Old Sep 25, 2012, 05:24 PM
DVE is offline
DVE
Find More Posts by DVE
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
Originally Posted by _AjK_ View Post
Now, placed at about 10/15 cm over the AIOP board, the magnetometer doesn't feel any disturb at all, even with motors at full speed!
Cool! Glad to listen.
Can you share a photo, how you place it? I was trying the same, but couldn't find good way of solid placement of the sensor.
DVE is offline Find More Posts by DVE
Old Sep 25, 2012, 07:13 PM
CN I Dawg is offline
Find More Posts by CN I Dawg
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
Originally Posted by e_lm_70 View Post
This gps is a u-blox NEO-6M GPS module
Good luck finding a way to flash it ...
But, gps works fine without the need to be flashed, this should have a battery capable to store the configuration ... configure a gps is nothing else then send it few serial commands
Anyhow, you should not have problem to connect any gps to this apm board
Tchuss
E_lm_70
Thanks! I saw this on the 3DR site, "The units will ship pre-configured for ArduPilot Mega use, and the configuration file is available in the repository." and this, "has custom and exclusive "DIYDrones" firmware that allows the unit to output an efficient and very compressed binary protocol (This firmware will only work with our modules!)." So I thought there may be an issue?
Steven
CN I Dawg is offline Find More Posts by CN I Dawg
Old Sep 25, 2012, 07:17 PM
Boykintom is offline
Find More Posts by Boykintom
United States, SC, Ridge Spring
Joined May 2012
For you DX6i users out there who want to switch to more than a couple of flight modes on this board, take a look at this link. It may be old news to many, but it sure was good to find for me. I now can switch to 5 different modes, even without a 3 position switch!
Boykintom is offline Find More Posts by Boykintom
Old Sep 25, 2012, 08:30 PM
MadLab is offline
Find More Posts by MadLab
United States, IL, Chicago
Joined Oct 2011
Hey Everyone,
We have been using the Crius AIO Pro with an Extend Board, and think they are pretty spectacular. To keep our boards safe we came out with a case for them we are selling now. If your interested you can check out the post in the classifieds section at the link below.
http://www.rcgroups.com/forums/showthread.php?t=1739998
If you have any ideas for anything that should be changed on the case, please feel free to let us know. We are always open to suggestions.
Mad Lab Industries
http://MadLabIndustries.com
MadLab is offline Find More Posts by MadLab
Latest blog entry: Hexapod Quadcopter
Old Sep 25, 2012, 10:20 PM
_AjK_ is offline
Find More Posts by _AjK_
Registered Bot
_AjK_'s Avatar
Joined Sep 2012
Ehh, I've only made a few tests. Nothing serious yet.
Here is the test PCB(it sucks i know.... ):
and here the placement on the GPS antenna with some ducktape
i'm thinking to make the final PCBwith a 3.3V linear regulator and some 3mm holes to easily fix the PCB to the GPS antenna pole. I still have to design it.
_AjK_ is offline Find More Posts by _AjK_
Old Sep 26, 2012, 12:04 AM
DVE is offline
DVE
DVE
Joined Jul 2011
Cool I also have MAG3110 board, bought it on ebay:
http://www.ebay.com/itm/I2C-MAG3110-...item1c28299063
I've used 2cm plasitic spacers to put the board higher, so internal magnetometer works fine, without another one.
Old Sep 26, 2012, 12:25 AM
_AjK_ is offline
Registered Bot
_AjK_'s Avatar
Joined Sep 2012
I wasn't that lucky.. I've tried with a 4,5cm spacer without results. I think it depends on my power distribuition board or my ESCs.
Old Sep 26, 2012, 12:45 AM
WPDPilot is offline
Find More Posts by WPDPilot
WPDPilot's Avatar
United States, WI, Whitewater
Joined Feb 2012
Hello Gurus,
I have received my Crius AIO v1.1 board along with gps and bt module. I have successfully gotten BT and GPS to work with Multiwii in the GUI.
My problem however is that I would like to use MPNG, but I can't get the board to connect to the mission planner. I have loaded MPNG 2.4R4 and have tried setting every baud rate available the mission planner in config but no joy. I know what com ports I'm using and neither the built in USB nor BT will connect to the mission planner.
Any ideas?
WPDPilot is offline Find More Posts by WPDPilot
Old Sep 26, 2012, 01:54 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
Originally Posted by WPDPilot View Post
Any ideas?
Use latest firmware - 2.7R4, and latest mission Planner.
Sir Alex is offline Find More Posts by Sir Alex
Old Sep 26, 2012, 03:56 AM
Multor is offline
Find More Posts by Multor
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
heyo guys,
has anyone tried DYP-ME007v2 and HC-SR04 sonars?
ive followed the instructions here about 10 page before this.
if im not mistaken trigger is in esc out put signal on d9 and echo is on 10.
now both of them make the clicks. seems like they are working
tho, how do i know it electronically? is there a display on the gui? ive never seen it before, my alt guage still reads its info rom baro, jumps from -60 to -60 everytime just like before.
thanks
Multor is offline Find More Posts by Multor
Old Sep 26, 2012, 04:05 AM
Sir Alex is offline
Aleksey Kharlanov
Joined Sep 2011
Originally Posted by Multor View Post
heyo guys,
thanks
Which firmware? For MPNG you must enable sonar in Mission Planner (select any type of sonar). And restart board after this.
Old Sep 26, 2012, 04:32 AM
Multor is offline
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
yep for mpng, sorry,
i enebeled it and rested it
just the matter of knowing if it works.
Old Sep 26, 2012, 04:58 AM
Joined May 2012
Hello Gurus,
Any ideas?
Do you have a usb to serial port driver like this one? I had the same problem as you and this fixed it.
Old Sep 26, 2012, 07:40 AM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
Can this sonar device work with the AIO Pro
http://www.ebay.com/itm/5-Pin-Ultras...item5ae9c0f6f5
GTiDonavan is offline Find More Posts by GTiDonavan
Old Sep 26, 2012, 09:57 AM
janekx is offline
Find More Posts by janekx
janekx's Avatar
Czech Republic, South Moravian Region, Brno
Joined Aug 2012
same case as SR04, a few pages back or http://www.multiwii.com/forum/viewto...t=sonar#p23645
janekx is offline Find More Posts by janekx
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
