Old Sep 17, 2012, 10:19 AM
flash301 is offline
Find More Posts by flash301
Joined Mar 2012
Thanks for your help! You were right I had
//#define NMEA
#define UBLOX
// #define MTK
#define GPS_LEAD_FILTER
//#define GPS_FILTERING
//#define NAV_SLEW_RATE 30
At the bottom of GPS section I have now moved it to the top. But I still have the same problem.
Also my multiwi.ino looks like this
#if defined(ARMEDTIMEWARNING)
ArmedTimeWarningMicroSeconds = (ARMEDTIMEWARNING *1000000);
#endif
#if defined(GPS_SERIAL)
#if defined(UBLOX)
UBLOX_init();
delay(200);
#endif
#if defined(MTK)
MTK_init();
delay(200);
#endif
SerialOpen(GPS_SERIAL,GPS_BAUD);
delay(400);
for(uint8_t i=0;i<=5;i++){
GPS_NewData();
I have #if define(GPS_SERIAL)
SHOULD THAT BE THERE ?
flash301 is offline Find More Posts by flash301
Old Sep 17, 2012, 10:24 AM
flash301 is offline
Joined Mar 2012
I took those two lines out and now it compiles thank you so much for your help
Old Sep 17, 2012, 01:16 PM
cjnuk is offline
Find More Posts by cjnuk
Joined Oct 2010
How hard would it be to alter the serial port for the LCD in MultiWii from port 0 to 3? It's not a major deal but it simplifies the wiring when there's a GPS attached too and saves using those rather flimsy sockets too often. I've had a look through the source but my programming skills are pretty basic!
Perhaps an option in the config.h to change from 0 to 3 would be possible? Pretty please?
cjnuk is offline Find More Posts by cjnuk
Old Sep 17, 2012, 01:27 PM
kornetto is offline
Find More Posts by kornetto
Austria, Wien, Vienna
Joined Jan 2006
Hi there!
I am following this thread since some while, received my AIOP a few days ago and now started to play around with MPNG 2.7R4
In fact it runs well so far on the bench. However, I still could not figure out how to get the AP_Limits library working with MPNG on the AIOP.
I understand that when using Mission Planner with the original ArduPilot, one can modify apart from other things also the "Parameter List" which in the background will somehow create/modify some APM_Config_cmake.h or so.
From my understanding this is not the case when using MPNG, so we can ignore that Parameter List.
However, we can use the settings listed in config.h, but instead of modifying config.h, we should rather do our changes in APM_Config.h
Now, I wanted to enable AP_Limits in order to play around with LIM_ALT as well as geo fencing.
I added following lines to AP_Config.h:
#define AP_LIMITS ENABLED
#define LIM_ENABLED 1
#define LIM_ALT_ON 1
#define LIM_FNC_ON 1
#define LIM_GPSLCK_ON 1
recompiling and uploading MPNG does not change anything in Mission Planner for me. I still cannot choose/configure any of the limits things or geo fencing.
What am I missing here?
thanks a lot for your help!
Christian
kornetto is offline Find More Posts by kornetto
Old Sep 17, 2012, 01:39 PM
helidex is offline
Find More Posts by helidex
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
Originally Posted by 41south View Post
Mine is working fine in this configuration, running a ubec to power the AIOP and also plugged into usb.
Fired it up with MPNG and the CN-06 gps for the first time yesterday, worked like a charm with 7 sats lock sitting on the window ledge inside
Thanks for that - Just noticed the distance from Napier to Wellington used to be 338Km - is now 9000Km
helidex is offline Find More Posts by helidex
Old Sep 17, 2012, 01:47 PM
Kd4Kw is offline
Find More Posts by Kd4Kw
KD4KW
Kd4Kw's Avatar
United States, FL, Tallahassee
Joined Jul 2009
Hi, thanks to everyone on the thread. Reading this forum has helped me a ton. I compiled my MPNG and got the board and GPS working first try. Question how do I cal the mag and where in the code do I configure my declination? I looked thru the code and may well have missed it. Oh, another question. Why does the BT need to be on the FTDI port rather than t3-r3 telemetery?
Kd4Kw is offline Find More Posts by Kd4Kw
Old Sep 17, 2012, 02:08 PM
matorsk is offline
Find More Posts by matorsk
Joined Sep 2012
aio pro mp gimbal
Hi folks, I have problem with my aio pro with megapirate firmware and gimbal, it simply do not work, I tried almost everything, have anyone this setup with working gimbal, could you help me? Thank you a lot.
matorsk is offline Find More Posts by matorsk
Old Sep 18, 2012, 11:23 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
You Calibrate the Mag & set the declination in the Mission Planner (-Configuration-Hardware Options).
The Serial Port is in use on most peoples setups for GPS etc & though RX3-TX3 might be free the VCC & GND aren't so it is easier & tidier to put the BT in the FTDI port.
nebstress is offline Find More Posts by nebstress
Old Sep 18, 2012, 03:22 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
Originally Posted by nebstress View Post
I have installed the GPS fix in a copy of MultiWii 2.1 & it can be downloaded HERE.
What is this sorcery!!
That one worked..but looked pretty much the same as mine did before. Whatever, not complaining
Thanks nebstress!!
Endlesslag is offline Find More Posts by Endlesslag
Old Sep 18, 2012, 04:15 PM
Torque66 is offline
Find More Posts by Torque66
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
Hey... i have an all stock motors esc DJI F450.... can i just swap the AIOP with the snooza and i'm good to go?
thx...
Torque66 is offline Find More Posts by Torque66
Old Sep 18, 2012, 06:18 PM
41south is offline
Find More Posts by 41south
Yet another flying K1W1
41south's Avatar
Wellington, New Zealand
Joined Jan 2006
You folks had another earthquake and moved a looooong way away?
41south is offline Find More Posts by 41south
Old Sep 18, 2012, 08:23 PM
Jerry Campbell is offline
Find More Posts by Jerry Campbell
Jerry Campbell's Avatar
United States, OR, Blodgett
Joined Apr 2011
Hello,
Is there any reason I should not hook up my board directly from my 3S battery to the extended power input? I have a UBEC, I'm just wondering if I need to use it.
Jerry
Jerry Campbell is offline Find More Posts by Jerry Campbell
Old Sep 19, 2012, 01:37 AM
x_rui is offline
Find More Posts by x_rui
aka icsss
Joined Feb 2012
I have this FC Bluetooth Module.
How do I connect it to the FC? Is this correct?
FTDI --> Bluetooth Module:
TX0 --> TXD
RX0 --> RXD
5V --> VCC
GND --> GND
Anything else I have to do to connect it using mwii2.1?
x_rui is offline Find More Posts by x_rui
Old Sep 19, 2012, 01:52 AM
janekx is offline
Find More Posts by janekx
janekx's Avatar
Czech Republic, South Moravian Region, Brno
Joined Aug 2012
Should be TX to RX and RX to TX I thing
janekx is offline Find More Posts by janekx
Old Sep 19, 2012, 01:54 AM
x_rui is offline
aka icsss
Joined Feb 2012
Originally Posted by janekx View Post
No should be TX to RX and RX to TX?
Is that a fact or a question?
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
