I decreased the gain on pan tilt and roll to 100 each but it's still the same. What do the other adjustments do...
End-> and End<- And how do the centering controls do anything different to resetting the Arduino on the reset button. There's a lot I don't understand about this project, this is becoming more and more obvious, may be I should read through the entire thread again to see if there's anything different I can do. |
![]() Yes you can use rest to center it , but Dennis made a fast switch for that. Also don't forget to press "set offset to 0" button before recalibrating. I am kind of new to this just as you. There must be someone more exprianced here to help you out. ![]() My HT worked for the first time, so i did not go deep.... Did you read help, in the config tools? Gábor |
Sorry guys, I have been crazy busy lately and also have a few other projects, that I would love to get done.
It seems like the calibration-procedure and faulty hardware have been causing some problems. A few notes... - The calibration don't have to be done in any specific order - Magnetometer calibration should be more or less self-explaining from the pictures. It's a bit misleading that the headtracker is turned upside-down on the pictures, but it doesn't matter for the purpose of calibration. It's recommended to keep a good distance from anything metal (mobile-phones are also a bad idea to have nearby), but as it only accounts for offset with this procedure, it shouldn't matter too much (the gain as calibrated with some self-test) - The accelerometer calibration is different from the magnetometer-calibration. The procedure is found in "Help -> How to" (year, it's well hidden).. Now, for the sake of calibration. When doing a new calibration, it's important to press "Set offset to 0". Make the necessary measurements, and press save. When this is done, you can check the calibration-data. Don't press "set offset to 0", but just repeat the measurements. The result should be very close to x, y and x offset at 0. If this is true - the offset have been set right Quick GUI explanation PPM channel Controls the channel that pan, tilt and roll is assigned to. Servo Center: Sets the center-position of the servo. End -> Left (or right) servo end position End -> Right (or left) servo end position Gain Controls the necessary head-movement to control the servo. The default should be close to 1:1, but most people probably like a little higher gain to get more servo-movement with less head-movement. Reverse: Simply check the box to reverse servo-movement for the channel. Advanced settings Most people don't have to adjust any of the advance settings, but they do give some more options if needed... LP filter at tilt/roll/pan The software includes a lowpass-filter to remove noise etc. As the headtracker uses quite high update-rate, the default 75 % value is almost not noticeably. Low value will give very smooth movement, but very slow response. Gyro weight. This value describes how much we thrust the measurement from the gyro. The best sensor to measure head-movements is the gyro, but unfortunately it drifts. To account for the drift we use magnetometer for pan, and accelerometer for roll and tilt. The value is simply a weight-factor describing how much we thrust the gyro. The default 98% means 98% of the next position estimation is calculated based on gyro, and the last 2% is used from accelerometer or magnetometer to account for drift. Servo parameters... Servo-center describes the pulse-width in the unit uS/2. Travel adjust min and max describes how much the pulse can vary from the center-position. Be aware that the normal settings will keep a maximum and minimum pulse-time, while these settings will allow anything. |
![]() Quote:
Did I read somewhere that the sensor board should have the components at the top.
I have my board mounted as in the picture in the magnetometer cal screen, I assumed this to be OK but it seems at odds with original statement as it clearly shows the top (component side) of the sensor board as at the bottom. A. |
| Thread Tools | |
| Build Log Diy osd (Arduino and opensource) | Dennis Frie | Video Piloting (FPV/RPV) | 2278 | May 10, 2013 09:31 AM |
| Discussion PPM to PWM circuit for headtracker | 38cjc38 | DIY Electronics | 18 | Mar 04, 2011 06:43 AM |
| Question Adding additional PPM inputs to a headtracker/module setup. | SebastianJ | Video Piloting (FPV/RPV) | 0 | Aug 19, 2009 07:38 AM |
| Question Adding additional PPM inputs to a headtracker. | SebastianJ | DIY Electronics | 0 | Aug 18, 2009 03:37 PM |
