Old Jan 02, 2013, 06:09 PM
sjb_rc is offline
Find More Posts by sjb_rc
Joined Mar 2012
Originally Posted by jaroSK View Post
Hi,
who know what I did wrong ? Pls, look on my video, rotation about one axis is ok, but rotation about the second axis is different, servo always return to original position. Is it normal or something is wrong ? HW ? or sw calibration ?
thanks
Jaro
http://www.youtube.com/watch?v=tk-vP...ature=youtu.be
The problem is in the calibration of the accelerometer.
Open the accelerometer application and go to the pull down menu help.
Follow the instructions. this will solve you're problem!
If not, contact me via YouTube or rcgroups.
Sjb
sjb_rc is offline Find More Posts by sjb_rc
Old Jan 02, 2013, 06:45 PM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Jaro,
I had most if not all the problems others had with this project but eventually got them sorted. Search this thread for all my comments and you probably find the answers you need.
A.
AndyOne is offline Find More Posts by AndyOne
Old Jan 02, 2013, 10:43 PM
P.I.Engineer is online now
Find More Posts by P.I.Engineer
P.I.Engineer's Avatar
United States, WA, Maple Valley
Joined Mar 2005
my z-axis accel cal is at like 2192 or 1904, is there any way to fix this? Or do i have a garbage sensor board?
P.I.Engineer is online now Find More Posts by P.I.Engineer
Old Jan 03, 2013, 12:08 AM
krise is offline
Find More Posts by krise
also known as ke123
krise's Avatar
Canada, AB, Edmonton
Joined Dec 2007
Just a clarifying note for someone wiring this button like me: this is not Pin 11 (D8) as in the arduino pin diagram that comes up when you google "arduino nano pins", this is pin D11 that must be connected to ground to set center.
BTW thanks Dennis this headtracker works awesome!
Originally Posted by Dennis Frie View Post
Always good to know to obvious things I haven't documented good enough... Documenting is not really my strong side.
Reset shouldn't be necessary - at least quite a few people have been able to make it work pretty good without drift.
Anyway, if you ever need to reset center, it's a lot better to connect a button between to be used as "set center".
The pin is defined in config:
// Button input:
#define BUTTON_INPUT 11
Just connect a button between the pin defined (in this case 11)) and ground. Will make it center immediately with no start-up delay
krise is offline Find More Posts by krise
Old Jan 03, 2013, 05:47 AM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
It's a good idea to have a reset switch because if you switch on the tracker when facing the wrong way, you don't have to pull the plug and fumble it back in whilst wearing the goggles.
A.
Old Jan 04, 2013, 09:41 AM
piotrek.zet is offline
Find More Posts by piotrek.zet
Poland, Swietokrzyskie, Starachowice
Joined Feb 2011
Hello friends.
Awesome design - Big Thank creators!
I would like to present my Fatshark BASE goggles modification:
On the left I installed - AV Receiver 5.8G Video Receiver Set for FPV system + Dip swich changing channels
On the right I installed my HT (ArduinoProMini), and with the hotglue. + My diy 6pin socket 232 HT programming
Equipment I use Turnigy 9x + soft ER9x
To send the wireless signal PPM - Fatshark <> Turnigy, I used the TX + RX modules 413Mhz - TX5 in Fatshark + RXB14 Turnigy receiver.
HT reset swich on the right.
PPM signal can be transmitted via a cable - plug Futaba Micro Audio Video
the entire modification process Fatshark Baseyou can see in the gallery , or a fraction of the photos below:
RF-modules PPM Link tested - work with FrSky 2.4Ghz and Rimelec LRS 433MHz
Edit:
Mod in turnigy9x:
Greetings from Poland
PROFESOR
rc-fpv.pl
piotrek.zet is offline Find More Posts by piotrek.zet
Old Jan 04, 2013, 09:45 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by piotrek.zet View Post
Hello friends.
PROFESOR
rc-fpv.pl
Wow, that looks pretty "brave"
Very nice done.
You mentioned PPM link was tested. Do you use PPM-read and PPM-generate to put headtracker-channels on extra channels? It should work just fine, bit I haven't heard anyone else actually use it.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Jan 04, 2013, 10:09 AM
Joined Feb 2011
Thanks, it was a little work on the goggles .
HT generates a PPM-out - only 3 channels PPM - so much need for ER9x
Mixer in ER9x does the rest.
mixes on channel 5 - PPM1, 6 - PPM2, 7 - PPM3
Wireless Link RF513Mhz tested previously tested FrSky2.4GHz - here you have a video:
OpenHeadTracker Test #2 (2 min 56 sec)
Tests HT - in the Air soon - as soon as the weather improves with us!
Old Jan 04, 2013, 10:27 AM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
"Neat" 9x installation completed;
I wouldn't recommend using a jack, I plugged it in with the radio on and managed to short the 12v supply despite having it at the tip of the plug. Now I have replaced 3 burnt tracks in the radio and need to buy a new SmartieParts board
Now know not to do this when the radio is powered. I'll change it to 5pin DIN one day
cheers
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Jan 05, 2013, 12:48 AM
EngineerX is offline
Find More Posts by EngineerX
☢ Self-Proclaimed n00b FPVer ☢
EngineerX's Avatar
Joined Sep 2012
Very nice! I would like to see what parts you used for your RF513MHz wireless link. Do you have a web link or thread where you show info about the wireless link?
EngineerX is offline Find More Posts by EngineerX
Old Jan 05, 2013, 06:09 AM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Yesss :D
Hi Dennis,
now I have a full working drift free headtracker : so happy.
It was so easy to setup and configure, with working hardware.
Electronics were ordered from Goodluckbuy this time.
Thank you very much.
Now I have to solve the annoying problem with the stretcher.
What about developing a working one ?
Has anyone some suggestions about a good solution ?
I should try to stay at low tx throws, to avoid sync problems with Sherrer LR RC system.
Best regards,
Ric
chiloschista is offline Find More Posts by chiloschista
Old Jan 05, 2013, 06:18 AM
LKJ is offline
LKJ
Find More Posts by LKJ
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
Originally Posted by chiloschista View Post
Hi Dennis,
Best regards,
Ric
Buy a servo hvo can do what you want, they run smooth stretchers usually have to low resolution.
Hyperion Atlas digitals can do 170 and work smooth, i use them on pan.
Lars.
LKJ is offline Find More Posts by LKJ
Old Jan 05, 2013, 06:53 AM
Switzerland
Joined Feb 2008
Lars.
A programmable servo, yes, good idea.
Ric
Old Jan 06, 2013, 02:46 PM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Hi Dennis,
Best regards,
Ric
MD260 servo can do over 180 degrees without any modification. Its 12 grams, not perfectly smooth but the price is right.
hefest is offline Find More Posts by hefest
Old Jan 06, 2013, 04:48 PM
Switzerland
Joined Feb 2008
Good catch, thanks.
Does it reach 180 with standard 1100-1900us pulse (+-100%) ?
Specs say it can reach 260 and deadband is less than 4us, which should mean a good precision.
In the meantime I swapped the old HS81 with an HS225. HS81 was no more centering. I had several of those with this issue. HobbyKing D-MG16 are way better and cheaper.
Ric
Build Log Diy osd (Arduino and opensource) Dennis Frie FPV Equipment 2504 Jun 28, 2016 03:21 PM
Discussion PPM to PWM circuit for headtracker 38cjc38 DIY Electronics 18 Mar 04, 2011 06:43 AM
Question Adding additional PPM inputs to a headtracker/module setup. SebastianJ FPV Talk 0 Aug 19, 2009 07:38 AM
Question Adding additional PPM inputs to a headtracker. SebastianJ DIY Electronics 0 Aug 18, 2009 03:37 PM
