Old Sep 21, 2012, 02:19 AM
didgydont is offline
Find More Posts by didgydont
Australia, VIC, Bannockburn
Joined Aug 2012
Originally Posted by Kd4Kw View Post
As a followup to an earlier request for help thanks everyone. In the sketch I did see how to set or know what the ftdi port speed is. For MPNG can someone fill me in. I'm trying to get the BT working.
I didnt have to do anything to get mine working other than plug it in to the ftdi port. What are you trying to connect to it with ?
didgydont is offline Find More Posts by didgydont
Old Sep 21, 2012, 02:24 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
FTDI is set to 115200bps as normal speed.
It depends on which BT module you have, some have default 9600bps, some the one from CRIUS have 115200bps by default
The BT module can be configured to change the BT name, BT 4 pin security, and as well the speed in BPS
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Sep 21, 2012, 02:36 AM
neo__04 is offline
Find More Posts by neo__04
Australia, VIC, Warrnambool
Joined Feb 2012
Hey,
Just looking at getting myself one of these boards & a gps.
Any recommendations on where to buy the board from?
Also is there a particular gps recommended to run with it?
I plan on running Arudcopter firmware.
Thanks heaps!
neo__04 is offline Find More Posts by neo__04
Old Sep 21, 2012, 03:46 AM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
Originally Posted by neo__04 View Post
Hey,
Thanks heaps!
RC Timer has the v1.1 board GRR and I ordered V1.0 2 days ago
GTiDonavan is offline Find More Posts by GTiDonavan
Old Sep 21, 2012, 03:48 AM
kornetto is offline
Find More Posts by kornetto
Austria, Wien, Vienna
Joined Jan 2006
same here....
but the question is: what has been improved on the V1.1?
kornetto is offline Find More Posts by kornetto
Old Sep 21, 2012, 04:06 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Its looks to be just the USB port that looks different, all other hardware looks the same.....I use Btooth or Xbee for connecting
koolkiwikat is offline Find More Posts by koolkiwikat
Old Sep 21, 2012, 04:11 AM
flyboygaac is offline
Find More Posts by flyboygaac
flyboygaac's Avatar
Portugal, Lisbon, Sintra
Joined Jul 2011
component layout from photos seams to be the same... any difference besides the reinforced USB?
flyboygaac is offline Find More Posts by flyboygaac
Old Sep 21, 2012, 04:26 AM
janekx is offline
Find More Posts by janekx
janekx's Avatar
Czech Republic, South Moravian Region, Brno
Joined Aug 2012
Even version 1.0 had on RCtimer written that have reinforced USB, so my I recieve a few days ago looks same asi 1.1 except circus green pins
janekx is offline Find More Posts by janekx
Old Sep 21, 2012, 04:29 AM
kornetto is offline
Joined Jan 2006
well, I reinforced my USB carefully with a few drops of epoxy. I think when crashing my vehicle the last thing that falls apart is the USB from the AIOP.
I also compared the pictures and could not find any noticeable difference between V1.0 and V1.1 so far...
Old Sep 21, 2012, 04:41 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Hey,
Thanks heaps!
For be on the safe side ... just take it from RTtimer.com ... the ALL IN ONE PRO cost just 2$ more then the cheapest available, but it is already 1.1
GPS module there are also well priced ... around 26$ (cheapest from eBeay is 25$) ... so no much sense to risk and fight with some compatibility issue ...
Anyhow, on hobbyking they had (now is in backorder, and who knows when and if will be back available): http://www.hobbyking.com/hobbyking/s...dproduct=26588 ... that is a ALL IN ONE PRO clone + GPS ... for just 62$ + shipping (3$) ... so the best possible price.
As cheap alternative solution there is this path:
http://www.hobbyking.com/hobbyking/s...dproduct=27033 (26$) .... but it need some hacking (or i2c) for have a direct connected GPS ...
I'm currently hacking MultiWii 2.1 for have direct access to GPS (no i2c board) ... with a similar board as above ... (a clone of this: http://rctimer.com/index.php?gOo=goo...1&productname=) ... the drawback is that GUI and GPS can't be connected on the same time .. but for the rest ... all is looking good so far.
This means that for 50$ you get all the needed parts ... for have a GPS controller ...
Tchuss
e_lm_70
Old Sep 21, 2012, 04:43 AM
janekx is offline
janekx's Avatar
Joined Aug 2012
For smoother pluging and unpluging USB cable I slightly polish hooks on upper side of the MicroUSB cable, it is simple...
Old Sep 21, 2012, 04:46 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Originally Posted by kornetto View Post
same here....
The only difference that I can see immediately is "Separate 3.3V and 5V LDO voltage regulator".
nebstress is offline Find More Posts by nebstress
Old Sep 21, 2012, 04:47 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
I pulled those 'Hooks' out completely, even more simple.
Old Sep 21, 2012, 04:52 AM
janekx is offline
janekx's Avatar
Joined Aug 2012
I wanted to catch there a little, some MicroUSB keeps in place without hooks because are out of tolerance, are bigger, my cable without hooks will disconnect very easily (fall off).
Old Sep 21, 2012, 05:01 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
That is a good point but I think too loose is better than too tight (in this case anyway) that is if you can't get it perfect I think any fix is good that will save stress on the USB port, even the boards with "reenforced" USB don't seem much better so it is best to do something with the "Hooks".
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
