Have a look at "koolkiwikat's" last post HERE |
![]() edit: i tried 180 imax from 20 and now its good but its sliding around really badly and sometimes it just shoots up to one direction for no reason. on MY crius multiwii SE board it works fine, all my esc are calibrated parallely.
http://www.cpkb.org/wiki/Micro-USB_pinout just visualize it imagine* you have the female version and lay the orientations down in your board. ![]() edit: oops i just read thoroughly tru your post. get your usb cord plug it in your broken female micro connector and see the continuities of your missing pin 4. |
But for some reason, the PC can't see it. |
Australia, VIC, Bannockburn
Joined Aug 2012
Can some one please explain how to get voltage sensor working I'm pretty sure it's pin a0 I can configure it and then test it with a battery and the volts change when I connect it to battery but it's not an accurate reading. I have tried the power from the ubec and a esc but the voltage on both don't seem to drop as the battery drains. I'm using mega pirate r4. I'm trying to get the battery reading correct in the mission planner osd.
United States, CA, Yosemite Lakes
I played with the settings a bit and got it to hover at about 2 feet. But it only will hover for like 10-15 seconds. Then one side will cut out and dip and it crashes to the ground. |
Oh, Oops
I miss spoke (typed) I used the card to make all settings identical (cut off, timing ect) And I used a y-harness to do the throttle calibration 2 at a time. Ill try again one at a time tonight. Im also trying to fab that CD holder Board suspending rubber band mount I saw on here. Forgot who made it. |
Joined Aug 2012
I've read through this entire thread to learn more about the board, and there are questions that were completely skipped through regarding the GPS...
who knows what is a better module to use with the AIO? these seem to be what the majority is using: U-blox NEO-6M U-blox LEA-6H MediaTek MT3329 MediaTek MT3339 anyone? |
Austria
Joined Jan 2004
I have a U_blox NEO-6M ... with 6.02 firmware, if anybody knows how to upgrade the firmware to 7.03 I will appreciate, on ublox site apparently NEO firmware is not even available ... |
Joined Jun 2008
Anyone know how to reach rctimer?
Hi,
I've been trying to get in touch with rctimer via email, does anyone know how to reach them? I've tried sales@rctimer.com and rctimer@gmail.com, are there any others? Thanks!
Joined Dec 2011
CRIUS LCD not working?
I saw earlier in the thread some back-and-forth about the Crius LCD not working properly with MultiWii 2.0 and above. I'm having some problems getting my LCD to work, and wondered if anyone had some solutions (other than soldering an ISP header to the LCD board and reflashing the firmware).
I'm using MultiWii 2.1 with a Crius SE 2.0, and the Crius LCD flashes "SERIAL LCD V1.03" on power-up. Has anyone managed to get this working using LCD_SERIAL3W , or is there something else I'm missing? |
| Thread Tools | |
| Discussion New updated Crius Multiwii SE flight controller | SGsoar | Multirotor Electronics | 72 | May 15, 2013 08:36 PM |
| Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 | pprioverde | Multirotor Talk | 29 | Nov 21, 2012 09:58 PM |
| Discussion Jim, any plans for more multi rotor flight controller? | chris24g | Xtreme Power Systems | 12 | Jun 25, 2012 08:11 PM |
| Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots | wingspinner | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | May 28, 2012 12:55 AM |
| Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) | SJackson | Multirotor Talk | 27 | Apr 30, 2012 08:51 PM |
