Old Jun 23, 2012, 11:40 AM
milo12 is online now
Find More Posts by milo12
Joined Feb 2011
Looking for VTOL that tilts props for control
I am looking for info and videos of a VTOL that uses servos to tilt a prop while in hover for pitch and roll control. I know I have seen them but searching couldn't find them. The prop is oriented so it is horizontal, motor shaft pointing vertical. Basically the tilting replaces cyclic as used on a helicopter.
I know most 1 man gyrocopters use tilting the rotor for control. I am interested in how using a tilting prop(rotor) for control compares to conventional cyclic on a RC vehicle.
I do not want tilt props like the Osprey or tilt wings. I am looking for hovering vehicles that use tilting the prop for stability control.
Thanks.
milo12 is online now Find More Posts by milo12
Old Jun 24, 2012, 06:26 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Check out the twin (side by side) copters. That is how most of them control pitch.
Example
Also, not quite the same, there are a couple of tilt the prop that have wing designs.
example
leadfeather is offline Find More Posts by leadfeather
Old Jun 24, 2012, 06:27 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Weight shifting is the closest I have seen.
RCvertt is offline Find More Posts by RCvertt
Old Aug 23, 2012, 05:12 AM
SONICX is offline
Find More Posts by SONICX
SONICX's Avatar
South Africa, GP, Krugersdorp
Joined Jul 2012
Read this tread, has lots of info on what you are looking for
http://www.rcgroups.com/forums/showthread.php?t=1278074
SONICX is offline Find More Posts by SONICX
Old Aug 23, 2012, 08:39 AM
Brandano is offline
Find More Posts by Brandano
Unless you have a fully articulated rotor it is always a form of weight shifting. For a tilt prop to work there must be some distance between the CG of the plane and the prop tilting axis, and the CG must be beneath the tilt axis while in a hover. This is not desirable in full size planes, since there must be some available CG range (expecially for cargo planes), so generally even though the rotors do tilt, pitch is controlled with fore/aft cyclic, like roll is controlled with side/side cyclic in tandem helicopters.
Brandano is offline Find More Posts by Brandano
Help! looking for non-folding prop and spinner for radian pro devinvagt FPV Talk 0 Jun 17, 2012 11:28 PM
Help! Looking for 24x12 counter rotating props T.T. Multirotor Talk 17 Jun 14, 2012 06:56 PM
Help! looking for a prop that won't self destruct. ApachePilot Flying Wings 8 May 25, 2009 10:34 PM
finally did it: VTOL tilt prop w. 2 airplane props hovers garygress Electric Plane Talk 31 Sep 26, 2008 07:10 AM
R/C Tilt-wing VTOL: has anybody ever actually done this? Bill Glover Electric Plane Talk 21 Jul 22, 2002 11:00 AM
