Old Oct 26, 2012, 09:11 PM
mintie is offline
Find More Posts by mintie
mintie's Avatar
Kaiapoi , New Zealand
Joined Jun 2007
pretty happy with the way things are shaping up so time to start gluing all the fuse parts together for good.
Started with the rear fuse section and working forward,positioning the ply bulkhead bits in as well.
mintie is offline Find More Posts by mintie
Old Oct 27, 2012, 08:20 PM
philkiteflyer is offline
Find More Posts by philkiteflyer
KISS_KeepItSimpleStupid
philkiteflyer's Avatar
Invercargill, New Zealand
Joined Nov 2006
Originally Posted by mintie View Post
I have a little plan by keith Humber from 1994 [ Radio modeller ]with a w/s of 74.5 in and I just doubled every thing on that. Is this the same plan you speak of?
Graeme
You'll never guess . . . I found that very plan in my collection the other day. Didn't even realise it was there.
I was looking for a small(ish) glider I could use for aero-tow at he park behind an electric tug.
Um . . . just realised . . thats a big glider ! ! Don't get a real feel for size till it's all together. With your construction should be quite a floater.
Still watching . . .
Phillip C
philkiteflyer is offline Find More Posts by philkiteflyer
Old Oct 27, 2012, 11:56 PM
mintie is offline
mintie's Avatar
Joined Jun 2007
yes Phil..it is starting to get big..But thats what I want,so will just keep going..
Stay on board mate and watch the progress.
Graeme
Old Oct 30, 2012, 02:56 AM
mintie is offline
mintie's Avatar
Joined Jun 2007
Now have the cabane strut welded up and will bead blast at work tomorrow.
Next a coat of paint on it and then bolt to the bulkhead.
All that assembly can then be fitted to the fuse.
Old Oct 31, 2012, 02:43 PM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
Very interesting build. Been following along.
ARUP is offline Find More Posts by ARUP
Old Oct 31, 2012, 10:28 PM
AllanK1 is offline
Find More Posts by AllanK1
Blenheim, NZ
Joined Dec 2007
Novel Construction
This a novel construction method Mintie. I guess the foam remains in place after glassing. Did you come up with this approach yourself?
How are you planning to do the wings?
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Nov 01, 2012, 12:52 AM
mintie is offline
mintie's Avatar
Joined Jun 2007
Allan ... I have been building models this way for the last 15 yrs.
Yes the foam stays in place that is why I have made it all hollow.
The finish construction is light and strong. Have a few on my Blog.
Have built e-power and glow models this way.
The wings are to be a built up construction and solatex covered. As is the elevator.
Thanks for the interest....Mintie.
Old Nov 01, 2012, 02:26 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
Wing construction.
Very cool.
Have you considered a foam wing with veneer skin and then cut out the rib bays?
I'm doing my SHK tailplanes that way after seeing a commercial Minimoa built like this.
Just another idea.
Allan
Old Nov 01, 2012, 06:33 PM
mintie is offline
mintie's Avatar
Joined Jun 2007
Originally Posted by AllanK1 View Post
Very cool.
Just another idea.
Allan
Havent really considered that but would be interested in seeing how yours comes out.
How does weight compare to a built up tail..need to keep this tail end very light.
Have done foam and balsa skinned wings and tail on my edge 540T,but no rib bay cut outs.
Yes always open to input and ideas.
graeme
Old Nov 02, 2012, 06:05 PM
papaalpha is offline
Find More Posts by papaalpha
Joined Oct 2012
Single seater Tutor (Kirby Cadet Mk 2), about 1/6th scale which flys but has no penetration or much of a glide as per the real one which I did my first solo in on my 16th birthday (a few years ago now). Model from K.G. Humber's plan.
papaalpha is offline Find More Posts by papaalpha
Old Nov 02, 2012, 09:34 PM
mintie is offline
mintie's Avatar
Joined Jun 2007
Have got that plan as well.but I chose the mk3 and made it twice size. Again a K G Humber plan.
Nice model you have there.
Old Nov 03, 2012, 07:45 PM
mintie is offline
mintie's Avatar
Joined Jun 2007
Fuse now all glued together..A bit of sanding to go before the paper covering.Fiberglass skinning will come later.
Need to fit the front skid mount and the tow release mechanizim and the rear tail plane brace mount.
The front skid runner will be a fiberglass unit.
The AUW now is 350 gms.I have a projected weight in mind and will see how close we get.
Any input wellcome...need ideas for the wing top pop up brakes.
Old Nov 03, 2012, 08:49 PM
Joined Nov 2006
Q1:- Whats the purpose of the paper covering? (saw the pics in your blog)
Q2: What weight cloth will you be using for glass skinning?
Airbrakes, have a look at this link he used a servo with a sprung wire arm connection. The spring made sure the brake stayed down and didn't open during flight.
Looking good . .
Phillip C
Old Nov 04, 2012, 01:04 AM
mintie is offline
mintie's Avatar
Joined Jun 2007
I will answer the Qs one at a time.
The paper serves two functions...firstly ..the paper is like a very thin veneer,remember it is wood.This adds very little wt, but a considerable amount of strength if put on correctly.Its cheap and easy to work with.
secondly....as you may be aware foam absorbs a hugh amount of resin when glassing and that is weight,so the paper seals the foam and then, the amount of resin used is greatly reduced,and a better surface to work on.Glassing is all about using the least amount of resin.[Some people think that you just pile it on ,but the resin does not surply the strenght, it only needs to lock the glass fibers together]
On some of my e-power models just the paper is used and works a treat..
with the paper on and any final filling done, will use a base covering of 6oz cloth over the whole fuse,then a 2oz over the whole fuse.
This will be left to harden for a couple of days then lightly sand.If I am happy with this, will then do the forward section up to the rear of the cockpits with a 24gm finishing cloth.
left to harden off again then a light sand .Time then to start with the 2k under coats.
Will document as I go with pics.
Thanks for the airbrake link.that is way cool...kind of thought something like that would work .So simple and easy. but functionable.
Old Nov 04, 2012, 01:18 AM
Joined Nov 2006
Thanks, makes perfect sense.
Can't wait to see the process . . .
Phillip C
Sold Airworld 3.5 meter Kirby Kite NIB SteveR Aircraft - Sailplanes (FS/W) 9 Jun 25, 2012 12:56 PM
Discussion "The Lockheed Plant" presented by Joe Kirby BeechMusketeer Atlanta Area RC 0 May 28, 2012 08:08 PM
For Sale 2x HK-SS30A-HW ESC flashed with Simon Kirby's fw lazze Aircraft - Electric - Power Systems (FS/W) 0 May 25, 2012 07:55 AM
For Sale Vintage Super Call-Air Cadet Decals redball8 Aircraft - General - Miscellaneous (FS/W) 0 Mar 10, 2012 12:00 PM
