Old Oct 06, 2012, 09:42 PM
dgonano is offline
Find More Posts by dgonano
Joined Sep 2012
Originally Posted by dutchcommando View Post
no lipo!set as NIxx (NIMH NICD etc)
granted the lipo setting saves a lipo from deep discharging...
but it saves the lipo by cutting all power to the motor. and a multi without power to the motors is brick... and bricks don't fly.
to prevent the transformation from multi to brick. (and crashing down and destroying your multi) we all set cutoff to NIxx.
lipo cutoff happens at 3.3 volts per cell. NIxx at 0.9 volts per cell. so if the esc is told it is connected to NIxx batteries it will cut off all power under 1 volt. so your multi will kill your lipo but it won't crash.
i hope it's understandable now why we DON'T WANT TO SET THE ESC TO LIPO.
A very entertaining post! especially the bricks dont fly part :P but yes i get it now so thankyou!!
i plan to get the card to make the programming easy and once i start to get the hang of it all (im brand new to quads) i'll flash them
Originally Posted by TheFernMan View Post
You use the programming card to set the options for the ESC faster.
But If you flash them when you get it, no. The SimonK firmware is optimized for Multirotors. So you don't have to program those options.
ahk so i may as well get it haha
when i eventually flash them, simonK has to be calibrated still yeah?
As these have built in UBEC do i need an external BEC from HK (like a 3A one) to go into the 'extend power in' port or can i power the board, gps, OSD, receiver all from the ESC BECs??? (and leave the jumper on)
EDIT: PS, you guys on this forum are amazing at helping me get started :P who knows what id do without you
dgonano is offline Find More Posts by dgonano
Old Oct 06, 2012, 10:45 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
if you have simonized (flashed) esc's you have to calibrate them once for multicopter use.
those HK30A esc's have bec's yes. almost all esc's have bec's. if they don;t have bec's they are designated as opto. DJI is almost the only one who uses and supplies opto's with their kits.
you have heard about the use of only one bec from four esc's?
and you are welcome.. helping and getting help is what this forum is all about.
eventually you will help other people with their problems and questions.. isn't the world of the internet sometimes great?!
dutchcommando is offline Find More Posts by dutchcommando
Old Oct 06, 2012, 11:02 PM
dgonano is offline
Joined Sep 2012
[/I][/B].
Should I use built in BECs or external one?
And Yeah I have. I know I have to connect all 4 signal and grounds from the ESC but do I connect 0,1 or 4 5v lines from the ESCs ?
And the jumper on or off ? Haha
For best performance I'm thinking:
Use 3A external BEC connected to external power in port
Jumper removed
Not sure how many esc 5v lines to connect.....
Old Oct 06, 2012, 11:13 PM
narpat007 is offline
Find More Posts by narpat007
Rana
Gurgaon - India
Joined Jul 2009
hil?
HIL (Hardware in Loop Simulation) mode is used to test the firmware on simulator environment where the code is actually executed by the processor of your autopilot board and the IMU data is provided by external Simulator software like AeroSIM-RC, via plugin working in the backend. Just have a look at the following videos;
Arduplane_2.65 Flight test on Predator in Aero-SIM-RC, Auto take off, manual landing (6 min 7 sec)
ArduPlane 2.65 looses altitude drastically, soon after it turns to waypoint after an auto take off (6 min 36 sec)
With HIL bugs can be easily found without actually crashing your plane.
narpat007 is offline Find More Posts by narpat007
Old Oct 07, 2012, 12:03 AM
newmanhyde is offline
Find More Posts by newmanhyde
Singapore, Singapore
Joined May 2012
i hope you guys can help me ,as i am trying to load megapirate. some how i am using apm planner to upload arducopter 2.7 on the board . now when i arm the board the motor wont spin.
have i done the wrong steps?
newmanhyde is offline Find More Posts by newmanhyde
Old Oct 07, 2012, 12:30 AM
Rana
Gurgaon - India
Joined Jul 2009
Though APM board and your board have the same processor ATMEGA2560 but have different pin connection details. For example APM2 has IMU sensor MPU6000 which communicates via SPI / I2C whereas for example CRIUS ALL IN ONE PRO v1.0 has MPU6065 which can only communicate via I2C.
Since Arduino bootloader residing in ATMEGA2560, won't stop you to load firmware via APM Mission planner but that firmware will not work for you due to reason I explained above.
You can flash the new firmware (MegapiratesNG) via Arduino IDE. However there is technique to load custom firmware via mission planner also.
Old Oct 07, 2012, 01:44 AM
Phroz is offline
Find More Posts by Phroz
Joined Dec 2009
Hey Guys,
If your running 3cell can you power the board directly from your main flight pack via the "Extend power" in put or is it better to leave the BEC wire connected on the ESC connected to D2 and cut the BEC (red) wire on the other ESCs?
P.
Phroz is offline Find More Posts by Phroz
Old Oct 07, 2012, 01:52 AM
Rana
Gurgaon - India
Joined Jul 2009
Originally Posted by Phroz View Post
Hey Guys,
P.
Fully charged 3S Lipo goes upto 4.2v / cell resulting in 12.6V total, will exceed the limit of the board which is 5V to 12V, may result in overheating / damage to the on-board regulator.
Old Oct 07, 2012, 02:41 AM
Joined May 2012
the strange thing is now even i load pirate or multiwii code both show armed in gui but the motor just dont spin.
oh pls tell me i have not kill my board.
Old Oct 07, 2012, 02:51 AM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
The serial ports do not work with just the ESCs powering the board. You need the extended power in and remove the jumper. It's been talked about here a lot
I asked the same question about using a ESC's bec to the extended power in. It should work but I don't know if anyone answered. you could add pins as I've seen I think nebstress do and connect the ESCs bec there.
Once you remove the jumper, the ESCs are isolated from the rest of the board.
I posted a link to another post somewhere earlier in the thread. Read a few pages back. Theres a lot of good info here and even some drama from some members here lol
Did nebstress leave this thread really? Neb? Quad?
We should really break this thread into two. One from Crius AIO MultiWii and anther one for Crius AIO MPNG.
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 07, 2012, 03:34 AM
Rana
Gurgaon - India
Joined Jul 2009
Erase the E2PROM, via following procedure and then reset the board, by power cycle and then upload appropriate parameter file. DO PROPER RADIO CALIBRATION AS WELL.
Using MP, go to terminal then Setup and then type Erase command, it will ask to type Y for confirmation.
You also need to check the PWM values actually present on individual channels like Rol, Pitch, Throtle, Yaw and Mod.
If this does not work for you then there might be h/w issue, which I do not expect.
Old Oct 07, 2012, 05:07 AM
Phroz is offline
Joined Dec 2009
Well, tried to test fly mine.. never got of the ground.. on the verge of a flip every time i feed in throttle. As this is my first MultiWii experience are there any guides anyone can point me to regarding setting up a mulltiwii from the ground up that would be applicable to this board also? I know the hardware side (done plenty of KK builds) but know nothing about MultiWii.
P.
Old Oct 07, 2012, 06:15 AM
Joined May 2012
thanks narpat but i have erase the eprom still the motors wont run. how do i check the pwm values .are you saying i should calibrate the esc throttle range?
Old Oct 07, 2012, 08:19 AM
Rana
Gurgaon - India
Joined Jul 2009
By radio calibration, I mean, when Arducopter code ( MegaPirateNG_2.7_R4.zip ), is flashed into your bard, you connect your Autopilot board to the APM Mission planner, via USB.
It is assumed that you have connected the receiver with the Autopilot board properly and turn on your Radio Transmitter.
Then from Mission Planner, click on the configuration tab and from there you will find a clickable list in the left from there you click on Calibrate Radio.
After that it will be self explanatory.
Old Oct 07, 2012, 08:28 AM
Rana
Gurgaon - India
Joined Jul 2009
MultiWii has lots of variants, product link / photo is required. There is good start up guide for MultiWii (CRIUS ALL IN ONE PRO V1.0).
P.
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
