Old Jun 22, 2012, 03:38 PM
mintie is offline
Find More Posts by mintie
mintie's Avatar
Kaiapoi , New Zealand
Joined Jun 2007
Build Log
Kirby Cadet mk 3
I am getting ready to scratch build one of these to 29%scale.I have a small plan that I am working off [not sure how accurate this is ] but would like a bit more detail.
Have done a google search but come up with very little.
This postng is to enquire if any of you glider guys have an more info. that I can use in my build. cheers
Now have the project under way .
mintie is offline Find More Posts by mintie
Old Jun 22, 2012, 04:58 PM
SZD16 is online now
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
Can I ask why 29%?
SZD16 is online now Find More Posts by SZD16
Old Jun 22, 2012, 05:43 PM
mintie is offline
mintie's Avatar
Joined Jun 2007
How does 3.6 - 1. sound . The w/s is very close to 12 ft. a very convenient size to work to.
cheers
Old Jun 22, 2012, 06:20 PM
SZD16 is online now
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
Gotcha...... I figured that was. A friend of mine built a SZD-15 to 1:2.67 scale because that was the longest wing half that would fit in his van!
Old Jun 22, 2012, 10:01 PM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
Martin Simons has a nice 3-view of the 1950 Slingsby Type 31 Tandem Tutor (Cadet Mark 3) on page 33 of his book entitled 'Sailplanes 1945-1965'. The span was 13.2m. The T-35 was similar with a span of 15.64m
ARUP is offline Find More Posts by ARUP
Old Jul 07, 2012, 08:33 PM
mintie is offline
mintie's Avatar
Joined Jun 2007
well after a bit more time on line came up with more photos of the full size.Over the weekend started cutting out the fuse.
I enlarged a smaller plan that I had ,and taped those bits to a large piece of paper then drew in all the missing bits. Still have the wings to do .
lots of design bits to do yet ,like how I will mount the wings to the fuse and the strut mounting system.
Will try and get these to follow the full size glider as close as I can.
At the moment I have ideas running around in my head,and will put them onto the plan.
The fuse is 6mm ply on the center frames and mount points,white foam fuse sections then all will be covered in paper and the lot fiberglassed to give me the ply wood finish look.
The under cart will by tied into the center section with ply mounts.
Any ideas are welcome during the build.
Old Jul 12, 2012, 08:55 AM
istvann is offline
Find More Posts by istvann
Joined Jan 2005
Hi Mintie,
here is a link with documetation and Plan:
http://scalesoaring.co.uk/VINTAGE/Do...by%20Cadet.htm
and a lot of other planes as well.
I enjoy your threads, especially the Fournier covering method.
Istvan
istvann is offline Find More Posts by istvann
Old Jul 13, 2012, 04:24 AM
mintie is offline
mintie's Avatar
Joined Jun 2007
Hello Istvan.....thanks for that I have some of those plans but not all .have now saved the site for future referance.
I have also used the same method with the PA 8 build as well.
Using a similar method with my latest builds,but have put a fiberglass skin over the paper covering.
Will be back on this build again tomorrow.
Thanks for your comments. cheers Mintie.
Old Jul 16, 2012, 03:57 AM
mintie is offline
mintie's Avatar
Joined Jun 2007
Now have the front ply former done for both sides.
Made up 5 templates to cut out the front half of the foam nose section. This worked a treat as was able to do it all in one piece,instead of three bits and sanding the final shape.
Have also drawn up the front wing mount the way I want it to mount into the plane.
So far all is going along just fine.
Old Jul 20, 2012, 04:17 AM
mintie is offline
mintie's Avatar
Joined Jun 2007
The other half of the nose section cut tonight.
Split the nose sections then made up three templates and hollowed them out and glued back together.
Moved down the fuse a little and did the rear cockpit area.
Old Jul 21, 2012, 03:31 AM
mintie is offline
mintie's Avatar
Joined Jun 2007
After a few wee mods to get things to line up ,now have the forward cockpit area done.
Glued the two front half sections together.
With this done I can now work out how I want the tow hook mounted and where any reinforcing might be needed.
Next working on the tail end and how I will incorperate the fin and post into the fuse.
Purchased some wire today to make up the wing front strut.
Will get a wee bit more done over the next two weeks,then all building will stop as we are off to Canada & USA for 6 weeks
Very happy with progress so far.
Old Aug 01, 2012, 01:08 AM
mintie is offline
mintie's Avatar
Joined Jun 2007
Progress has been a bit slow as had other things to do.Some of the fuse is glued and the rest is just taped together for a look.
Have been working on the strut mount designs for the fuse and wing,but still have more to do .
This will be my last posting for a while as we are away in a few days,and all modelling must stop.
Building will continue again in october when we get home.
Old Oct 13, 2012, 12:51 AM
mintie is offline
mintie's Avatar
Joined Jun 2007
back in the swing again
Back to the build..Home from our trip,done another exam,and now have time to build again.
I now have the forward bulkhead glued together and the wing/fuse forward strut mounting bolted onto it.
Next step is making the wing mounting cabane and fitting that to the bulkhead. Been working on a jig system so as to mount everything on to it and weld the bits.
When that is all done the B/H will be glued to the front section of the fuse.
Now everything is slowly taking shape.
Old Oct 15, 2012, 06:56 PM
AllanK1 is offline
Find More Posts by AllanK1
Blenheim, NZ
Joined Dec 2007
Hi Mintie, nice work. I look forward to having you come to an aeo tow with this one.
Your T31 would be a welcome addition to the South Island scene so make sure youn include and aero tow release.
I attach a picture of my small one. 108 inch span. It tows nicely but has the glide slope of the space shuttle. Even so I managed a 15 minute flight at the CHCH Radio Fliers feild out at Burnham this year. Good lift though.
I love the inovative construction and will watch this one with interest.
Allan Knox in Blenheim
AllanK1 is offline Find More Posts by AllanK1
Old Oct 15, 2012, 07:45 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
While I think about it I recommend you fit a taller rudder than the original T31 plan. The Aussies built a T31 derivative with the rudder a rib bay longer. I have since fitted this to mine and it has tamed the yaw instability nicely. I will get some pictures. They tell me the full size suffers the same way.
Allan
Sold Airworld 3.5 meter Kirby Kite NIB SteveR Aircraft - Sailplanes (FS/W) 9 Jun 25, 2012 12:56 PM
Discussion "The Lockheed Plant" presented by Joe Kirby BeechMusketeer Atlanta Area RC 0 May 28, 2012 08:08 PM
For Sale 2x HK-SS30A-HW ESC flashed with Simon Kirby's fw lazze Aircraft - Electric - Power Systems (FS/W) 0 May 25, 2012 07:55 AM
For Sale Vintage Super Call-Air Cadet Decals redball8 Aircraft - General - Miscellaneous (FS/W) 0 Mar 10, 2012 12:00 PM
