Old Sep 19, 2012, 02:00 AM
arkcom is offline
Find More Posts by arkcom
Northwest Arkansas
Joined Sep 2008
Originally Posted by x_rui View Post
Is that a fact or a question?
Fact.
arkcom is offline Find More Posts by arkcom
Old Sep 19, 2012, 02:03 AM
janekx is offline
Find More Posts by janekx
janekx's Avatar
Czech Republic, South Moravian Region, Brno
Joined Aug 2012
When one side transmit TX pin transmiting other must Recieve Rx pin recieving and vice versa.
janekx is offline Find More Posts by janekx
Old Sep 19, 2012, 02:07 AM
janekx is offline
janekx's Avatar
Joined Aug 2012
Today arrive AIOP to me and for information was in antistatic bag and in the hard paper box for protection, look that Nina read this thread carefully
Old Sep 19, 2012, 05:23 AM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
Hi are these the receiver connections regardless of what
#define TX_CHANNEL_SET is set to in megapirate?
Thanks.
NDw is offline Find More Posts by NDw
Old Sep 19, 2012, 05:34 AM
Multor is offline
Find More Posts by Multor
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
MegaPirate Ninja
Hi there guys, got my crius for quite a while now.
Really not happy with the stabilization at all, it wobbles like fat tire, unresponsive like a cat.
oscillates like a horny man D:.
and i dont think its on the P at all, tried going from 0-5, no changes D:
i tried everything
My accelerometer keeps resetting it self
I would try to make a video but its really hard to get a good shot.
Multor is offline Find More Posts by Multor
Old Sep 19, 2012, 05:51 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Originally Posted by Multor View Post
MegaPirate Ninja
i tried everything
Sounds like a can of random!, what pill did you take? the blue(MPNG) or red(MWii)?
koolkiwikat is offline Find More Posts by koolkiwikat
Old Sep 19, 2012, 05:59 AM
Multor is offline
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
Megapirateninja
what could be wrong is the PPM SUM putting me back or something?
Old Sep 19, 2012, 06:25 AM
didgydont is offline
Find More Posts by didgydont
Australia, VIC, Bannockburn
Joined Aug 2012
I found this in this thread. "- Lipo voltage sense: connects to pin A3 from A0~A5 plug"
How do i do this ? do i just connect positive from lipo in to a3 ? This thread needs sub cats
didgydont is offline Find More Posts by didgydont
Old Sep 19, 2012, 06:30 AM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
For anybody looking to get a Gimbal working with MultiWII 2.1
RHTizzy is offline Find More Posts by RHTizzy
Old Sep 19, 2012, 09:25 AM
NDw is offline
NDw
NDw
Joined Aug 2010
Hi. So I've configured my radio to match mission planner. And reversed channels so that everything goes in the right direction in that. Should that mean that my channels should be correct? When I try to fly pitch seems to be reversed and possibly something else.
Thanks.
Old Sep 19, 2012, 11:12 AM
scribble007 is online now
Find More Posts by scribble007
United States, CA, Yosemite Lakes
Can Some one list some starting PID settings for multiwii 2.1 on a 450 quad
I just got some apc props. And dubro balencer. They spin buttery smooth.
But my quad refuses to hover/fly. It spins up then cuts out spins up then one side dips. cuts out. then the side that dips starts up again and the other side falls.
Before I thought this was a vibration issue. But I'm not getting significant readings from the accel. On the graph.
My board it mounted to the top. With Velcro mounted to 2 layers of double sided foam tape.. That my problem?
I can take a video today after work if it will help you help me.
scribble007 is online now Find More Posts by scribble007
Old Sep 19, 2012, 11:30 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
The default PID's should be OK for a 450 size Quad & it doesn't sound like its the Gains, if it was it would spin up & take off but just oscillate (wobble/shake) while hovering.
A video & maybe a photo as well showing how the Board is actually mounted would help .
nebstress is offline Find More Posts by nebstress
Old Sep 19, 2012, 11:32 AM
Quadframes is offline
Find More Posts by Quadframes
Quadframes's Avatar
Joined Jun 2011
Thanks.
dont reverse your channels in the mission planner as if you upgrade your software you could forget to redo this and well could crash or worse! reverse the channels on your radio that way they are always done
Quadframes is offline Find More Posts by Quadframes
Old Sep 19, 2012, 11:34 AM
penpen is offline
Find More Posts by penpen
France, IdF, Paris
Joined May 2010
hint:
for mwii, tune roll/pitch PID
for megapirate, tune roll/pitch RATE (not the pid part)
penpen is offline Find More Posts by penpen
Old Sep 19, 2012, 12:42 PM
abriosi is offline
Find More Posts by abriosi
abriosi's Avatar
Portugal, Setúbal, Palmela
Joined Jul 2011
Failsafe
Guys i'm having trouble configuring MPNG failsafe feature on 2.7 R4, can anyone give me some light on the subject?
Thank you
abriosi is offline Find More Posts by abriosi
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
