Old Aug 14, 2012, 12:31 PM
Wazmo is offline
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
Originally Posted by ulpilotrmh View Post
I give up. How do I upload multi photos with captions?
Click the Manage Attachments button under the post text box. If it's not there, click the Go Advanced button.
Wazmo is offline Find More Posts by Wazmo
Old Aug 15, 2012, 12:56 PM
awilmunder is offline
Find More Posts by awilmunder
Good for what ALES you
awilmunder's Avatar
United States, CA, Novato
Joined Jan 2009
I had been thinking about trying this approach since there are some benefits. In my GL I have the firewall at the front which could allow the battery to impact the rear of the motor and running the wires past the motor housing is a challenge. Keep us updated.
awilmunder is offline Find More Posts by awilmunder
Old Aug 18, 2012, 07:17 PM
ulpilotrmh is offline
Find More Posts by ulpilotrmh
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
If I were to do this again, I would reduce the depth of the firewall 3/32" to 1/8" at the top edge.The hatch becomes very thin right at the back edge of the firewall and is fragile. I have painted the entire hatch with epoxy and that has stiffened it a lot, but I still worry about it.
In order to mount the motor to the front of the firewall, I pressed the prop shaft thru the motor so it protrudes out the side of the motor opposite the motor mount. I will then plug in the leads to the ESC so the motor runs "backwards."
Another problem was accessing the motor mount screws while the motor is in the plane. I found that I can pull the prop shaft and the spinning part of the motor off the armature (The magnets actually are all that hold the motor together) and that provides just enough space to access the mount screws with the ball end allen wrench.
More to come.
Russ
ulpilotrmh is offline Find More Posts by ulpilotrmh
Old Aug 20, 2012, 08:08 PM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
I got the outer wing panels for the 3 piece wing covered. I used Coverite. I don't know if this is the best for weight but it sure beats the others I've tried as far as ease of application. The other films I've tried have too much of a tendency to stick to themselves. This drove me up the walls on small airframes. Also the clear plastic backing peals off Coverite with ease, I think it's all I'll ever use from now on.
Can someone steer me to a tutorial on posting mutiple photos with captions?
I need step by step instructions.
Russ
Old Sep 10, 2012, 01:36 PM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
Okay, now I have a real problem and really need help. I just recieved the 1500mAh 3S Lipo that was recommended way back when I started on this project. As you may remember, I had moved the firewall back in order to allow the square nose shape to be rounded off to acccomodate the folding prop and spinner. Now that I have the Lipo in hand, I find it is too long by about 1/2".
Before I hang this project in the rafters, Can I go with a shorter 2S Lipo in this plane and expect adequate performance in ALES Comps?
Russ
Old Sep 11, 2012, 10:37 AM
awilmunder's Avatar
Joined Jan 2009
Russ,
My GL is using Turnigy Nano-tech 3S 1300 mAh 45C batteries that are just a shade less than 3" in length. Looking at the standard Turnigy 1500 mAh batteries, they are 107mm, so more than an inch longer than the 1300's. I also use these 1300s in my electric Oly because the voltage drop at full throttle using lower C rated batteries was causing the ESC to cut the motor.
From your earlier photo, these batteries should fit in your bay but you may need to move the RX and ESC back. The smaller batteries wlll result in a lighter plane, so there are other benefits.
Old Sep 11, 2012, 04:13 PM
smoothvirus is offline
Find More Posts by smoothvirus
smoothvirus's Avatar
United States, VA, Franconia
Joined Sep 2010
I use the Hyperion 3s 1300 25C and the Turnigy Nano-Tech 850 45C in my Electra and they work fine. The 850 is fairly small but it's only good 2 motor runs or so. I use them in ALES because you probably won't be doing more than 1 motor run in ALES.
smoothvirus is offline Find More Posts by smoothvirus
Old Sep 12, 2012, 07:15 AM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
Thanks guys. I went with the Nono-Tech 850, have two on order That should do it.
russ
Old Sep 20, 2012, 03:25 PM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
Sorry for the silence. I ran out of Coverite and had to order another roll to finish the wing. Also have the "Y" cable ordered for the flap servos. I think the end is in sight. Still have to figure out the best placement of the components for balance.
Russ
Old Sep 28, 2012, 11:48 AM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
Sometimes we are our own worst enemy. Back a few posts ago I made the choice of flaps over spoilers to shorten the glide on final. I decided the flaps should be large and open 90 degrees. I have completed the wing's center section with flaps that are 2 inches wide and 17 3/8 inches long. I've decided this is overkill to the max and am scratch building another center section with 7 3/4 x 1 inch spoilers. These will be raised by the servo arms pressing directly upon the inside of the spoilers and they will be closed by the slipstream and kept closed with small magnets. I found this setup on youtube and like it for its simplicity.
Russ
Old Sep 28, 2012, 02:11 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Hi
2.5 inches for flaps MIGHT BE a bit of overkill. 20 to 25% should be good( I just asked about that the other day)
However it can be usefull when setting flaps for speed and lift settings ie camber changes. Let these guys chime in before doing a rebuild????
ozmo01 is offline Find More Posts by ozmo01
Old Sep 29, 2012, 05:08 AM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
Rebuild is not a problem. This way I'll have two center sections and can switch to spoliers if the flaps proove to be too much. Besides, I enjoy building and have everything needed on hand, except I will need to order more Coverite.
Russ
Old Oct 10, 2012, 06:23 AM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
My next project is a Thermic 72, the short kit From Aerosente. It's been done before on this site, but years ago. Anyone interested in another build log on this design? Mine will be set up to use the same RC hardware as the gentle Lady.
Russ
Old Oct 10, 2012, 07:47 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Not sure that Coverite is a good idea on the center panel. I don't think it will add as much torsional stiffness to the wing. Of course there are ways to fix this, such as using some sheeting on the bottom and making a d-tube, or adding some diagonal ribs. (These don't actually have to touch the covering to be helpful, so they could be trapezoids.)
Suspect your flaps won't be too large if you can program in some elevator compensation. Or, as a friend of mine did many years ago, some kind of mechanical mixing. As I recall, his wing had 20 percent flaps on the entire span! He could descend straight down, it seemed, without going too fast.
lincoln is offline Find More Posts by lincoln
Old Oct 11, 2012, 03:41 PM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
Humm...too late for a "D Tube" but I like the diagonal rib idea, I think I'll look into that. Thanks.
Russ
For Sale Carl Goldberg Sophisticated Lady $45 LPU Arcadia, CA vmaxmasonrya Aircraft - Sailplanes (FS/W) 3 Jun 20, 2012 10:00 PM
Sold Vintage Classic Carl Goldberg Gentle Lady NIB! spitfire1999 Aircraft - Sailplanes (FS/W) 1 May 20, 2012 02:13 PM
For Sale Carl goldberg gentle lady 2 meter sailplane ovron41 Aircraft - Sailplanes (FS/W) 1 Apr 30, 2012 09:13 AM
Sold Gentle Lady laser cut kit mcjustis Aircraft - Sailplanes (FS/W) 2 Mar 24, 2012 09:52 PM
Sold "A Classic" Goldberg Gentle Lady Laser Cut Kit (NIB) Tank52 Aircraft - Sailplanes (FS/W) 3 Feb 17, 2007 07:00 AM
