Old Jun 23, 2012, 02:43 PM
mealie is offline
Find More Posts by mealie
Joined Jun 2011
New Product
CRIUS ALL IN ONE PRO v1.0 Multi Rotor Flight Controller
◆Features:
•Support MegaPirateNG / ArduPlaneNG / ArduCopterNG / MultiWii / AeroQuad firmware
•8-axis motor output
•8 input channels
•4 serial ports (S0~S3)
•2/3-axis gimbal system
•6 Analog port for extend device (A0~A5)
•I2C port for extend sensor or device
•Separate 3.3V and 5V 500mA LDO voltage regulator
•ATMega 2560 Microcontroller
•MPU6050 6 axis gyro/accel with Motion Processing Unit
•HMC5883L 3-axis digital magnetometer
•MS5611-01BA01 highprecision altimeter
•FT232RQ USB-UART chip and Micro USB receptacle
•On board logic level converter
•Dimension: 50mmX50mm
•45x45mm mounting holes
•Height: 11.6mm
•Weight: 14.2g
•Hole diameter: 3mm
•Match the standard of RoHS
◆Package content
•AIO PRO FC x 1
•3Pin to 1Pinx3 cable 100mm x 3
•3Pin to 3Pin cable 100mm x 1
•Molex 1.25mm 4Pin cable 100mm x1
•Molex 1.25mm 6Pin cable 100mm x2
•Molex 1.25mm 8Pin cable 100mm x1
Warning!
Issues of clone board :
http://www.rcgroups.com/forums/showthread.php?t=1790506
Thanks jabram very much!
mealie is offline Find More Posts by mealie
Old Jun 23, 2012, 02:48 PM
Quadframes is offline
Find More Posts by Quadframes
Quadframes's Avatar
Joined Jun 2011
were can we buy ??
Quadframes is offline Find More Posts by Quadframes
Old Jun 23, 2012, 02:59 PM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Very nice spec.
TS00 is offline Find More Posts by TS00
Old Jun 23, 2012, 04:13 PM
mealie is offline
Joined Jun 2011
Coming soon.......
Old Jun 23, 2012, 06:52 PM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
great board
hope the price will be good
titeuf007 is offline Find More Posts by titeuf007
Old Jun 24, 2012, 01:47 AM
Greenpeace is offline
Find More Posts by Greenpeace
Joined May 2012
How soon? I don't want to wait 2-3 months.
Greenpeace is offline Find More Posts by Greenpeace
Old Jun 24, 2012, 02:00 AM
mealie is offline
Joined Jun 2011
Try search "Multiwill Flight Controller V1.0" on ebay
Old Jun 24, 2012, 03:17 AM
Lorphos is offline
Find More Posts by Lorphos
aerial photographer
Lorphos's Avatar
Germany, NRW, Dortmund
Joined Dec 2004
70€ + 10€ shipping (+taxes) on ebay sold by "forcehobby"
Lorphos is offline Find More Posts by Lorphos
Old Jun 24, 2012, 07:38 AM
Joined Jun 2006
too expansive!
rabbit flight controll with news baro is less expansive and have a great stability!!!!!
Old Jun 24, 2012, 08:14 AM
Quadframes's Avatar
Joined Jun 2011
Originally Posted by titeuf007 View Post
too expansive!
Rabbit flight controll with news baro is less expansive and have a great stability!!!!!
+100
Old Jun 24, 2012, 01:47 PM
mealie is offline
Joined Jun 2011
rabbit...
Old Jun 24, 2012, 01:53 PM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Originally Posted by mealie View Post
rabbit...
Don't worry, it's a flight controller just like you board, but people seem to wet their pants over it because it has a 32 bit processor.
(even though the code was written for an 8 bit!)
Give me an 8 bit running well tested multiwii code anyday.
Old Jun 24, 2012, 04:49 PM
Lorphos is offline
aerial photographer
Lorphos's Avatar
Joined Dec 2004
too expansive!
Isn't the Rabbit FC firmware stolen from MultiWii in violation of the GPL?
I believe the advantage of this board is that it runs both MultiWii and MegaPirateNG and has all four sensors onboard (gyro, acc, baro, compass), together with the ATMega 2560.
It's a lot cheaper than the APM 2, even if you add GPS. It is, however, more expensive than http://www.goodluckbuy.com/mwc-multi...ard-quadx.html
Old Jun 24, 2012, 05:28 PM
Katch is offline
Find More Posts by Katch
FC flux'd
Katch's Avatar
Joined Jan 2007
Meh megapirate comes with 10 dof and runs MWC and Megapirate-ng code on a 2560 for $65.
I don't see the point in the high price for this one.
http://www.ebay.co.uk/itm/Pirate-Fli...#ht_3546wt_923
Katch is offline Find More Posts by Katch
Old Jun 25, 2012, 12:45 AM
mealie is offline
Joined Jun 2011
The IMU board used BMP085, low precision baro.
The main board no FTDI circuit and voltage regulator.
So it is cheap.
http://rover.ebay.com/rover/1/710-53...3ht_3546wt_923
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
