Old Oct 07, 2012, 09:08 AM
Trauma50 is offline
Find More Posts by Trauma50
Joined Sep 2011
Originally Posted by Phroz View Post
Well, tried to test fly mine.. never got of the ground.. on the verge of a flip every time i feed in throttle. As this is my first MultiWii experience are there any guides anyone can point me to regarding setting up a mulltiwii from the ground up that would be applicable to this board also? I know the hardware side (done plenty of KK builds) but know nothing about MultiWii.
P.
Turn on the transmitter. Full throttle. Plug in the battery pack on the copter. Wait. You will hear the ESC's tone's. When the tone's stop. Pull the stick back to the bottom. Go fly. Trauma50
Trauma50 is offline Find More Posts by Trauma50
Old Oct 07, 2012, 09:17 AM
x_rui is offline
Find More Posts by x_rui
aka icsss
Joined Feb 2012
What baud rate does this bluetooth have?
How can I check it?
x_rui is offline Find More Posts by x_rui
Old Oct 07, 2012, 10:59 AM
x_rui is offline
aka icsss
Joined Feb 2012
It's working, it was set on 9600, I've changed it and it works.
Old Oct 07, 2012, 12:22 PM
liorz055 is online now
Find More Posts by liorz055
Joined Aug 2009
For me only manually one by one esc calibration worked , you should try it if the all in one esc calibration won't work.
liorz055 is online now Find More Posts by liorz055
Old Oct 07, 2012, 12:34 PM
Phroz is offline
Find More Posts by Phroz
Joined Dec 2009
Trauma50, does this need to be done as well as the ESC calibration via the code in Arduino? FYI i'm running HK F-30A with SimonK firmware.
P.
Phroz is offline Find More Posts by Phroz
Old Oct 07, 2012, 01:30 PM
dgonano is offline
Find More Posts by dgonano
Joined Sep 2012
alright so, with all the stuff ive read this is the wiring diagram ive come up with, i know its sketchy but its gets the job done :P
is there any mistakes? comments?
finally, can i connect all 4 5v esc lines or not if I've removed the jumper? i know its been talked about but its confusing with so much random bits out there and id rather just confirm it and not blow up my board or ESCs haha
dgonano is offline Find More Posts by dgonano
Old Oct 07, 2012, 01:55 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
It seems ok. Once you remove the jumper, you isolate the ESCs 5v from the rest of the board.
But Just remove the 5v from the ESCs if you're worried. You can lift the little tab on the servo cable of each ESC and pull the 5v cable out and black tape it or use heat shrink to cover the tip.
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 07, 2012, 02:01 PM
dgonano is offline
Joined Sep 2012
awesome hmm might just pull them out and heat shrink them to be safe haha and take the jumper off to :P
if i were to put a HK 2.1 FC board in place of the CRIUS, would i connect 1 or 4 ESC 5V lines? i.e will connecting all 4 to the one point damage the F30 ESCs?? (just asking to help me understand it all :P)
sry for being a noob i'll get it all soon
Old Oct 07, 2012, 02:20 PM
TheFernMan's Avatar
Joined Jul 2012
It's bad when your ESCs have switching becs and you connect them to the FC.
The HobbyKing f-30a have linear becs. So it should be ok. I have a kk2 board with all ESCs connected. But the kk2 m1 connector is isolated from the other esc connections on the board.
Those new Multistar ESCs have switching becs and that wasn't good.
A rule of thumb I've seen here in RCG is remove the 5v bec lines except one. That one will power your board and receiver.
Old Oct 07, 2012, 02:23 PM
dgonano is offline
Joined Sep 2012
Sounds good to me
Old Oct 07, 2012, 03:50 PM
jraulj is offline
Find More Posts by jraulj
Joined Jul 2012
Jumpy07
[QUOTE=Jumpy07;22927755]Default Baudrate on FTDi/S0 is 115,200 and the Default Baudrate on Tx3/Rx3 is 57,600 so make sure you change the baudrate of the 3DR's to match.
I dont know what i did wrong but my radio now does not connect, start and got stuck on the firsparameters (getting param sysid 1-compid 1) than said than fail to connect. tried on tx3/rx3 and on FTDI.
I switch wires you know from this tx-rx//rx-tx ...to this tx-tx/rx-rx but than tried to connect 29 seconds and than times out
on FTDI tried 115200 On RX-TX3 57600 but no luck.
Question. on FTDI I connect tx-rx and got 5v and ground fron the other port thats all that I need to connect ?
Thank you
jraulj is offline Find More Posts by jraulj
Old Oct 07, 2012, 03:53 PM
mast3rwurm is offline
Find More Posts by mast3rwurm
Joined Dec 2010
Does someone know how to calibrate the compass?
i got and error it says if i try it"Log does not contain enough data"
I turned my quad all directions..
mast3rwurm is offline Find More Posts by mast3rwurm
Old Oct 07, 2012, 04:03 PM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
hover for awhile and then calibrate it
Titus Gordon is offline Find More Posts by Titus Gordon
Old Oct 07, 2012, 04:07 PM
Joined Dec 2010
Only by hovering?
FPV it is!
Canada, SK
Joined Aug 2012
yeah it just needs some data
then do a calibration
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
