Old Jun 22, 2012, 05:26 PM
AlPackin is offline
Find More Posts by AlPackin
AlPackin's Avatar
United States, CT
Joined Mar 2011
BlueSkyRc Micro Tri-Copter
David was so kind to send me a prototype of his micro tri-copter frame. It goes together really well and in the end was great to fly.
I had a problem along the way because I bought these "great for MR" ESCs from HK and they we're terrible.
http://www.hobbyking.com/hobbyking/s...C_1A_UBEC.html
So anyway, my build uses the openpilot CC FC with a Orange (Spektrum) satellite RX plugged into one of the serial ports. That makes for a really low profile package of FC and RX. I used HK 1811 motors and the finished build uses Proton 10A ESCs. I used a GWS Pico servo on the tail
If you paint the frame like I did make sure you carefully remove the paint from the holes for the tail pivot shaft and the mating surfaces between the tail and the moving tail motor mount.
Servo tape didn't hold the servo rigidly enough so I double wire tied that along with the tape.
AlPackin is offline Find More Posts by AlPackin
Old Jun 22, 2012, 05:28 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
Here is how it flew on the HK ESCs
NutsOn3S (0 min 30 sec)
Old Jun 22, 2012, 05:29 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
and here's how it flew with the Protons
MicroTri2 (1 min 45 sec)
Old Jun 22, 2012, 06:41 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Thanks to AlPackin for helping beta test the kit. I did my beta using the Bob's Super Simple Shield (MultiWii). The kits will be listed for sale on BlueSkyRC.com today or tomorrow.
I am using:
1810 Motors
Gemfan 5030 x 3blade props
MultiWii
500mAh 3s pack
FrSky Rx
Here is my first flights.
Micro Tricopter by BlueSkyRC (1 min 30 sec)
Qrome is offline Find More Posts by Qrome
Old Jun 22, 2012, 08:10 PM
Terrier is offline
Find More Posts by Terrier
Dawg, Junkyard, 1 ea.
Terrier's Avatar
United States, TN, Nashville
Joined Feb 2012
I gotsta have it!
I've only had the parts on hand, waiting for its release, for about two months now...
Looking forward to making it fly.
Terrier is offline Find More Posts by Terrier
Old Jun 22, 2012, 09:36 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
Ok, the kits are listed.
http://www.blueskyrc.com/index.php?m...products_id=56
The kits include:
  • Plywood parts
  • Aluminum Hinge Tube
  • 8 Nylon Bolts
  • 8 Nylon Nuts
  • 4 Nylon risers
  • Printed Assembly Instructions
Thanks for those that have been patient over the months. I didn't want to release a Tricopter that was not up to snuff -- getting the tail hinge is key and many fail there. Probably one of the reasons you don't see many Tricopter kits.
Big thanks to those that kept pushing and to Ed for helping test with the CopterControl board.
Old Jun 22, 2012, 10:02 PM
Terrier is offline
Terrier's Avatar
Joined Feb 2012
Got my order in...
Old Jun 28, 2012, 09:02 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
I had a great time flying the little tri today, it's so maneuverable ... I'm going to jack up the max stick angles and see if I can flip it
MicroTri3 (2 min 15 sec)
Old Jun 28, 2012, 09:08 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
AlPackin -- very nice. You will be able to flip it for sure.
Old Jul 03, 2012, 11:46 AM
Knighthawk517 is offline
Find More Posts by Knighthawk517
Joined Jul 2010
Hi AlPackin,
I like the connector you have on the servo that connect to the pin. Where can i get that part?
Knighthawk517 is offline Find More Posts by Knighthawk517
Old Jul 03, 2012, 12:44 PM
bluescrn is offline
Find More Posts by bluescrn
bluescrn's Avatar
Joined Jul 2008
D
Argh, I've just ordered a set of these, was hoping I'd get better stability out of them than my 10A Hobbywing Funflys (Silabs version) that I've got at the moment (currently in a Micro V-Tail, but I've got a Tri frame on order) - but it sounds like they're going to be worse..
Is there a reliable list anywhere of which ESCs are/aren't good for multicopters? (Or which ESCs are rebranded versions of the same thing, as that adds a lot of confusuion!)... I did find the list of SimonK-firmware-compatible ESCs, but most of the lower-amperage models aren't SimonK-compatible, and there's no comments on whether they're multicopter-friendly...
bluescrn is offline Find More Posts by bluescrn
Old Jul 03, 2012, 12:52 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
Apparently these can be flashed with Simon-K firmware
Old Jul 03, 2012, 01:10 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
Originally Posted by Knighthawk517 View Post
Hi AlPackin,
you mean between the servo arm and the linkage wire? I think I got them from my LHS. I'll look around
Old Jul 03, 2012, 01:31 PM
AlPackin is offline
AlPackin's Avatar
United States, CT
Joined Mar 2011
ok here is a link to a similar servo horn connector
http://shop.dubro.com/products/produ...5.0.0.0?pp=12&
Old Jul 03, 2012, 10:50 PM
Joined Jul 2010
Thanks AlPackin!! yes, that is the part I have interest.
New Product BlueSkyRC Micro VTail - Grasshopper Qrome Multirotor Talk 184 Dec 05, 2014 03:29 AM
Question Tri-copter Yaw device... Fingerlessfred Multirotor Talk 1 Jun 21, 2012 01:58 AM
Sold BlueskyRc Micro Spider Hex tmproff Aircraft - Electric - Multirotor (FS/W) 7 Apr 09, 2012 02:54 PM
Sold L@@K - BlueSkyRC micro quad frame Old Blade Man Aircraft - Electric - Multirotor (FS/W) 2 Apr 07, 2012 03:50 PM
Build Log micro tri-copter(for now) bradleyK Multirotor Talk 38 Dec 04, 2010 07:52 PM
