Old Oct 05, 2012, 12:45 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
Originally Posted by liorz055 View Post
As opposed to Fpv airplane in quad the video tx and the remote control receiver are very close to each other and the range reduced dramatically . The same setup (frsky and 1.2 mhz fox 800 ) that I used and got 1km with my Bixler in my 450 quad the ranged reduced to 50m!!!
Now I am moving to UHF system (dragon link ) in order to enjoy Fpv with my quad .
Get one of these for your 1.3 vtx and you will get at least a few 100 meters of range.
The harmonics from the 1.3 vtx kill the range of 2.4ghz control if you don't use a filter.
NDw is offline Find More Posts by NDw
Old Oct 05, 2012, 01:23 PM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
I got my new 3DR radio system installed and I have to say it's great making adjustments live without having to plug the quad into the computer with a usb cable. Makes tuning alot faster and less hassle.
Now if I could only figure out why my quad's yaw drifts...
Titus Gordon is offline Find More Posts by Titus Gordon
Old Oct 05, 2012, 01:39 PM
NEAGRON is online now
Find More Posts by NEAGRON
United Kingdom, Scotland, Aberdeen
Joined Mar 2010
How childish can people get,someone tries to help the community by putting information in one place and gets BANNED,surely the idea of the forum is to help one another,this is rubbish,and the mods should sort it out,just my thought's,Marty.
NEAGRON is online now Find More Posts by NEAGRON
Old Oct 05, 2012, 02:15 PM
liorz055 is offline
Find More Posts by liorz055
Joined Aug 2009
I am using 1.3mhz low-pass filter :
http://www.readymaderc.com/store/ind...roducts_id=484
Without it the range on my bixler decrease to 300 meter. If you want to enjoy Fpv in Israel you must switch into UHF .
liorz055 is offline Find More Posts by liorz055
Old Oct 05, 2012, 02:56 PM
icah is offline
Find More Posts by icah
Hungary, Pest County, Tököl
Joined Oct 2010
Originally Posted by Jumpy07 View Post
I used the throttle input pin input to get it working ..A8 , yes un-comment that line.
That worked, thanks! Just had to set the TX to standard to have the main channels in a correct way for my mode 2 transmitter.
icah is offline Find More Posts by icah
Old Oct 05, 2012, 03:03 PM
npre is offline
Find More Posts by npre
Joined Jan 2011
If it drifts slowly over a minute or so there is not a lot you can do other than enabling the onboard compass, gyros always drift a little like that. I term will help for drift that occurs within seconds.
npre is offline Find More Posts by npre
Old Oct 05, 2012, 03:32 PM
compuatic is offline
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Originally Posted by compuatic View Post
can someone please post a snapshot or advice on where to find the default PIDs in megapirateNG? I have been playing around in mine and didn't write down the defaults...
Please?
compuatic is offline Find More Posts by compuatic
Old Oct 05, 2012, 03:33 PM
NDw is offline
NDw
NDw
Joined Aug 2010
Some fpv in the garden on a windless day (ground recording).
Addictive.
Crius AIOP Megapirateng Fpv (5 min 59 sec)
Old Oct 05, 2012, 03:51 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
NDW and Titus, can you guys post your latest PIDs please?
Old Oct 05, 2012, 03:57 PM
NDw is offline
NDw
NDw
Joined Aug 2010
These are my latest although I havn't been playing with loiter ect recently
Old Oct 05, 2012, 04:06 PM
FPV it is!
Canada, SK
Joined Aug 2012
which I term are you refering too? rate, stabilize or stabilize yaw or rate yaw?
My compass is enabled because I have a GPS onboard, but the GPS seems to have stopped working (it worked one time and since I can't get a GPS lock)...
Old Oct 05, 2012, 04:09 PM
FPV it is!
Canada, SK
Joined Aug 2012
I just put some new motors and gear on my quad last night and reflashed it, so I have to start tuning all over, so I have nothing useful to post atm. But I'll post them when I have something worthwhile.
Old Oct 05, 2012, 04:13 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
NDW, what motor kv / props are you using?
Old Oct 05, 2012, 04:16 PM
NDw is offline
NDw
NDw
Joined Aug 2010
1200 kv and 8 x 4.5 props on 3 cell. And on a 450 frame.
Old Oct 05, 2012, 04:21 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Thanks! I'm using 980kvs, 8x4.5 on a 4S. Spider frame. should be close.
I spent an hour dialing in the parameters yesterday. No oscillations at this point but i feel that stabilization should be better. The quad isn't unstable by any means but i am constantly correcting to keep it from wandering around. I'm not sure what to play with to keep it more steady. Altitude is constantly changing as well, its either drifting up slowly or down slowly (not using altitude hold).
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
