Old Oct 06, 2012, 04:52 PM
NEAGRON is offline
Find More Posts by NEAGRON
United Kingdom, Scotland, Aberdeen
Joined Mar 2010
Great to see your still here Jump07,your's Marty,your a star
NEAGRON is offline Find More Posts by NEAGRON
Old Oct 06, 2012, 07:36 PM
dgonano is offline
Find More Posts by dgonano
Joined Sep 2012
hey guys, are these ESC's okay to use with this board?
http://www.rctimer.com/index.php?gOo...9&productname=
i though they were but have just read some stuff saying their bad
is it better to use the blue series or F30s from HK instead? can i run these with stock firmware to start with? and then flash them with simonK later? i dont think i can flash them haha i don't understand the process/connections haha
dgonano is offline Find More Posts by dgonano
Old Oct 06, 2012, 07:47 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
oh yea! you should go with the F-30A ESCs from HobbyKing.
BlueSeries have very similar hardware but programming pad are not in a row.
But those ESCs preflashed with SimonK from RCTimer are ok too. Its just that the F-30A have better hardware. (All N-Fet)
i was trying to find a post of someone that has some rctimer ones and he said he has no problems with them
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 06, 2012, 07:50 PM
Boykintom is offline
Find More Posts by Boykintom
United States, SC, Ridge Spring
Joined May 2012
I can attest that the F-30A's are doing fine. Flashed them for my quad and they are very smooth.
Boykintom is offline Find More Posts by Boykintom
Old Oct 06, 2012, 07:51 PM
dgonano is offline
Joined Sep 2012
okay so these ones to confirm?
http://www.hobbyking.com/hobbyking/s...dProduct=15205
i can run them with stock firmware to start with yeah? and flash them when i know a bit more :P
Old Oct 06, 2012, 07:55 PM
TheFernMan's Avatar
Joined Jul 2012
yes! get them. everything will be fine. order a spare. order bullet connectors if you need them and some wires like 16 gauge.. if you need them
When you get them, think about flashing them. its really easier than you think.
Look at this video
Flashing SimonK Firmware on a 20 amp HK esc (12 min 30 sec)
Old Oct 06, 2012, 08:02 PM
TheFernMan's Avatar
Joined Jul 2012
Get the atmel programmer too. You need it at some point.
Old Oct 06, 2012, 08:04 PM
dgonano is offline
Joined Sep 2012
Yes thats in my list of stuff to order
compuatic is online now
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Guys what frequency setting are you using for thr ESCs?
compuatic is online now Find More Posts by compuatic
Old Oct 06, 2012, 08:06 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
yes, they are ok stock..
just program to the correct settings:
batt type: NIxx
brake: off
protection mode: low
timing: auto
startup :normal
Look at this video
www.youtube.com/watch?v=NZsT0agRZMY
also add with the above list the atmega socket firmware flashing tool.
i makes programming your esc's easier than a walk in in the park and you can flash 80% of the esc's used for multicopters easy.
i have one and i did 9 esc's (octocopter + one spare esc) within three minutes!
works like a charm.. well worth the money!
dutchcommando is offline Find More Posts by dutchcommando
Old Oct 06, 2012, 08:26 PM
dgonano is offline
Joined Sep 2012
batt type: NIxx
brake: off
timing: auto
startup :normal
wait.... battery set to Nimh or LiPo? i thought LiPo would be the one?
Do i need to buy that programming card then?
Old Oct 06, 2012, 09:15 PM
narpat007 is offline
Find More Posts by narpat007
Rana
Gurgaon - India
Joined Jul 2009
Why any of the Arducopter compatible versions of MPNG does not compile for HIL ?
narpat007 is offline Find More Posts by narpat007
Old Oct 06, 2012, 09:31 PM
TheFernMan's Avatar
Joined Jul 2012
Yes and no lol
ESCs CAN be programmed with the remote but it's a PITA (pain in the )
You used the programming card to set the options for the ESC faster.
But If you flash them when you get it, no. The SimonK firmware is optimized for Multirotors. So you don't have to program those options.
TheFernMan's Avatar
Joined Jul 2012
Originally Posted by narpat007 View Post
why any of the arducopter compatible versions of mpng does not compile for hil ?
hil?
Old Oct 06, 2012, 09:36 PM
Joined Feb 2012
no lipo!set as NIxx (NIMH NICD etc)
granted the lipo setting saves a lipo from deep discharging...
but it saves the lipo by cutting all power to the motor. and a multi without power to the motors is brick... and bricks don't fly.
to prevent the transformation from multi to brick. (and crashing down and destroying your multi) we all set cutoff to NIxx.
lipo cutoff happens at 3.3 volts per cell. NIxx at 0.9 volts per cell. so if the esc is told it is connected to NIxx batteries it will cut off all power under 1 volt. so your multi will kill your lipo but it won't crash.
i hope it's understandable now why we DON'T WANT TO SET THE ESC TO LIPO.
a programming card is handy if you have non flashed esc's, once flashed you don't need the card anymore.
you will use the card only once per esc. you program the right settigns (NIxx!) and you are done with it.
the programming card saves you a lot of hassle. without the card you have to use your transmitter and ears.. the esc beeps a certain set of beeps and you have to react with the throttle stick... programming one esc this way is a pain.. now with a quad you have to do it 4 times...
buying a card (the correct one!) is worth the money.
but it's even better to buy the socket programmer (and a usbapp programmer if you not already own one) and flash your esc's to simonK firmware..
the simonK firmware makes the esc's respond much faster, resulting in a smoother and more stable flight. also the esc's will have no cut off and no need for programming any more. the firmware is specially made for multicopters.
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
