Old Sep 27, 2012, 01:55 AM
neo__04 is offline
Find More Posts by neo__04
Australia, VIC, Warrnambool
Joined Feb 2012
Just about to order the AIO pro.
Can someone post me a link of what board they ordered, and also what gps & bluetooth?
Just want to make sure what I order is all compatible.
Thanks!
neo__04 is offline Find More Posts by neo__04
Old Sep 27, 2012, 01:58 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
Originally Posted by Multor View Post
hi there, guys,
i managed to connect my sonar.
i just need to know if it works?
how can i do that? is there a status on gui or something?
Just go to CLI and use 'sonar' command in 'test' submenu.
Sir Alex is offline Find More Posts by Sir Alex
Old Sep 27, 2012, 03:05 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Thanks!
CRIUS AIOP
GPS [Extend Board]
'OR'
GPS
Bluetooth
nebstress is offline Find More Posts by nebstress
Old Sep 27, 2012, 03:13 AM
Multor is offline
Find More Posts by Multor
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
idont know what this means
both of my sonar now works on rabbit, it holds fine.
in megapirate aiop, do i just plug it in and eneable alt hold then it will automatically just reads it from the sonar?
Multor is offline Find More Posts by Multor
Old Sep 27, 2012, 03:14 AM
Goofy68 is offline
Find More Posts by Goofy68
Sweden
Joined Sep 2010
Hi
I have just started playing with my Crius aio pro card. Managed to get Multiwii 2.1 installed and running. BT adapter from rctimer works without any problems.
Now, my problem is gps. Ive got Multiwii MWC FC CN-06 GPS Receiver V2.0 from rctimer and I have read that I need to chande baud rate to 115200. Could someone please tell me or post a link to information on how this is done?
I know Im supposed to use u-center but how do I connect my gps to my computer?
Can I make some sort of adapter myself or do I need to buy one?
Goofy68 is offline Find More Posts by Goofy68
Old Sep 27, 2012, 03:28 AM
helidex is offline
Find More Posts by helidex
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
Originally Posted by karmonkey View Post
hello
I just received my AIO with a gps and bluetooth from rctimer and im reading the all thread but i cant understand how to get started.
Ive downloaded the multiwwiconf 2.1 but now dont know how to do.
Can anyone tell me how to step up in that project?
Thanks in advance!!
Start with arduino and read the how to etc here
Also a another useful arduino tutorial
Then have a look at this
And take note - when you read this thread - Multiwii and Megapirate are discussed side by side but they are quite different to configure. Good luck with your project.
helidex is offline Find More Posts by helidex
Old Sep 27, 2012, 03:48 AM
didgydont is offline
Find More Posts by didgydont
Australia, VIC, Bannockburn
Joined Aug 2012
Originally Posted by nebstress View Post
Did you check that the COM port that you are using is also set to the same speed.
I use the APC220's but I haven't tried connecting to the serial port, I connect mine to the FTDI port.
I see this user has connected the APC220 to the FTDI port. My bluetooth work in this port but not my APC220. Does anyone have any pointers ?
didgydont is offline Find More Posts by didgydont
Old Sep 27, 2012, 04:29 AM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
Originally Posted by scribble007 View Post
Can You show me how you have your FC mounted?
It's just mounted with the arrow pointing in the direction of flight.
If you mean on the rctimer frame it's just in a foam box that a kk board came in velcroed on the bottom plate.
NDw is offline Find More Posts by NDw
Old Sep 27, 2012, 04:31 AM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
Originally Posted by didgydont View Post
Hi all
Trying to get APC220 to work. I have configured them to same frequency and followed guide but the s0~s03 port on my board snapped off during crash. I soldered directly to board and gps is working. i have a bluetooth module working in ftdi port is there a way to test the APC220 link or a way to use it on my FTDI port ? using megapirateng 2.7 R4
i would like to know the same..
my apc's do not talk..
in the mission planner there's a tab called "TERMINAL" open this tab and you are in the CLI command center.
the sonar works just like the rabbit. low alt for sonar higher alt for baro and slight overlap when passing both altitudes.
i would like to know that to
dutchcommando is offline Find More Posts by dutchcommando
Old Sep 27, 2012, 04:41 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
didgydont has just drawn my attention to this, sorry I was actually using 3DR's not APC's.
I think that the highest Baud that APC's can be set to is 57600bps the FTDI's Baud is 115200bps.
Old Sep 27, 2012, 05:14 AM
Multor is offline
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
thanks, it works, aparently the redsonar is better, the blue sonar is limited to reading only 205cm and the DYP-ME007v2 is about 270cm
btw, sir alex, is it possible to use RXTX1 for minim osd instead of the mav port?
Old Sep 27, 2012, 05:44 AM
Joined Aug 2012
Let us know if you have any luck
Thanks im buying a 3DR
Old Sep 27, 2012, 08:50 AM
Joined Feb 2012
that's correct, APC's use 57600 max. that's why in config.H the baud rate should be set to 57600 and the mission planner should connect with 57600 to.
but i can't get the two APC's (230) to talk..
i programmed them as well as the AIOP.. still nothing..
anyone with APC's that work can share some light?
i don't want to buy 3DR's when i have two APC230's laying around..
Old Sep 27, 2012, 09:28 AM
Multor is offline
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
which terminal port you plugged your APCs?
make sure its on RX TX 3 as thats the one that outputs the mavlink,
i dont know this, but have you tried to use normal baudrate instead of 57600?
i mean the board spew out 56700 signal, transfer to your air module then transfer on your ground, then change it to usb. maybe it converts it to a differen signal or something, eh who knows
Old Sep 27, 2012, 09:29 AM
DVE is offline
DVE
Find More Posts by DVE
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
Connect RX with TX pins on remote APC, and try to open with Terminal from PC - you must get an echo when typing symbols.
If no, something wrong with the link.
Btw, APC internal speed is 19200, it using a buffer to get "virtual" 57600. 3DR speed is really higher.
DVE is offline Find More Posts by DVE
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
