Old Sep 14, 2012, 11:46 PM
Huddo is offline
Find More Posts by Huddo
Australia, SA, Adelaide
Joined Aug 2011
Well I got over my nerves... and decided to do a first flight in my tiny back yard.
DJI S800 First Flight - DJI Wookong-M (6 min 45 sec)
Also did a quick Z15n test in front of the mirror...
DJI Zenmuse Z15n Mirror Test (0 min 38 sec)
Next up will be a flight in a nice big field with long grass !
Huddo is offline Find More Posts by Huddo
Old Sep 14, 2012, 11:55 PM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
I have never seen any vibration problems but I did find that some std. carbon props needed rebalancing. I have also made a conversion kit for using stock 14x4.7 APC's, these seem to be a little better in strong winds IMHO. They run slightly faster. Much cheaper too.
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Sep 15, 2012, 12:05 AM
Spyde is offline
Find More Posts by Spyde
Denmark, Region Zealand, Jyderup
Joined Jun 2010
I just got my s800 back after my crash and it seems to me that the new props i got are alot stiffer then the ones on my old one, maybe thats why some of us dont have so many vibrations as others
Spyde is offline Find More Posts by Spyde
Old Sep 15, 2012, 12:12 AM
Joined Aug 2005
I think receiver placement could be a potential source of problem as well. With two layers of carbon nicely placed to block any signal I think it/they have to be mounted very high or well below the plates away from carbon blockages. I definitely would not put anything between those plates. There is so much carbon everywhere that line of sight at all angles is hard too achieve
Old Sep 15, 2012, 12:18 AM
Joined Aug 2005
Whereas I know that many are using much higher gain settings than default I have been working the other way. I have very low atti and a little higher basic gains. I find that the model is a lot less nervous in higher winds.
Old Sep 15, 2012, 01:02 AM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
Congrats on the maiden and good luck with your next flight!
c3d76 is offline Find More Posts by c3d76
Old Sep 15, 2012, 03:24 AM
c3d76 is offline
Joined Mar 2012
Originally Posted by Sid3ways View Post
I could see the problem with crashes on S800s being with ESC timing. Maybe some units are unable to support the middle "recommended" setting and need the timing slightly higher. The motor could either lose sink or get confused and go 100% throttle. Of course there is zero data to back this up but I could buy it as something to investigate (although I would imagine DJI has already checked into this).
I just don't get how idle speed would affect the timing?! I saw it more as a minimum throttle trim... Nothing to do with actual inflight throttle input (35-100% ish)
I'm happy it worked, but I don't understand how or why
Old Sep 15, 2012, 03:39 AM
oylore is offline
Find More Posts by oylore
Joined Nov 2009
Thank you for the info.
What gain setting are you using on the S800/Z15 combo?
oylore is offline Find More Posts by oylore
Old Sep 15, 2012, 08:23 AM
Spyde is offline
Joined Jun 2010
just finished my gimbal mount for my cinestar gimbal! hope it works
Old Sep 15, 2012, 08:28 AM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
Regarding log data, the perhaps the most helpful data right now would be logs of the PWM control pulses going from the WKM to the ESC. If we had logs of the control pulses during a "flip of death" we would know insantly is the problem was in the WKM or in the arm (physical wire problem or ESC/Motor). Another log that would be very helpful was the status and health of the IMU leading up to the flip. I find it incredible that there is no logging in the WKM. All the hardware needed is already there.
jab is offline Find More Posts by jab
Old Sep 15, 2012, 08:39 AM
oylore is offline
Joined Nov 2009
Nice work! Looking forward to seeing the rest in place.
Old Sep 15, 2012, 09:05 AM
Chilli Paste is offline
Find More Posts by Chilli Paste
Namibia, Khomas, Windhoek
Joined Jul 2012
@Spyde, I digg your mount design. Where did you get those rubber (Silicone?) mounts?
Chilli Paste is offline Find More Posts by Chilli Paste
Old Sep 15, 2012, 09:11 AM
Spyde is offline
Joined Jun 2010
Thanks man! I got Them at altigator
Old Sep 15, 2012, 09:55 AM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
hope it works
how will you ever know. I thought you were too scared to fly with the s800 or have you decided to give it a go??
Paul@SCC is offline Find More Posts by Paul@SCC
Old Sep 15, 2012, 09:59 AM
Spyde is offline
Joined Jun 2010
For now Its just standing there :-). But i Think i Will give a another chance! So we Will see how it goes
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
