Old Jun 29, 2012, 06:49 PM
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by LKJ View Post
Thanks for the help.
By the way, servo center fit nerly perfekt vith 2220.
Lars.
No problem, always nice with some FPV talk etc.
I feel pretty sure 2220 is off center on my transmitter - but as everyone can just set the center-position matching the transmitter it shouldn't matter.
Have you checked that the servo can move 100% in each direction? If the center-position is not set correct, and/or the travel-adjustment (in your program called "servo pulse variation") is too high, the transmitter will ignore the pulse and center the servo in case you move it too much.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Jun 29, 2012, 07:21 PM
Joined Feb 2007
Hi Dennis,
Great project! I've seen futaba squere socket on your photo, should i use only 3 pins: GND (pin 2), Signal In (pin 5) and +V switched (pin 6) to get it worked with my T8FGS? No PPM out (pin 3) needed?
Which pins on IMU side are Yellow and Green? On arduino side Yellow=A5 and Green=A6, what about IMU?
Cossacs is offline Find More Posts by Cossacs
Old Jun 29, 2012, 07:30 PM
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
AAAaaa it just did that for me when i moved/turned the HT far to far in pan, now i lerned some more today.
I wil look ind to that tomorrow.
Lars.
LKJ is online now Find More Posts by LKJ
Just another user
Joined Feb 2011
Originally Posted by Cossacs View Post
Hi Dennis,
I only use GND, signal in and +V swithced atm. That's all you need for the headtracker.
PPM out is just for the PPM expansion part - but that's not quite done yet.
Old Jun 29, 2012, 07:36 PM
Just another user
Joined Feb 2011
Lars.
Well, at least you know the reason
If you wasn't experiencing that before, I would expect, that the center-position was actually set right before. When you where comparing with the potentiometer on the transmitter, have you checked in the servo-menu that it was actually in neutral?
Old Jun 29, 2012, 07:42 PM
Joined Feb 2007
Cool, thanks
Just to clarify regarding IMU to Arduino connection, SDA=A5 and SCL=A6?
Old Jun 29, 2012, 07:49 PM
LKJ
Lars k Jensen
Joined Apr 2006
I think i controlled this when i made the setup and will recheck tomorrow, but there are week knots in the pots so they have somewhat locked positions/steps, therefor i can not make both pan and tilt neutrals 100% perfect at one time, one of them will always move just a little, the new programming tool you made where each servos neutral and individual end positions can be set will cure that.
Lars.
Old Jul 01, 2012, 05:32 PM
Just another user
Joined Feb 2011
Cool, thanks
No, it's:
SDA = A4
SCL A5
Old Jul 02, 2012, 04:05 PM
Just another user
Joined Feb 2011
Guess it's time for a little update.
Anything missing in the headtracker part except a button to "reset"?
Code updated at:
http://code.google.com/p/open-headtracker/
please note that magnetometer min/max value must be calibrated manually atm for best performance. I'll write a little tool to help getting this done later.
Old Jul 02, 2012, 04:26 PM
Joined Sep 2010
So whats next after the headtracker?
I'd like if you made an arduino transmitter
That would be a suitable challange for your skillz
msev is offline Find More Posts by msev
Old Jul 02, 2012, 05:10 PM
Just another user
Joined Feb 2011
I don't really have any plans for new FPV-projects, but good ideas are welcome (have a few other projects, but not related to FPV)
I'm not quite sure what you mean by "Arduino transmitter"?. OpenLrs should be a good place to start if you want to play with OpenSource RC-link.
Old Jul 02, 2012, 06:17 PM
Aviation industry participant
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
So is anyone building one of these? I'm quite excited, as I've been looking to add headtracking to my FPV expreience for ages, but have been put off by the limitations of the commercial systems.
I have managed to build my own multicopter controller board based on the Arduino, wii motion plus and nunchuck before. Do you think I could handle this? Is there anything I need to be especially careful of?
Sub.
subsonic is offline Find More Posts by subsonic
Old Jul 02, 2012, 06:23 PM
Santo Domingo, Dominican Republic
Joined Mar 2007
Dennis is in a much better position to answer this, but after building his DIY OSD this weekend in about 15 minutes, I can tell you Im amazed by the simplicity and reliability of his systems.
I built it in a breadboard and am waiting for the proto board so I can solder it and mount it on an aircraft. You should be fine!
OrlandoP is offline Find More Posts by OrlandoP
Old Jul 02, 2012, 07:48 PM
HOL
Danmark, Midtjylland, Galten
Joined Oct 2011
High end OpenSource RC transmitter is to be found here:
http://www.os-rc.com/
But unfortunately a little more costly than the arduino . But with "built-in" FPV options.
HOL is offline Find More Posts by HOL
Old Jul 03, 2012, 01:14 AM
Just another user
Joined Feb 2011
Sub.
Year, you should be finem the hardware is very easy
The board can be directly mounted on Arduino Nano's pins (will upload picture when I get it done) and you just need 3 wires to transmitter.
The GUI etc. should be straight forward.
It's still one of the early software versions - but I don't think much will be changed, as it works pretty well.
*I have just changed the title of the thread, should match better.
Build Log Diy osd (Arduino and opensource) Dennis Frie Video Piloting (FPV/RPV) 2282 May 23, 2013 09:34 PM
Discussion PPM to PWM circuit for headtracker 38cjc38 DIY Electronics 18 Mar 04, 2011 06:43 AM
Question Adding additional PPM inputs to a headtracker/module setup. SebastianJ Video Piloting (FPV/RPV) 0 Aug 19, 2009 07:38 AM
Question Adding additional PPM inputs to a headtracker. SebastianJ DIY Electronics 0 Aug 18, 2009 03:37 PM
