Old Aug 03, 2012, 11:58 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by ABLomas View Post
Please, read my post again.
One board has ITH3200 or ITG3205 as gyro (ITG3205 is a bit worse - it's the same re-marked ITG3200, when they did not pass stright requirements); and another board has L3G4200D as gyro.
Both are written on board description and even in title, i do not know why do you think, that theyre "exact same board".
Year, but I was refering to the original sensor-board compared to this one:
http://www.goodluckbuy.com/nine-axis...3l-module.html
(Original sensorboard used):
http://www.ebay.com/itm/ws/eBayISAPI...E:L:OC:US:3160
As far as I can see they both use same gyro etc. It was only a suggestion to another cheap alternative that looks to be the exact same board as used in this project.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Aug 04, 2012, 03:26 PM
ElectoPete is offline
Find More Posts by ElectoPete
Sweden
Joined Aug 2004
Hello Dennis,
I tested your head tracker, and it works very well - keeping the servos very still - no drifting
I would like to place the gyro board vertically instead of flat. This will allow me to use a smaller flat box to enclose the gyro and Pro Mini inside. And it would be easier to mount it onto the goggles.
Is it much work to change the orientation of the board? (I understand, there are several places in the code that have to be changed )
Regards
Pete
ElectoPete is offline Find More Posts by ElectoPete
Old Aug 04, 2012, 03:39 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
deleted
SpookiePower is offline Find More Posts by SpookiePower
Old Aug 04, 2012, 07:50 PM
Just another user
Joined Feb 2011
Originally Posted by ElectoPete View Post
Hello Dennis,
Regards
Pete
I'm glad to hear it works
I'll consider to add vertical position of the sensorboard as an option, but I have a few other updates that I'll look at first.
I will be home in about a week and release an update sooner or later but the position of the sensorboard probably want be included this time.
Old Aug 04, 2012, 09:13 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Hello Dennis,
Regards
Pete
I just finished building mine as well after the bench test. Mounted up to my goggles and am pleased to say it works excellently well. I need to find a moment to take it flying now.
I struggled to find a way to mount it cleanly so I ended up keeping the sensor board and arduino separate, only connected by a thin 4 wire loom. Might be a solution for you?
subsonic is offline Find More Posts by subsonic
Old Aug 04, 2012, 09:22 PM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
Dennis,
Another great Open Source project and very big thank you to you!
Will this support the MPU-9150? If so, this could turn out to be one of the smallest and best head trackers available. Also, what are your thoughts on using an ATiny as the processor?
Thanks again.
CheckSum is offline Find More Posts by CheckSum
Old Aug 05, 2012, 04:37 AM
eranmutai is offline
Find More Posts by eranmutai
Joined Dec 2010
it works!!!!
eranmutai is offline Find More Posts by eranmutai
Old Aug 05, 2012, 05:22 AM
Just another user
Joined Feb 2011
Originally Posted by CheckSum View Post
Dennis,
Thanks again.
Making the headtracker with an mpu9150 and an Attiny could make it an incredible small and hopefully cheap headtracker in production. Might be worth looking at some of the new microcontrollers with built-in usb for direct USB onboard without FTDI converter etc? A bit more expensive in production, but a lot easier to use.
But no matter what, it will require a custom built print etc. It should be pretty simple and straight forward to design, but if it's with sale in mind, it will require a descent number of devices to get the price down.
I don't mind to help designing and coding, but I have little interest in sale - if that's what you have in mind. It would be very nice, but I prefer to use my time developing instead
If you have any plans to take it further, just let me know. I don't mind to help with the design and the code.
Old Aug 06, 2012, 04:33 PM
Joined Jun 2009
I have just finished my DFHT build and now I'm trying to upload the settings to the DFHT but something does not work right.
When I connected the DFTH to my computer the driver was installed ok. I then opened up Arduino IDE and selected the file DIY_headtracker.ino and the Arduino Nano w/Atmega328 board and then tried to upload. In the end of the upload I receive this message "avrdude: stk500_getsync(): not in sync: resp=0x30". I guess this is some kind of error, but what to do now, I just don't know. I then tried to open up Headtracker_GUI_v0_02.exe and select the COM port I used before, but nothing happens.
Anyone who can help me from here ?
A little update on my problem.
When uploading in Arduino IDE and choosing COM port 3 I get the message "avrdude: stk500_getsync(): not in sync: resp=0x30". But when I select COM port 17 I do not get the message But when I open up Headtracker_GUI_v0_02.exe I can only select COM port between 1 to 10...not port 17
When I press connect, nothing happens, and when I press "start plot" I get this message "$PLST"
- Kim -
Old Aug 06, 2012, 05:11 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Kim,
Change the number of the COM port of your nano arduino in device manager/Ports/COM17(double click) -->port definitions-->Advanced -->choose a free COM port or choose an occupied port that you know you don't use often
jalves is offline Find More Posts by jalves
Old Aug 06, 2012, 06:20 PM
Joined Jun 2009
Originally Posted by jalves View Post
Kim,
I'm not sure exactly what to do - I have opened Device Manager on my computer, but can't find anything about COM ports or Nano Ardunio, if that is what you are telling me to do.
- Kim -
Old Aug 06, 2012, 07:43 PM
Just another user
Joined Feb 2011
In the Gui just delete COMxx and write COM17, thats the quick solution. will consider a smarter com-port selection later.
Old Aug 07, 2012, 01:37 AM
Joined Jun 2009
I'll try that later today Dennis. Thanks
Old Aug 07, 2012, 02:46 AM
pheonix3 is offline
Find More Posts by pheonix3
Perth, Western Australia
Joined Jun 2009
Hello Dennis,
Your creation looks awesome and I would like to order and have a go at producing one.
Quick question though: Once assembled and the current software loaded, would this work with w Turnigy 9x radio running ER9x, or is it only for Futaba radios?
Cheers,
Matt
pheonix3 is offline Find More Posts by pheonix3
Old Aug 07, 2012, 11:10 AM
Just another user
Joined Feb 2011
Originally Posted by pheonix3 View Post
Hello Dennis,
Cheers,
Matt
I don't really know Turnigy 9x, but if it supports a headtracker / trainer mix it most likely works.
You might wanna see if other people have used it with headtrackers and what kind of PPM-signal it will accept.
Build Log Diy osd (Arduino and opensource) Dennis Frie FPV Equipment 2475 Today 06:08 AM
Discussion PPM to PWM circuit for headtracker 38cjc38 DIY Electronics 18 Mar 04, 2011 07:43 AM
Question Adding additional PPM inputs to a headtracker/module setup. SebastianJ FPV Talk 0 Aug 19, 2009 08:38 AM
Question Adding additional PPM inputs to a headtracker. SebastianJ DIY Electronics 0 Aug 18, 2009 04:37 PM
