Old Oct 04, 2012, 02:06 PM
scribble007 is offline
Find More Posts by scribble007
United States, CA, Yosemite Lakes
What da.
2 of the most helpful people unsubscribed....Did I miss something?
scribble007 is offline Find More Posts by scribble007
Old Oct 04, 2012, 02:57 PM
Jumpy07 is offline
Find More Posts by Jumpy07
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Originally Posted by Guru06 View Post
Jumpy any particular reason you are using the breakout board, did you previously use XBee? I'm just weighing the pros and cons of breakout board. Thanks.
No reason, just didnt want to cut link cable.. bit overboard .. you could probably just use header pins
Jumpy07 is offline Find More Posts by Jumpy07
Old Oct 04, 2012, 03:05 PM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Ok.. have done a bit more work to the new guide.. have created a PDF, its a first draft and probably has some errors...
Would apreciate if someone could proof it..
Its quite large so give it time to download.
Use it at your own risk.. goes without saying..
http://www.rcgroups.com/forums/showa...1&d=1349383822
Old Oct 04, 2012, 03:08 PM
dgonano is offline
Find More Posts by dgonano
Joined Sep 2012
WOW i like that guide!!! im new and trying to figure it all out still and its really helpful!
dgonano is offline Find More Posts by dgonano
Old Oct 04, 2012, 03:17 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
:/ nebstress left? We're screwed lol
We really need better organized Multirotor forum. Multikopter has a great structure.
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 04, 2012, 03:25 PM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Agree, one of the problems I had as a noob, was wading through this thread.. Multikopter has a much better structure
Hopefully the updated guide I have created will save someone the loss of hours of their life lol
Old Oct 04, 2012, 03:26 PM
dgonano is offline
Joined Sep 2012
wait so can minimOSD be used with CRIUS without modification or another piece of hardware or not? i dont understand what it said there, i just want to be able to have an OSD feed in the future.
also, can the OSD display be configured in the planner still?
Old Oct 04, 2012, 03:27 PM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Thanks, let , me know how you get one with it.. bound to be a few errors btw ..
Tried to cover off all of the questions that keep getting asked. would welcome feedback
Old Oct 04, 2012, 03:32 PM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Sorry not sure of the question.. so will try and answer what I think you are asking
Yes MinimOSD can work without other hardware with the Crius with MegapirateNG. However MinimOSD is just an OSD, you will still need a video tx and rx and something to view the video feed on.
The planner shows information from the Crius AIO either via USB or 3DR Radios or Bluetooth.
OSD information will appear in the video feed, which I think you can show in a window in the planner.. but havent tried that.
MinimOSD has its own configuration program http://code.google.com/p/arducam-osd/download
s/detail?name=OSD_Config.zip&can=2&q=
Hope that makes sense..
Old Oct 04, 2012, 03:35 PM
Guru06 is offline
Find More Posts by Guru06
United States, NC, Raleigh
Joined Mar 2012
Jumpy great guide, I'm ordering mine today and I can't wait to put this guide to use. Thank you.
Guru06 is offline Find More Posts by Guru06
Old Oct 04, 2012, 03:46 PM
TheFernMan's Avatar
Joined Jul 2012
Can't download PDF. Bandwidth exceeded.
Old Oct 04, 2012, 03:48 PM
dgonano is offline
Joined Sep 2012
hmm yes that makes sense i think. i understand i need a video feed (will gopro work or is that too high res?) and a tx/rx and monitor but what is the PWM RSSI (and minumosd-extra) stuff then? thats the bit that confused me :P
Old Oct 04, 2012, 03:51 PM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Geeze.. had 50meg bandwidth.. ok will find somewhere else to host it.. give me a few mins
npre is offline
Find More Posts by npre
Joined Jan 2011
Attached, I downloaded it before the bandwidth cap.
It's very good
No login is required to download attachments here.
edit, deleted as it is an old version.
npre is offline Find More Posts by npre
compuatic is online now
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
someone needs to host jumpy's guide and post it.
compuatic is online now Find More Posts by compuatic
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
