Old Nov 28, 2012, 06:06 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
hfest,
Did you try loading the simple LED flasher demo into the Adduino to check it that way.
I bought both boards from Goodluckbuy because there were problems between DX and Paypal, no problems with the ones from GLB apart from the 3 week delivery time.
A.
AndyOne is offline Find More Posts by AndyOne
Old Nov 28, 2012, 07:03 AM
XDreamer is online now
Find More Posts by XDreamer
Joined May 2010
Isn't it time to remove the links to DX.com from the first page? The hardware from DX is cheap, but it seems only 50% of the units work as they should.
I spent several days trying to get my DX Arduino and GY85 to work, but never succeeded. The hardware from Goodluckbuy worked right away. Of course I might have been lucky...but I think the price difference really gets you better hardware.
XDreamer is online now Find More Posts by XDreamer
Old Nov 28, 2012, 08:12 AM
Gabek is offline
Find More Posts by Gabek
Gabek's Avatar
Magyarország, Baranya, Pécs
Joined Feb 2008
Hi,
I bought it from DX also, but my did work well, and still does.
Keep in mind that this board comes without boot loader for sure:
Link
I had to borrow a Usbasp to burn bootloader.
And i bought this sensor: Link
Gábor
Gabek is offline Find More Posts by Gabek
Old Nov 28, 2012, 08:17 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Originally Posted by AndyOne View Post
hfest,
A.
Well, no bootloader==no possibility to upload anything.
Flashing new bootloader via ICSP also failed.
hefest is offline Find More Posts by hefest
Old Nov 28, 2012, 08:19 AM
Gabek is offline
Gabek's Avatar
Joined Feb 2008
Did you use arduino, to upload boot loader, and selected right board?
Old Nov 28, 2012, 08:20 AM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Tried using arduino, but the thing is OS is reporting broken USB device, both Linux and Windows.
Old Nov 28, 2012, 08:25 AM
Gabek is offline
Gabek's Avatar
Joined Feb 2008
Ok.
Just to make sure. Did you try to upload bootloader trough the boards own port?
I am asking, because that is not possible.
By FTDI you simply can't.
You need an external 6 pin (or a 10 pin if you know how to connect it) AVR programmer.
I think the cheapest way is this: Link
Gábor
Old Nov 28, 2012, 08:27 AM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Ok.
Gábor
Yes, i have exactly that AVR programer and tried flashing bootloader with it with no luck, OS is reporting broken USB device.
Poweron led turns on, the rx led flashed red few times and that's it.
I didnt check pin-by-pin 6pin cable and connections on Arduino Nano DX clone if those are aligned correctly.
Old Nov 28, 2012, 08:36 AM
Gabek is offline
Gabek's Avatar
Joined Feb 2008
Well if you power it trough AVR programer than usb connection does not matters as it is not even connected.
Than if boot loader burning goes well than you can try. If still the same error, try this:
connect the USB cable to the board, than hang it on the wire, so the board will not touch a thing. Than connect it to the computer.
Also try more than one cable if you have.
This board is very sensitive.
Old Nov 28, 2012, 08:38 AM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
Hello,
just seeing if anyone has one for sale or will make me one for a Futaba 9c.
you can send me a PM.
Thanks G
G-unit is offline Find More Posts by G-unit
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
I did try several different USB cables and holding it away from everything to avoid shorting out and similar with same results.
Old Nov 28, 2012, 08:46 AM
Gabek is offline
Gabek's Avatar
Joined Feb 2008
But did boot loader take?
Also my is interfering with 72 Mhz. when my transmitter was on i had the same error.
I had to use shielded cables.
Now it works as it should.
Just ordered an LRS modul Will see what happens
Old Nov 28, 2012, 11:20 AM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
Originally Posted by G-unit View Post
Hello,
Thanks G
Even if you bought the NDHT ready-made you would still have to calibrate it in place on your video-goggles because of their magnetic field.
A.
Old Nov 28, 2012, 12:08 PM
G-unit is offline
G-unit's Avatar
AZ
Joined May 2006
A.
Yes i understand that,
but thanks for the info.
Old Nov 28, 2012, 10:49 PM
capn is offline
Find More Posts by capn
United States, CA, San Diego
Joined Sep 2005
FYI:
I was just able to build a third, perfectly functioning headtracker. The key is to keep the gy-85 separate from the arduino with a length of wire and to calibrate the magnetometer by holding the sensorboard with the components up in the first step instead of down as they are shown in the GUI.
I tried using the exact same components in another headtracker earlier without success. I was having a constant twitching of the servos along with pan returning to zero. I decided to try again using the techniques that I described above and it worked beautifully.
I used components that were purchased from three different vendors to build each of the three headtrackers, though none were from DX.
capn
capn is offline Find More Posts by capn
Build Log Diy osd (Arduino and opensource) Dennis Frie FPV Equipment 2474 Yesterday 04:23 PM
Discussion PPM to PWM circuit for headtracker 38cjc38 DIY Electronics 18 Mar 04, 2011 07:43 AM
Question Adding additional PPM inputs to a headtracker/module setup. SebastianJ FPV Talk 0 Aug 19, 2009 08:38 AM
Question Adding additional PPM inputs to a headtracker. SebastianJ DIY Electronics 0 Aug 18, 2009 04:37 PM
