define the code to activate RTH instead?
Old Oct 09, 2012, 06:36 AM
Afonsos is offline
Find More Posts by Afonsos
Lisboa, Portugal
Joined May 2004
RCT is selling now v1.1 of AIO PRO.Anyone knows what have changed from v1.0?
Besides pinheader are now green
Afonsos is offline Find More Posts by Afonsos
Old Oct 09, 2012, 06:41 AM
janekx is offline
Find More Posts by janekx
janekx's Avatar
Czech Republic, South Moravian Region, Brno
Joined Aug 2012
Nothing new
janekx is offline Find More Posts by janekx
Old Oct 09, 2012, 06:48 AM
er9xuser is offline
Slovenia, Ljubljana
Joined Sep 2011
It was written few pages back what is was changed. Good thing...USB connector is reinforced
Old Oct 09, 2012, 06:54 AM
DVE is offline
DVE
Find More Posts by DVE
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
2 All:
To all Megapirate users: anyone tried long distance mission flights? (more than 500-700m between waypoints)
I had a very strange crash, after 1st point copter go lower and fall dawn without any reason. Battery was charged, all was checked.
It looks like bug in algorithm, I described it on Arducopter forum, and placed log there, but it seems that nobody knows:
http://diydrones.com/forum/topics/st...ght-log-inside
DVE is offline Find More Posts by DVE
janekx is offline
janekx's Avatar
Joined Aug 2012
Reinforced USB was in 1,0 later relases as well so now nothing new
Old Oct 09, 2012, 08:05 AM
mamut is offline
Find More Posts by mamut
mamut's Avatar
Romania,Est Europe
Joined May 2004
Originally Posted by DVE View Post
2 All:
Hi
I got that too with my Crius Quadro, on the second waypoint it wants to land by itself . Delete that waypoint,make another waypoint, reload waypoints and it works.
mamut is offline Find More Posts by mamut
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
