A few have asked for the GUI-code. It was never the plan to release it (mainly as it's a bit messy and not coded very well), but as I'm too busy to keep things updated.. oh well
https://dl.dropbox.com/u/3947315/HeadTracker_GUI.rar |
Detroit
Joined Sep 2005
Dennis,
How much is involved in making the code work for the sparkfun 9DOF stick ( https://www.sparkfun.com/products/10724 )? If I were to buy one and send it to you could you update the code for it? capn |
Joined Sep 2011
Hi Guys
Someone suggested that the Arduino Nano needs to separated from the GY-85 IMU Sensor Module because of noise. Still no luck. Cheers Jason
Joined May 2010
Do you plan on implementing a Read button in the GUI? When adjusting the settings in the GUI it's easy to forget what you entered last time. Or is it already there? I might be missing something. If it's not there, it should "just" be a matter of sending a $Debug to the serial port and parsing the answer. |
Maybe a suggestion for a new project:
A small 433MHz RF beacon on arduino based: which has an input for various GPS (i mean it does understand different baud, update,.. settings, so we can use the GPS we use for the OSD) and a small arduino with LCD for the ground station to see the coordinates. I know that similar projects do exists, but no ones based on the simple arduino boards. ;-) |
Danmark, Midtjylland, Galten
Joined Oct 2011
You can do it with the cheap USBasp from HK: http://www.hobbyking.com/hobbyking/s...occessors.html And it's in stock right now. |
My friend has one, and the boot loader is uploaded now. But! I seam to have strong interference from 72 mhz! So the tracker stops working. No reaction at all. When i remove 72 mhz modul than it works as it should. I will try to use shielded cables. Will see what happens.... Anyone had similar problem? Gábor |
Detroit
Joined Sep 2005
Just an FYI,
I was able to get a second tracker working well. Testing it without heatshrink on the sensorboard (the gy-85 is mounted remote from the arduino with about 1meter of cable) it worked perfectly. The graph in the GUI responded as it should, so I decided to shrinkwrap the sensorboard to protect it. After I got done, I tested it again and the pan was returning to zero and it was behaving poorly. I removed the heatshrink and situated the wires away from the top of the sensor (I heatshrinked the wires on top of the sensorboard in order to make the whole thing neater and smaller). After clearing the wires away from the sensorboard, the tracker began working well again. I could make the graph show bad behavior simply by moving the wires back and forth over the sensor as it sat motionless. I don't know if it's the fault of the wire I used (an old wired mouse's cable) or if the board is just sensitive. I reapplied the heatshrink, this time making sure the wires ran at the edge of the board, away from the components on its top and all is well again. capn |
| Thread Tools | |
| Build Log Diy osd (Arduino and opensource) | Dennis Frie | Video Piloting (FPV/RPV) | 2278 | May 10, 2013 09:31 AM |
| Discussion PPM to PWM circuit for headtracker | 38cjc38 | DIY Electronics | 18 | Mar 04, 2011 06:43 AM |
| Question Adding additional PPM inputs to a headtracker/module setup. | SebastianJ | Video Piloting (FPV/RPV) | 0 | Aug 19, 2009 07:38 AM |
| Question Adding additional PPM inputs to a headtracker. | SebastianJ | DIY Electronics | 0 | Aug 18, 2009 03:37 PM |
