Old Oct 08, 2012, 08:22 AM
Jumpy07 is offline
Find More Posts by Jumpy07
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Originally Posted by TheFernMan View Post
RCTimer has a Radio Telemetry Kit for $45.96
3DR 900Mhz.. no good for Europe.. as same frequency as mobile phones.
Jumpy07 is offline Find More Posts by Jumpy07
Old Oct 08, 2012, 08:28 AM
tvbcom is offline
Find More Posts by tvbcom
Sweden
tvbcom's Avatar
Sweden, Stockholm County, Djurö
Joined Apr 2012
I bought this
http://www.ebay.com/itm/251129230384...84.m1497.l2649
Which is the same but the 433 Mhz version US $43.87 Free shipping.
tvbcom is offline Find More Posts by tvbcom
Old Oct 08, 2012, 08:30 AM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Would the 433Mhz be better even in the US?
RCTimer says its available in both.
Originally Posted by tvbcom View Post
I bought this
How's that one working for you? good?
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 08, 2012, 08:39 AM
tvbcom is offline
Sweden
tvbcom's Avatar
Joined Apr 2012
Don´t know yet, ordered 29 Sept, was shipped 2 Oct, waiting for arrival
Old Oct 08, 2012, 08:44 AM
icah is offline
Find More Posts by icah
Hungary, Pest County, Tököl
Joined Oct 2010
Hi guys, I am trying to set up flight modes with my T9X. The only problem is that I can set the flight modes on channel 5 ONLY, and my TX allows me using my F-MODE switch for channels 6,7 or 8 only. My question is how can I tell the MissionPlanner or the mpng to use other channel than "5" for flight modes? I have tried redefine the TX-channels_set to "ROLL,PITCH,THROTTLE,YAW,AUX1,MODE,CAMPITCH,CAMROL L" but it did not help anything with this issue.
icah is offline Find More Posts by icah
Old Oct 08, 2012, 09:23 AM
tvbcom is offline
Sweden
tvbcom's Avatar
Joined Apr 2012
What I did with my DX8 was to simply swap the channel 6 to 5. The receiver cable from channel 6 I connected to the input for channel 5 on the FC and the receiver cable from channel 5 I connected to the channel 6 input on the FC.
Old Oct 08, 2012, 11:15 AM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
Programming an ArduPilot mode switch for Turnigy 9X transmitter
I followed this guide to setup my 6 flight modes using the 3 position switch and the throttle hold switch combined.
http://rcav.posterous.com/programmin...witch-for-turn
Titus Gordon is offline Find More Posts by Titus Gordon
Old Oct 08, 2012, 11:29 AM
icah is offline
Joined Oct 2010
The problem is that I am using PPM SUM, so 1 cable ONLY between receiver and FC. There is no way I can change channel except somewhere in the software.
The 3-way switch is WORKING WELL, BUT not on channel 5! It is working on channel 6,7 or 8. If anybody knows what to change in the code to get channel 6,7 or 8 acting for mode switching then please let me know.
Old Oct 08, 2012, 11:33 AM
FPV it is!
Canada, SK
Joined Aug 2012
What is this PPM SUM? I keep seeing it referenced but have no idea what it is
Old Oct 08, 2012, 11:38 AM
icah is offline
Joined Oct 2010
It is when you do not need 8 cables to connect 8 channels but just one cable, the receiver and the FC both have to be capable of using this feature. Referenced as CPPM as well.
Old Oct 08, 2012, 11:47 AM
FPV it is!
Canada, SK
Joined Aug 2012
ok, that sounds like it would make for a clean setup with less spaghetti I'll have to start reading about it
Old Oct 08, 2012, 12:56 PM
TheFernMan's Avatar
Joined Jul 2012
usually the FrSky has them. Like this one does 8 channels even though it has four connectors.
RSSI (PWM) and CPPM output - If CH3 and CH4 are connected by a jumper, CH1 will output RSSI (PWM), and CH2 will output CPPM for CH1~CH8
Old Oct 08, 2012, 02:14 PM
icah is offline
Joined Oct 2010
That is what I use exactly. The only problem is that my Turnigy 9x is unable to handle the F-MODE switch on channel 5, it can handle channel 6,7,8 only with the stock firmware so I f you intend to use it with this TX, beware.
Old Oct 08, 2012, 02:28 PM
x_rui is offline
Find More Posts by x_rui
aka icsss
Joined Feb 2012
Which is correct baud for cn-06 v2 on mwii2.1? 57600?
x_rui is offline Find More Posts by x_rui
Old Oct 08, 2012, 02:33 PM
x_rui is offline
aka icsss
Joined Feb 2012
Did anyone broke the clips for the battery on cn-06 v2? Or I'm the first?
I tried to "replace" the battery since I could not set the baud with u-center. The CN-06 v2 was not saving the settings and I thought it was the battery.
Does anyone know where to solder new clips for the battery on the GPS bard.. to work again?
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
