Old Jun 27, 2012, 04:35 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
I mean using arduino as a ppm generator for using different controller peripherals such as a nunchuck with its buttons, acc & mini joystick.. And using / interfacing a gameport joystick.
msev is offline Find More Posts by msev
Old Jun 27, 2012, 04:50 PM
Dennis Frie is online now
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by LKJ View Post
Dennis are you sure i can plug the HT in both USB and my F9 on the same time, i get light in the red light diode on F9 with out turning F9 on, i am afraid to push 12V back in the USB and let the smoke out somewhere.
Lars.
I just tested with a 12-20 volt supply at Vin to be completely sure. No problems at all. They will share the same 5-volt rail (usb and regulator), but you should not get any "high voltages" into your pc etc. Not perfect, but shouldn't cause problems. The LED you see turn on at your transmitter is caused by a low voltage (~1.6 volt) that can be seen at the other side of the regulator while powered with USB.
As always, it's on your own risk - but you should be fine
I have to defend my bachelor thesis in 9 hours, so I'll try to get some sleep.
Dennis Frie is online now Find More Posts by Dennis Frie
Old Jun 27, 2012, 04:54 PM
LKJ is offline
LKJ
Find More Posts by LKJ
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
Just wanted the smoke staying on the right place for tomorrow.
Good luck tomorrow.
LKJ is offline Find More Posts by LKJ
Old Jun 28, 2012, 10:09 AM
Just another user
Joined Feb 2011
Good luck tomorrow.
I got the best grade possible, so can't really complain .
The calibration for the magnetometer was done yesterday and should be ready. The gain is calibrated automatically with the self-test function, but the offset have to be set manually.
Old Jun 28, 2012, 01:57 PM
LKJ is offline
LKJ
LKJ
Lars k Jensen
Joined Apr 2006
Got nearly 2 houers flying with DFHT to day, one of them was a 1 houer long thermal flight, absoluteley no drift at all
It just works with no fuss, i have problems with pogramming new centerposition, the tracker just do`nt react on changes, so i was just flying it the way it was out of the box.
I am shure it is just a minor problem soon fixed.
First time flying in 5 years with HT with no need for anny inflight reset neded.
So wel done Dennis.
Lars.
Old Jun 28, 2012, 02:47 PM
msev is offline
Joined Sep 2010
Well done Dennis! What about my question about joystick or nunchuck interfacing?
Old Jun 28, 2012, 03:59 PM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
Good luck tomorrow.
You can use a USB cable with cut power line.
or if using an Ardunio Pro Mini:
a FTDI adpater without +5V connected.
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old Jun 28, 2012, 05:39 PM
Just another user
Joined Feb 2011
All the PPM-output is already done, so you can basically just add the sensors you want
I don't plan to write support for wii-controllers etc. but it should be pretty easy to add other devices.
If you just want a device to be used with wii controller I would suggest the one from Flytron:
http://flytron.com/open-source-hardw...lus-board.html
Old Jun 28, 2012, 05:43 PM
Just another user
Joined Feb 2011
So wel done Dennis.
Lars.
Sounds very nice - I'm glad to hear it's a success so far.
I'll help you setup the tracker one of the next couple of days, should be pretty straight forward
The calibration of the magnetometer should improve the pan a bit for perfect match between gyro and magnetometer readings.
Old Jun 29, 2012, 09:08 AM
Just another user
Joined Feb 2011
You mentioned a few extra options to be able to adjust the servo-travel in all directions etc. Consider it done
Quite a lot of extra code have been added to allow everything to be saved in EEPROM and configured by GUI - but it seems to work just fine
I'll consider adding a single button for easy setup "in the field" and reset neutral position.
Old Jun 29, 2012, 10:30 AM
LKJ is offline
LKJ
LKJ
Lars k Jensen
Joined Apr 2006
looks wery prof Dennis
I will probably be without Internet connection for nearly a week the company vent bankrupt and the new Internet supplier sent me a defect router so when they close the net i use now to morrow night i am dead until the new router arrive by post next week.
Lars.
Old Jun 29, 2012, 03:05 PM
Just another user
Joined Feb 2011
Lars.
No worries, it was nice you was able to test the headtracker so quickly
When you need help with updating the software etc. just let me know
Old Jun 29, 2012, 04:56 PM
LKJ is offline
LKJ
LKJ
Lars k Jensen
Joined Apr 2006
You have mail.
I need to make power to my goggles and was wondering, can DFHT run on 6V i can use a turnigy UBEC on 6V to my goggles so can it feed DFHT to ???
By the way i coated DFHT in flex and it is running quite hot, could smell it when flying.
Old Jun 29, 2012, 06:28 PM
Just another user
Joined Feb 2011
You have mail.
Problem solved per phone - and the GUI have been "connected" as well.
The problem was the Arduino driver that wasn't installed properly
6 volt regulated supply-voltage should be fine.
Old Jun 29, 2012, 06:40 PM
LKJ is offline
LKJ
LKJ
Lars k Jensen
Joined Apr 2006
Thanks for the help.
By the way, servo center fit nerly perfekt vith 2220.
Lars.
Build Log Diy osd (Arduino and opensource) Dennis Frie FPV Equipment 2497 Apr 27, 2016 01:59 AM
Discussion PPM to PWM circuit for headtracker 38cjc38 DIY Electronics 18 Mar 04, 2011 06:43 AM
Question Adding additional PPM inputs to a headtracker/module setup. SebastianJ FPV Talk 0 Aug 19, 2009 07:38 AM
Question Adding additional PPM inputs to a headtracker. SebastianJ DIY Electronics 0 Aug 18, 2009 03:37 PM
