United States, CA, Anaheim
Joined Dec 2011
Totally agree. There are always going to be some issues as an early adopter, and you have to know and expect this going in. The results are a version 2 of the product that will flat out rock.
Las Vegas/Lake Tahoe
Joined Feb 2010
I posted this in one of the other threads. Mine is fine, but I will replace the red connector when I have the time. Here is what I posted and the picture of my connectors to the pcb.
Here is what mine looks like. The solder joint is a little gray vs shiny silver. I know it is non-lead solder so some of that is expected. All my pins are solid. This was one of the first in the US so maybe the QC was better on the earlier models. When I have the time, I will replace the red connector. I have some 90 degree 3 pin connectors that will work better anyway. Got them for an ArduCopter IMU. Sparkfun still have them in stock. http://www.sparkfun.com/products/10095 |
Joined Dec 2011
I don't see the tips of the pins in that picture, shouldn't the pin tips be pushed through just a little bit, and solder should be on top of the pins. Plus some of the solder joints look flat and not that great (non-shiny). But it could be the photo. The solder joint on my battey cable connector is very shiny (mirror like).
Orange County Ca
Joined Nov 2003
Hows your S800 flying
We have inspected the Header pins on our unit and have found no issue.
However we are getting quit erratic flight performance. Currently flying with a dummy payload equal to a Z15w/camera and lens on 6S 10,000mah. Roughly 14 LBS AUW. When flying in perfectly calm conditions the aircraft behaves somewhat normal and can be flown as shown in other POV videos provided it is not flown over about 10 or 12 MPH. In winds from about 4MPH on up its an entirely different story. While in forward flight into the wind the aircraft will wobble somewhat while losing altitude, some times it comes down slow, sometimes it will just drop. You have to increase throttle a great deal to maintain altitude While in a hover during wind gusts it will do the same thing. Again you have to increase throttle a great deal to maintain altitude When this happens it appears that the motors are shutting off momentarily causing the aircraft to loose altitude. Increases in altitude gain only make it worse. At first inspection it was thought the IMU might be coming in contact with the top center plate. This is not the case. This is our 3rd WKM unit as we have had great commercial success with our other two units mounted on an octo and a small hexa. Appreciate any feed back |
| Thread Tools | |
| Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble | jasper7821 | Multirotor Talk | 219 | Oct 16, 2012 05:11 PM |
| New Product DJI Spreading Wings S-800 Hexa multi-rotor | sidneyw | Multirotor Talk | 930 | Jun 22, 2012 10:14 AM |
| Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! | tpnitro | Multirotor Talk | 120 | Jun 19, 2012 01:27 AM |
| Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters | QuadcoptersUk | Multirotor Talk | 8 | May 14, 2012 01:27 PM |
| Discussion Dji Spreading Wings (S800) coming | Huluhulu | Multirotor Talk | 7 | Apr 27, 2012 03:11 AM |
