Old Nov 23, 2012, 03:28 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
As you have noticed, when using 100 % gyro weight, the gyro is pretty accurate on it's own. The difficult part is the magnetometer that's pretty damn sensitive to noise, current from wires etc. Unfortunatly some drift will always occur on the gyro, which have to be accounted for. 99% gyro-weight should be fine.
Pick whatever works best for you, but be aware that 0% = only magnetometer and 100% = only gyro. For tilt/roll 0 % = only accelerometer.
Dennis Frie is offline Find More Posts by Dennis Frie
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
OK in a nutshell, here's what I learnt the hard way.
1 Most importantly, the sensor board MUST be located component side up and not as in the magnetometer cal screen.
2 On the GIU screen click on "show" menu and select advanced settings. in the top right hand corner some adjustment of the "gyro weight on pan %" may be necessary, 99% seems best.
3 In the accelerometer cal screen click on "help" menu and select help/how to, to see exactly how to position the sensor for calibration.
4 Regular resetting of the Arduino by pressing the on-board reset button seems to help
5 Select disconnect when exiting a calibration screen to release the serial link so it can be used by another cal screen.
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Nov 23, 2012, 03:34 PM
Just another user
Joined Feb 2011
Andy.
Always good to know to obvious things I haven't documented good enough... Documenting is not really my strong side.
Reset shouldn't be necessary - at least quite a few people have been able to make it work pretty good without drift.
Anyway, if you ever need to reset center, it's a lot better to connect a button between to be used as "set center".
The pin is defined in config:
// Button input:
#define BUTTON_INPUT 11
Just connect a button between the pin defined (in this case 11)) and ground. Will make it center immediately with no start-up delay
Old Nov 23, 2012, 06:34 PM
how_eee is offline
Find More Posts by how_eee
Узбекистан
Joined Mar 2007
Thank you so much! In few last posts I found almost all answers for my quetions and misunderstandings.
Last one - components up during mag calibration?
how_eee is offline Find More Posts by how_eee
Old Nov 23, 2012, 07:48 PM
primestick is offline
Find More Posts by primestick
United States, MN, Bloomington
subscribed
primestick is offline Find More Posts by primestick
Old Nov 24, 2012, 12:47 AM
P.I.Engineer is offline
Find More Posts by P.I.Engineer
P.I.Engineer's Avatar
United States, WA, Maple Valley
Joined Mar 2005
did mine up today, that was super easy.
thanks for all the work.
P.I.Engineer is offline Find More Posts by P.I.Engineer
Old Nov 24, 2012, 04:43 AM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
I wish mine had been easy, I did learn a lot in the process though.
A.
Old Nov 25, 2012, 12:09 AM
Joined Mar 2005
check that, did some more testing.
my tilt works perfect, my pan, not so much.
when i pan, it pans but then moves back to center on it's own.
It shows the same thing happening on the plot.
it appears from the mag cal .exe that all the sensors are outputting correctly. So now i'm confused
Edit: just searched this thread, i'm not the only one with this issue.
Old Nov 25, 2012, 02:48 AM
how_eee is offline
Узбекистан
Joined Mar 2007
Did you calibrate mag as shown in pictures?
try to calibrate it inverted, first 2 pictures componets up.
Old Nov 25, 2012, 04:17 AM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
Drifting back to centre is what happens if the board is upside-down.
A.
Old Nov 25, 2012, 05:49 AM
Gabek is online now
Find More Posts by Gabek
Gabek's Avatar
Magyarország, Baranya, Pécs
Joined Feb 2008
A.
Or if the endpoint is too high!
Gabek is online now Find More Posts by Gabek
Old Nov 25, 2012, 09:52 AM
Joined Mar 2005
which way is up?
sensor board up or usb up?
Old Nov 25, 2012, 10:05 AM
LKJ is offline
LKJ
Find More Posts by LKJ
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
which way is up?
USB is on the controller board and it doesn't care, its is the sensor board vho need to have the component side up.
Lars.
LKJ is offline Find More Posts by LKJ
Old Nov 25, 2012, 10:06 PM
Joined Mar 2005
yeah, that's the way i have it, still drifting.
I'll mess with it more this week.
Old Nov 25, 2012, 11:29 PM
vpb is offline
vpb
Find More Posts by vpb
vpb
Joined Jun 2012
Has anyone try Dennis Frie code on crius se board?
vpb is offline Find More Posts by vpb
Build Log Diy osd (Arduino and opensource) Dennis Frie FPV Equipment 2497 Apr 27, 2016 01:59 AM
Discussion PPM to PWM circuit for headtracker 38cjc38 DIY Electronics 18 Mar 04, 2011 06:43 AM
Question Adding additional PPM inputs to a headtracker/module setup. SebastianJ FPV Talk 0 Aug 19, 2009 07:38 AM
Question Adding additional PPM inputs to a headtracker. SebastianJ DIY Electronics 0 Aug 18, 2009 03:37 PM
