Old Oct 05, 2012, 04:22 PM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
I just put a set of 1200 kv 28-26 NTM's, running 3s on a HT-FPV frame with 9" props atm, haven't tested it out yet
Titus Gordon is offline Find More Posts by Titus Gordon
Old Oct 05, 2012, 04:30 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
compuatic what do you mean by wondering around? Stabilise mode won't keep it in one spot. If it's drastically veering off have you tried automatic trim? Although i've found using a spirit level on the tip of my motor spinners and getting it as level as possible works best. And calibrating level in mission planner
NDw is offline Find More Posts by NDw
Old Oct 05, 2012, 04:56 PM
compuatic is offline
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
it doesnt veer into a specific direction. I've used the auto trim ch7 thing to clean that up as much as possible. If i let go of the sticks it will start to drift to the left, then to the right, then forth, then back, etc. Then again, my testing has been indoors in my living room which may be magnifying the issue.
How critical is setting the CG right below the board? My CG is probably about 1cm away from the center of the board.
compuatic is offline Find More Posts by compuatic
Old Oct 05, 2012, 05:16 PM
FPV it is!
Canada, SK
Joined Aug 2012
Originally Posted by compuatic View Post
can someone please post a snapshot or advice on where to find the default PIDs in megapirateNG? I have been playing around in mine and didn't write down the defaults...
if you still need these I can post the defaults when I get home from work in a couple hours, I reflashed mine last night
Old Oct 05, 2012, 05:24 PM
NDw is offline
NDw
NDw
Joined Aug 2010
yeah your cg shouldn't be an issue. Tbh if it flies in the confineds of a living room I'd be fairly happy I don't think you'll ever get it to sit perfectly in one spot.
Old Oct 05, 2012, 05:28 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Yes please
I'll take a video later and you guys can let me know what you think.
Old Oct 05, 2012, 06:05 PM
bc2801 is offline
Find More Posts by bc2801
Joined Oct 2012
here is my problem guys i can not figure it out.
20121005 174526 (0 min 38 sec)
bc2801 is offline Find More Posts by bc2801
Old Oct 05, 2012, 06:10 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
BC2801 i would check the following:
1. motor directions on all 4 motors
2. if you're using the right props, C vs W
3. increase P on the yaw rate (actually looks like its pretty high already!)
Old Oct 05, 2012, 06:28 PM
Soupbones is offline
Find More Posts by Soupbones
Soupbones's Avatar
Australia
Joined May 2011
Motors are going the correct way in the video, so your all good there. Check props are on the right way.
Actually decrease the yaw P setting. I just had issues and found this was it, the default yaw is to high.
Also double check your trim settings in your TX for the yaw as well.
Soupbones is offline Find More Posts by Soupbones
Old Oct 05, 2012, 06:46 PM
TheKnightFerrin is offline
Find More Posts by TheKnightFerrin
TheKnightFerrin's Avatar
Oregon
Joined Jan 2011
Originally Posted by bc2801 View Post
here is my problem guys i can not figure it out.https://www.youtube.com/watch?v=bKyVwqtfUuk
Is your gyro reversed/can you reverse it?
Meaning is the controller correcting yaw output in the wrong direction.
TheKnightFerrin is offline Find More Posts by TheKnightFerrin
Old Oct 05, 2012, 07:11 PM
HansAuf is offline
Find More Posts by HansAuf
Pass me some zip-ties!
HansAuf's Avatar
United States, FL, Gainesville
Joined Nov 2006
bcs801, Check the #define GYRO_ORIENTATION in config.h section. Does it look like the following?
#define GYRO_ORIENTATION(X, Y, Z) {gyroADC[ROLL] = Y; gyroADC[PITCH] = -X; gyroADC[YAW] = -Z;}
HansAuf is offline Find More Posts by HansAuf
Old Oct 05, 2012, 07:15 PM
FPV it is!
Canada, SK
Joined Aug 2012
Default PID values for MPNG
@ compuatic, here are the default PID after a fresh flash of MPNG
Old Oct 05, 2012, 08:29 PM
Mochaboy is offline
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Very helpful Titus - thanks again.
I'm a sad panda - all my packages are arriving tomorrow...which is all well and good except I won't be here, and with Columbus day on Monday that means - no play time till next Tuesday.
At least I had a chance to fix up the Bixler and swap out the motors though...these NTM 2826's are f'n nice!
Mochaboy is offline Find More Posts by Mochaboy
Old Oct 05, 2012, 09:50 PM
Phroz is offline
Find More Posts by Phroz
Joined Dec 2009
Hey guys, which would be the best GPS for this board? the MTK3329 or a CN06?
Thanks!
P.
Phroz is offline Find More Posts by Phroz
Old Oct 05, 2012, 09:57 PM
jraulj is offline
Find More Posts by jraulj
Joined Jul 2012
jumpy07 have a question
my 3d radio connects over TX3-Rx3 fine, . but when i connect GPS on TX2-RX2 does not detec gps..on mission planner.. GPS works fine by it self. I tried 3D radio over FTDI but does not connect. Im using megapirates. AIOpro board
my GPS is CN06
jraulj is offline Find More Posts by jraulj
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
