Old Sep 19, 2012, 09:37 AM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Originally Posted by azure View Post
I didn't have a Z15 or CAN bus in use with either of my S800 crashes. The system did not shut down entirely (at least the motors didn't), but sounded more like an uncontrolled motor(s) overspeed.
If you were using a WKM, you were using the can bus. It is the 4 lead connectors that allow the various components to communicate with each other.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Sep 19, 2012, 09:49 AM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
S800 makes the news
http://www.pressherald.com/news/aeri...012-09-15.html
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Sep 19, 2012, 10:34 AM
yeehaanow is offline
Find More Posts by yeehaanow
United States, VT, Bristol
Joined Sep 2010
Just an idea about the FOD mystery-
I thought it was pretty common knowledge that long power lines to the esc cause ripple voltage issues, and the esc's don't seem to have any big capacitors to guard against it.
I wanted to pull an esc and put in a castle creations one to measure it but never got around to it.
I have mentioned this before, but I discovered that one of my props simply would not balance while in use, even though it was precisely balanced on the stand. It had a slight defect in the construction. I would highly suggest everyone test each arm individually on the bench, and measure it with a vibration meter. (The Vibration ap for iphone is what I used) The dji battery straps are good for keeping the arm from flying away while you test.
Although Denny's prop adapters might be the best solution.
yeehaanow is offline Find More Posts by yeehaanow
Old Sep 19, 2012, 11:07 AM
cropter is offline
Find More Posts by cropter
Joined Sep 2012
Good point, but at least in my ESCs there are two big capacitors. Should be ok..
Vibration testing might make sense..
cropter is offline Find More Posts by cropter
Old Sep 19, 2012, 11:12 AM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
I use my iphone app all the time. I have seen caps. fall off due to vibration. I am going to try these 14x8 Graupner E to see how they perform against the APC's Did anyone check to see if Caps were loose after the FOD.
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Sep 19, 2012, 01:02 PM
ksrimoungchanh is offline
Find More Posts by ksrimoungchanh
Lost in the wind
United States, KS, Overland Park
Joined Jun 2012
Any guidance on how to power up the arms without the frame to test? or is everyone just unplugging 5 arms and just running up the left over arm without props.
KS
ksrimoungchanh is offline Find More Posts by ksrimoungchanh
Old Sep 19, 2012, 01:22 PM
flytahiti is online now
Find More Posts by flytahiti
flytahiti's Avatar
PolynÚsie franšaise, ╬les du Vent, Papeete
Joined Mar 2010
have you tried the 14x8 E i have received mine but not the prop adapters i still have to wait .
flytahiti is online now Find More Posts by flytahiti
Old Sep 19, 2012, 02:13 PM
Taszz is offline
Find More Posts by Taszz
The Netherlands, NH, Kudelstaart
Joined Jul 2012
I fly the s800 with the Naza+gps and the Graupner mx-16 hott. I have made ​​many flights without problems.
I think the crashes and problems must be sought in the wookong.
Taszz is offline Find More Posts by Taszz
Old Sep 19, 2012, 04:32 PM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
don't know if this is old news. Not going to read back. But the retraceable is for the s800 is shown on the Photokina. Check this FB profile for pictures.
Ah other stuff too. Fs100 Gimbal DJI VTX and Heli naza.
https://www.facebook.com/GlobeFlight
Boris
BorisSA is offline Find More Posts by BorisSA
Old Sep 19, 2012, 04:33 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
I agree
c3d76 is offline Find More Posts by c3d76
Old Sep 19, 2012, 05:10 PM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
So, here is a video from the S800 arm vibration tests we did earlier today.
The test was done by removing the props from all but one arm, and then mounting a small mirror at the arm. A laser pointer is then pointed at the mirror so that a spot is reflected at the wall. If there was little or no vibration, the laser should still be a tight spot on the wall or just become slightly fussy during testing.
But as you can see there is a bit more then slight fussing going on.. Propeller was tested in a balance jig before the run, and was pretty much close to perfect. We also tried lifting the S800 up from the ground to eliminate any resonances, and the vibrations where perhaps marginally better but to little to say for sure.
DJI S800 laser pointer vibration test (0 min 27 sec)
jab is offline Find More Posts by jab
Old Sep 20, 2012, 12:21 AM
Joined Sep 2010
KS
Just unplug all arms but one, or take props off the others. Seems much easier to do the former. That's what I did.
I found the motors themselves to run very smooth with no props. No vibes at all.
Old Sep 20, 2012, 12:35 AM
Lost in the wind
Joined Jun 2012
http://www.youtube.com/watch?v=Qa7ZTRW3uhU
what happens if you do the same test, without the props? does it dance around that much too?
Regards,
KS
Old Sep 20, 2012, 12:40 AM
azure is offline
Find More Posts by azure
Joined Mar 2012
Thanks, I understand now.
azure is offline Find More Posts by azure
Old Sep 20, 2012, 12:45 AM
Joined Aug 2005
KS
I simply unplug the motor wires and use a servo tester to run each one individually. I like the Laser pointer method and the iphone to do the checking.
The vibration level seen with the standard DJI carbon blades is I am sure enough to break a capacitor wire over time. maybe we should be using a blob of silicon to support them.
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
