Old Sep 07, 2012, 06:07 AM
rkenosha is offline
Find More Posts by rkenosha
Joined Jan 2012
Thanks for the reply. So when the board arrives and I want to use multiwi as the code, the Gui is Arduino? rkenosha
rkenosha is offline Find More Posts by rkenosha
Old Sep 07, 2012, 06:14 AM
Trauma50 is offline
Find More Posts by Trauma50
Joined Sep 2011
Oreintation
Thanks for the ideas with keeping up with what way my Multi copter is going. I have a florescent orange Velcro strap about 5 ins long hanging off the front of my +quad. Helps close in but past 50 yards or so its not much good.
I'll give the strobes a try and SEE how that goes.
After posting my question I thought about it more, and a plane is always moving forward, but a copter can go were it wants. But not always were I want it at this stage for me.
In Multiwii GUI what adjustment do I need to make for the throttle more responsive to hovering? It seems it's always going up or coming down. I have constantly be on the stick anticipating the up and down movement. Once in a while I get it just right?
Thanks again for all your input.
Trauma50 is offline Find More Posts by Trauma50
Old Sep 07, 2012, 06:24 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
No you use Arduino 1.0.1 to configure & upload the firmware to the CRIUS AIOP.
For MultiWii there are two GUI's, the one that comes with the firmware & the MW-WINGUI, I prefer the WINGUI because it has a lot more functionality & looks & works better.
nebstress is offline Find More Posts by nebstress
Old Sep 07, 2012, 06:33 AM
rkenosha is offline
Joined Jan 2012
Thanks. It should be here in a week or so, just getting my mind wrapped around the beginning process. rkenosha
Old Sep 07, 2012, 08:05 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
Originally Posted by CokeViper View Post
It seems like I can receive data on my PC, but I can't send. So how do I get this working?
Maybe FT232R on-board is preventing to communicate with ATMEGA2560. If your USB connector damaged, try to desolder FT232R chip.
Sir Alex is offline Find More Posts by Sir Alex
Old Sep 07, 2012, 08:19 AM
benybee is offline
Find More Posts by benybee
Indonesia, Lampung, Sukarame
Joined Dec 2009
Hi, anyone.. sorry i'm new for this board...
i decided to buy cirus AIOP for my second amateur UAV from rctimer..
i almost buy from Hobbyking, but i don't want bad sensor for my plane (some poeple said that)..
and i'm in hurry (sorry)
for info i wanna use this board for my FLYINGWING
and wanna add this airspeed sensor
so i wanna ask simple question:
1. i wanna use this OSD while i use TELEMETRY, can i do that in the same time?
2. which firmware that already tested? can you list those firmware for me?
any answer would be very much appreciated.. thanks
//ben
benybee is offline Find More Posts by benybee
Old Sep 07, 2012, 09:27 AM
flye is offline
Find More Posts by flye
Joined Sep 2010
Hi,
I'm trying to connect the board with a FTDI - USB breakout board to my computer, because my onboard USB port is broken.
However the APM connection fails, and I can't connect to the CLI either.
Dont know if you can get it working but I returned mine to rctimer for the same trouble
flye is offline Find More Posts by flye
Old Sep 07, 2012, 10:46 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Okay, now I have a problem. Loiter seemed fine the other day, but right now it just drifts. It drifts so far out of it's "home" that I have to manually bring it back before it bumps into trees, 10-20 meters away. Also, RTL is broken, it rises to about 15m and then scoots off in the wrong direction, after a short time it pitches down and I have to bring it back fast or it'll hit the ground hard.
Simple mode is also broken, it won't tilt in the right direction, even when I stand behind it and re-arm.
I have NO idea how to fix this. -_-; How can I get rid of interference that gets to the mag sensor?
WiseDuck is offline Find More Posts by WiseDuck
Old Sep 07, 2012, 11:44 AM
CHRISGA1A is offline
Find More Posts by CHRISGA1A
CHRISGA1A's Avatar
United States, FL, Palm Beach Gardens
Joined Jun 2012
Do you have a GPS fix?
CHRISGA1A is offline Find More Posts by CHRISGA1A
Old Sep 07, 2012, 01:44 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Here are my findings so far:
Acro, doesn't wobble. Doesn't hold angles though, so it's very unresponsive.
Stable, perfect the way it is. No wobbles, perfectly level, love it.
Loiter, OK for about 10 seconds. Then it starts to drift in a huge circle, 10 meter wide or so. No matter what I change, it does this every time. HOW do I tune this?
RTL, unpredictable. Tested it many times today. Sometimes it will scoot away in the wrong direction, when it does it WILL crash unless I intervene.
Sometimes it'll return to the home spot with perfect aim, then drop down, but it NEVER LANDS! Even though RTL Land is set to 1 it just stays 1 meter above ground and never ever lands. What's up with that?!
EDIT: One more thing, I can't seem to download logs. As soon as I try I get some error message about the com port and I'm disconnected.
Old Sep 07, 2012, 02:26 PM
Soupbones is offline
Find More Posts by Soupbones
Soupbones's Avatar
Australia
Joined May 2011
Oh don't tell us that! After loosing my quad with a rabbit due to it flying off, I now purchased a Crius in the hope that when I get around to using GPS it would be much better.
Seems the RTL on these Chinese boards is set to take it back to china!
Soupbones is offline Find More Posts by Soupbones
Old Sep 07, 2012, 02:31 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Arducopter has never really been advertised as a plug-and-play solution. We just need better documentation and some kind of list of what differs between multiwii and Arducopter. The only rock-solid but expensive solution I knwo of is Naza + GPS.
I mean, on Multiwii tuning is super simple. Adjust P until it no longer oscillates, increas I until it holds whatever angle you set it to, leave D alone. Done.
But Arducopter seems to work in a different way. So yeah, I need to experiment again..
And yes, I hope I can make RTL more reliable somehow. It MUST be, otherwise the entire point of having a GPS is lost. It is absolutely crucial that RTL works like it should.
Old Sep 07, 2012, 03:44 PM
DVE is offline
DVE
Find More Posts by DVE
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
Check compass at first, all GPS problems are going from it.
ALL directions in Simple Mode must work correctly (nose, back, left, right), if not, copter will fly in the wrong direction. Several tests (with Rabbit) were made, when board is plugged incorrect, in some directions compass is working, in some - not. After placing the board higher from the wires, problem gone away.
DVE is offline Find More Posts by DVE
Old Sep 07, 2012, 03:50 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
I cannot place mine higher. Question, will ferrite rings make a difference? I have several of the clip-on type that may fit on some of the ESC wires among other things.
Old Sep 07, 2012, 10:26 PM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
I am new to this, GPS drift in a huge circle = magnetic declination [difference between true North and Magnetic North] is not set correctly for your location, GPS and magnetic compass are trying for 2 very different targets hence the slow circling and can't find home..
EDIT: here is a video that may help
Naza Flight Controller Fix with GPS - Magnetic Declination Compensation (5 min 2 sec)
He is fixing it by physically rotating the magnetic compass, I assume the same can be done in the software.
jabram is offline Find More Posts by jabram
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
