Old Sep 17, 2012, 01:53 PM
Infante is offline
Find More Posts by Infante
Infante's Avatar
Portugal, Lisboa, Sintra
Joined Feb 2010
Please Help!!
I am having a problem with the idle speed.
3 of the motors marked with X start faster than the oder 3 marked with O.
I already tried all idle speed positions and i always have the same problem.
Everything was working fine before, no changes were made to the setup.
I only tried this on atti and gps mode and watt happens is wen i am at middle throttle and hovering, i have sudden changes in motors speed and the s-800 loses altitude. It looks like is losing power.
I have tried with new and old batteries.
I also noticed that i started to have 2 and 3 withe flashes when i am flying, never had them before. Props and motors are calibrated.
Can any one help me solving this problem.
Infante is offline Find More Posts by Infante
Old Sep 17, 2012, 01:59 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
@Infante
Tell us about your set up. How far is your receiver from the IMU? Have you tried to swap arms? Just a few questions.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Sep 17, 2012, 02:38 PM
Infante is offline
Infante's Avatar
Joined Feb 2010
Originally Posted by Tahoe Ed View Post
@Infante
Hi.
I didnīt swap the arms, i mean, the problem is from the diference of speed from clock and counter clock rotation motors.
The IMU is far from the transmitter, i never had this issue before.
I am using 2x6s 4000mah and sometimes 2x6s 4500mah.
The radio is the Graupner MX-20.
Here are some pics.
Old Sep 17, 2012, 02:48 PM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
Originally Posted by Infante View Post
Hi.
Here are some pics.
I wouldn't worry to much about the different idle speed at start up. Mine does that occasionally but once at take off or holding height there are no problems. If there would be a speed difference between the O and X arms things would result in a uncontrollable yaw etc. Don't think that the idle speed has anything to do with your setup not holding the altitude.
How many times has this happened now ? Once with one lipo, several times on the same day with different lipos ?
BorisSA is offline Find More Posts by BorisSA
Old Sep 17, 2012, 02:53 PM
BorisSA is offline
Joined May 2011
The little hole in the IMU that lets the air in for the Baro sensor lie to the inside of the IMU when mounted forward facing on the S800. Could it be that you have something blocking that hole ? A cable some component etc.
Boris
mitmit is offline
Find More Posts by mitmit
Moscow
Joined Jul 2006
Please Help!!
this is wkm problem, not s800.
idle pulses are different for cw and ccw outputs.
long story short, recalibrate esc's with some digital servo tester, play with low pulse value.
thats also true
cheers
dimitri
mitmit is offline Find More Posts by mitmit
Old Sep 17, 2012, 02:58 PM
BorisSA is offline
Joined May 2011
has similar problems once with an older build CS8 WKM. In my case the problem was that the outer pressure influenced the inner climate of my apartment and the heating was on full blast etc.
In this video i never changed the throttle input but the CS8 just landed.
WKM Alt Hold no working at all anymore. (1 min 3 sec)
You don't have a data link by any chance and can readout if the height drops while having the bird stading on the ground ? Could indicate that there is a problem with the baro sensor
Old Sep 17, 2012, 03:00 PM
BorisSA is offline
Joined May 2011
thats also true
cheers
dimitri
Hmmm can you calibrate the S800 ESCs ? Never tried it ! Shouldn't they have a fixed range ?
Boris
Old Sep 17, 2012, 03:10 PM
Infante is offline
Infante's Avatar
Joined Feb 2010
Hi Boris!
This normally happens when i use my 2X6S 4500mah 35-70c Nanotech
I dont remember having this problem when i am flying with 2X6s 4000mah 30c turnigy.
The nano are a little bit heavier but they are new, and i also have withe flashes, never had them before.
I must also say that the last time i tried to fly it was windy.
The IMU is free from dust or any thing that could block the barometric sensor.
Old Sep 17, 2012, 03:17 PM
Infante is offline
Infante's Avatar
Joined Feb 2010
thats also true
cheers
dimitri
Hi.
I dont have a servo tester, but even if i had i didn't knew how to do it.
is that really necessary?
cheers
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Boris
They are preprogramed as are the rest of the DJI escs. No programing necessary.
Site Sponsor
Old Sep 17, 2012, 03:21 PM
BorisSA is offline
Joined May 2011
Hi.
cheers
Infante don't worry about it like Tahoe Ed just stated the s800 escs are just like the DJI ESCs you can't calibrate them !
Old Sep 17, 2012, 03:22 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
What changed when the white flashes started?
Site Sponsor
Old Sep 17, 2012, 03:31 PM
mitmit is offline
Moscow
Joined Jul 2006
hmm, probably you are right Boris)
did not try that with s800.
it happened once with wkm on other frame, but in my case it behaved a bit different - cw motors did not start at all while ссw were ok at idle. playing with low pulse width did helped..
cheers
Old Sep 17, 2012, 03:34 PM
Infante is offline
Infante's Avatar
Joined Feb 2010
Very unstable beaver and lost of power, losing altitude.
This normally happens when the throttle stick is near the center position.
This might be a dum question but, with the graupner MX-20, the traveling of channel 1, which is throttle, goes from -100 to 100, shouldn't it be 0 to 100?
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
