Old Sep 14, 2012, 05:32 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Originally Posted by Vortexxx View Post
I am having trouble flashing MW 2.1 to my new AIO PRO I've set the com port and board, then compile the sketch and then upload it and it goes through with no error messages. The red and green board leds are permanently lit, the rx/tx leds blink away next to the USB and the "A" & "B" leds blink whilst the upload is underway.
After the upload completes the Arduino shows "Done uploading" and in the dialogue window there is a description of the file and NO errors. On the board the green & red leds are lit but the "A" & "B" leds are blinking slowly together.
Connect the board up to the GUI and it connects, there is no input from any sensors and it is flatlining with I2C errors rapidly increasing.
I have tried everything I can think of to get it working but am stumped!!
Anyone seen this before and know what the flashing leds mean and how to get it going or is it toast!!!
Lance
Hi Lance,
That's an odd one, are you sure that you have defined the correct settings in "Config.h" before compiling & uploading?
ie:
Define Multi type (eg: #define QUADX)
Define Board in "Boards and sensor definitions" (eg: #define CRIUS_AIO_PRO_V1 // Crius Multiwii AIO PRO v1.)
nebstress is offline Find More Posts by nebstress
Old Sep 14, 2012, 06:35 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
HELP!, Im wanting to install this INSIDE a DJI450 clone frame, the mount holes cause the board to be at a 45 degree angle, what do I change in the MPNG 2.7r3 sketch to get it to work as if the board was facing forward?
koolkiwikat is offline Find More Posts by koolkiwikat
Old Sep 14, 2012, 06:40 AM
janekx is offline
Find More Posts by janekx
janekx's Avatar
Czech Republic, South Moravian Region, Brno
Joined Aug 2012
Small noob question, I ordered MediaTek MT3329 GPS 10Hz + Adapter Basic Compatible with Remzibi's OSD(Poor Man's OSD)
And there is written
Note that the new MediaTek has custom and exclusive "DIYDrones" firmware that allows the unit to output an efficient and very compressed binary protocol (This firmware will only work with our modules!). You can still change between NMEA and Binary protocol with standard MTK messages, and switch the refresh rate between 1hz to 10hz, or set any standard serial baud rate (by default is set to 38400 bps and custom binary protocol).
Should I need change FW for 10Hz or only setting to 115200 and 10Hz? What device use (RCtimers FTDI Basic Breakout Arduino USB-TTL 6 PIN 3.3 5V or RS232 + 5V is enought Aten uc-232a) to connect to PC for this operation (flast / setting)
Janekx
janekx is offline Find More Posts by janekx
Old Sep 14, 2012, 07:23 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
It would be easier to use an adapter plate:
Old Sep 14, 2012, 07:25 AM
Vortexxx is offline
Find More Posts by Vortexxx
Joined Apr 2012
Originally Posted by nebstress View Post
Hi Lance,
ie:
Thanks nebstress, Yes I just double checked and both lines are in there exactly as you have written them.
Any other ideas??
Anyone know what the leds "A" "B" "C" mean?? I have a slow flashing "A" & "B" together.
Lance
Vortexxx is offline Find More Posts by Vortexxx
Old Sep 14, 2012, 07:32 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Any other ideas??
Lance
OK but have you 'defined' them ie; removed the "//" in front of them?
Otherwise have you tried deleting your copy of MWC 2.1 & re-downloading a fresh copy then trying that.
Old Sep 14, 2012, 10:54 AM
crash_1958 is offline
Find More Posts by crash_1958
crash_1958's Avatar
Canada, BC, Victoria
Joined May 2010
Originally Posted by liorz055 View Post
Hi ,
I did throttle calibration for the esc's,.
from some strange reason the motor start moving only at 90% throttle.
What am I doing wrong?
Lior.
Are you trying to do them all at once? When I tried that I ended up with the same
problem did them all individually and that worked great.
crash_1958 is offline Find More Posts by crash_1958
Old Sep 14, 2012, 11:05 AM
liorz055 is offline
Find More Posts by liorz055
Joined Aug 2009
Thanks Guy,
At first I tried them all at once , it failed . Today I tried to calibrate them individually and it did worked great . I did a median flight today and I think it went well because the quad is still in one pice..
By the way did you managed to get gps fix at the end???
liorz055 is offline Find More Posts by liorz055
Old Sep 14, 2012, 11:09 AM
crash_1958's Avatar
Joined May 2010
Thank guy ,
At first I tried them all at once , it failed . Today I tried calibrate them individually and it did worked great . I did a median today and I think it went good because the quad is still in one pice..
Yea took your advice and loaded the sketch without anything attached and now it's
working. Don't know why that would make a difference but as long as it works I don't really care.
Hope to get it finished and maidend this weekend.
Old Sep 14, 2012, 02:25 PM
toney is offline
Find More Posts by toney
United Kingdom, Chesterton
Joined Oct 2010
As I previously documented I've had problems with the quad running MPNG firmware where adjusting the PIDS has no effect on oscillations. Multiwii seems a little more stable in this respect. I would love to use MPNG as I'm familiar with the APM planner and all the extra features it brings.
Sorry for the poor video
MPNG Multiwii (0 min 11 sec)
toney is offline Find More Posts by toney
Old Sep 14, 2012, 03:24 PM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
Looks like your rate P is to high have you tried lowering just that
Gaza07 is offline Find More Posts by Gaza07
Old Sep 14, 2012, 06:08 PM
KevinBuckley70 is offline
Find More Posts by KevinBuckley70
KevinBuckley70's Avatar
Oxfordshire, UK
Joined Jul 2001
Originally Posted by Sir Alex View Post
Bluetooth modules work well with MPNG
It has been said by a few people here (and is also my experience so far) that BT doesn't work with MPNG for the various flavours af Android used on mobile phones and tablets.
It would be great if that is not true!
But I think most of the 'how to' posts are related to using it with laptops although it is often not stated.
Can we use BT on MPNG with Android?
KevinBuckley70 is offline Find More Posts by KevinBuckley70
Old Sep 14, 2012, 09:04 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
It's not that you can't use it, there's just no app for android for MPNG.
Edit: there's this but I'm not sure
Originally Posted by turbodriven View Post
Please do tell how... in detail. I've already seen the xbee link people posted before... and it doesn't tell how really. I'm dying to get my bluetooth module to work with Copter-GCS!
Edit: This link. Doesn't really show how?? http://code.google.com/p/copter-gcs/
TheFernMan is offline Find More Posts by TheFernMan
Old Sep 14, 2012, 09:20 PM
Multor is offline
Find More Posts by Multor
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
Connect your bluetooth to your xbee or 3dr ground module
txrx
rxtx
vccvcc
gndgnd
Multor is offline Find More Posts by Multor
Old Sep 14, 2012, 10:30 PM
Vortexxx is offline
Joined Apr 2012
FIXED!!!! Fantastic...Thankyou nebstress.
I have one other question.......
I am trying to get it to recognise my Crius GPS Receiver. I have it connected via the nav board but it doesn't seem to recognise it (the GPS is not lit in the GUI) but it's working fine in the U-Center
I have changed the baud rate to 115200 and 100hz and saved the changes
I tried setting the I2C GPS active in config.h and it came up with a whole bunch of errors when I checked the script. Any ideas or should I just connect it to the serial port??
Lance
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
