Old Jun 22, 2012, 08:56 PM
Gregor458 is offline
Find More Posts by Gregor458
Joined Jun 2012
Help!
Skyartec Wasp v3 setup
looking for help with my new helicopter. It is spinning uncontrolably counterclockwise and at one point it was fling forward and to the left slightly. Just hoping for some help I'm new at this. It is a skyartec wasp v3.
Gregor458 is offline Find More Posts by Gregor458
Old Jun 22, 2012, 10:42 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
It sounds like it was not set up, which is not uncommon. That is generally something most experienced pilots ensure before they attempt flight. You need to level your swashplate, level your servo arms, adjust your head travel and pitch, adjust your tail pitch, belt tightness, and generally ensure all parts are tight and have lock-tight where needed. The tail on that model can be especially problematic. It has way too much flex and tends to bind.
If you are new, I would suggest viewing Finless Bob's Trex 450 setup videos over at HeliFreak.com. Not everything will apply to your heli, but enough to give you an idea.
Balr14 is offline Find More Posts by Balr14
Old Jun 23, 2012, 08:22 PM
Joined Jun 2012
Thanks for your help
Old Jun 23, 2012, 10:19 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
If you have specific questions, feel free to ask. But, it certainly sounds like it needs a basic setup first. Yhr bad news is that is not a very durable heli. The electronics are pretty good. The head and tail are fragile. It's more stable and docile than other 250s. I think that's due to the old head design. I have one with many upgrades and it requires constant tweaking.
Old Jun 24, 2012, 08:48 AM
Sirdrnksalot is offline
Find More Posts by Sirdrnksalot
United States, CA, Lancaster
Joined Dec 2011
I also have this copter and mconstantly fighting spin. What. I have found isit is usually the belt is loose or the fly bar paddles aren't level with the rotor blades, just a little twist in the paddles makes a difference and if one is twisted alot from a crash you may not notice but it will not fly
Sirdrnksalot is offline Find More Posts by Sirdrnksalot
Old Jun 24, 2012, 09:08 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
What I eventually did was to buy an 250 kit and use all of the electronics from the Wasp.
Discussion Help, problem with WASP V3 joserm Beginner Training Area (Heli-Electric) 6 Jun 22, 2012 10:40 AM
Question Fltbar setup on Wasp V3 pigs might fly Beginner Training Area (Heli-Electric) 2 Apr 28, 2012 08:56 PM
Mini-HowTo Upgrading Skyartec Wasp V3 FP to V3 CCPM skyartec-usa Skyartec 0 Jun 27, 2009 03:40 PM
Discussion honey bee fp or skyartec wasp v3 fp with brushless and belt drive quadracer111 Micro Helis 3 Mar 17, 2008 04:10 AM
Discussion thinking of buying the skyartec wasp v3 HURON Electric Heli Talk 12 Dec 04, 2007 11:56 PM
