Old Aug 20, 2012, 10:25 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
ddmt, if you are using S-bus 2 with telemetry; S-bus currently does not support. PM email me please.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Aug 20, 2012, 10:43 PM
ddmt is offline
Find More Posts by ddmt
Gravity sucks :)
Indonesia
Joined Jul 2005
Originally Posted by Tahoe Ed View Post
ddmt, what were your gains set at. What Tx/Rx are you using? I fly the S800 on 5.12a with 2x6S 5000mAh lipos centered on the frame and I cannot replicate what is happening to you on my JR9503/AR8000 set up. I am running DJI suggested gains of 220/220/140/150 and 130/130 with 30% expo on Aileron and Elevator. I am also running a new center plate, arms and WKM MC from DJI. In my opinion it is not a s**ty platform. But I would like you to have the same experience that I am having. I hope we can help you.
ATM 116/105/130/140 150/150. Actually I had the problem when we were trying to find the correct gain. The basic pitch & roll is connected to x2 & x3. Tx is futaba 12fg, rx is r6208sb. Dunno if I want to test again with the DJI's suggested gain setting, it's scary to know if you can't trust the platform you're flying.
This is one reason we haven't upgrade our 2 other hexas (1 droidworx frame, 1 mk style frame with CF middle plate), still at 5.02, no problem whatsoever.
ddmt is offline Find More Posts by ddmt
Old Aug 20, 2012, 10:48 PM
ddmt is offline
Gravity sucks :)
Indonesia
Joined Jul 2005
Originally Posted by Dolby View Post
Something is wrong with your setup ddmt because that is not normal at all. Most people that use this platform find it extremely stable in atti so there is definitely something up.
The delay in controls makes it sound like there is some issue between the rx/wkm maybe? There should be no delay when you move the stick. Then again you say it works fine in manual so it doesn't make sense it would be a rx/wkm issue but more of a either a compass calibration or some issue with the IMU?
Maybe connect up the WKM to your PC and run the WKM Assistant and re-run the the tx-calibration. Then move the controls around and see if they move the sliders in the software at the same time or if there is some delay. Try all kinds of modes, etc.
I've tried to connect to wkm assistant again, and all tx setting were normal. This is not our 1st wkm, and we are using ace one as well. I guess we spent to much money on DJI's product.
Old Aug 20, 2012, 10:50 PM
ddmt is offline
Gravity sucks :)
Indonesia
Joined Jul 2005
No telemetry, only the droidworx hexa has the full waypoint license, hasn't use it yet because we are too afraid to upgrade the firmware.
Old Aug 21, 2012, 01:43 AM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
Personally I like the Turnegy Nano Tech lipos. I will say that out of the 20 or so that I have purchased about 3 arrived DOA. The procedure to replace them under warranty is more costly than just writing them off. Right now I fly with 2x6S 5000mah. I can get up to 18min without gimbal and not over discharge the lipo. I have flown 20+min before the low battery alarm went off. However, the lipos were over 90% discharged. I would not recommend doing this.
Originally Posted by shdwkeeper View Post
What are your settings in the WKM setup using (2) 6S 5000? What is your 1st warning set at and your 2nd warning set at?
anyone?
shdwkeeper is offline Find More Posts by shdwkeeper
Old Aug 21, 2012, 01:47 AM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
anyone?
I posted mine in post #626 ^^
c3d76 is offline Find More Posts by c3d76
Old Aug 21, 2012, 04:09 AM
Aaalie is offline
Find More Posts by Aaalie
Aaalie's Avatar
Netherlands
Joined May 2006
Mounted new props, I like the sound of the S800 (1:24) :
S800 in het donker (2 min 13 sec)
Aaalie is offline Find More Posts by Aaalie
Old Aug 21, 2012, 04:28 AM
c3d76 is offline
Joined Mar 2012
It sounds great! I had no idea the LED's were that bright, perfect for night flying
Old Aug 21, 2012, 08:31 AM
badbill is offline
Find More Posts by badbill
Soylent Green is PEOPLE
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
Originally Posted by Adidas4275 View Post
you were flying FPV and using the POI circling?
that seems interesting....
I can see it being useful with LOS flying, but FPV it seems useless....
I fly LOS, I just use the cam to frame video and pics.
Bill Davenport
AMA 28141
badbill is offline Find More Posts by badbill
Old Aug 21, 2012, 09:10 AM
helicoblast is offline
Find More Posts by helicoblast
Geneva, Switzerland
Joined Jan 2009
Could you please tell us which props you mounted, and if you needed an adaptator, which one?
thanks!
helicoblast is offline Find More Posts by helicoblast
Old Aug 21, 2012, 09:39 AM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
Another S800 first video
Still waiting for the Zenmuse so a short go pro flight, getting dark so quality not great.
10 points to anyone who can tell me the city.
Thanks for watching,
FB
https://vimeo.com/47910124
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Aug 21, 2012, 11:19 AM
Aaalie is offline
Aaalie's Avatar
Netherlands
Joined May 2006
thanks!
Actually, I made them myself. At first I bought a lot of different pair props. This one and the APCshape 14*4,7 Carbon were the one's with good trust/power ratio, this one had a little less vibration... but still a little to much, they were still to flexible at high power.
So I glued a piece of ABS 0,6mm over the center, sanded it a little in shape, used them to make moulds, and played a few evenings with epoxy, carbon tissue, wax etc. etc.
Here you can see the final result, the props I used for the moulds I thought came from rc-timer.
S800 andere props (2 min 28 sec)
Eeuuhh... City... Oregon city?
Old Aug 21, 2012, 02:42 PM
oylore is offline
Find More Posts by oylore
Joined Nov 2009
Is this safe to use?
MIne S800 arms with motor and ESC have been in Switzerland for the upgrade. It looks as if the resistors are switched. From what I can see of the picture it has only been working with resistors. See picture.
On one arm, the red LED is not liting now.
I could not wait longer to test flying! Everything seemed ok except one red LED. Motors and ESC was not hot after 2 x 13 min flight time.
My ESC has the sign: DJI High Voltage BLDC AQ 03-05 V3
But is it safe to use this ESC with faulty LED?
oylore is offline Find More Posts by oylore
Old Aug 21, 2012, 04:27 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Throwing this in here as it is directly for S800 owners. Adding my buddy code if anyone wants to save money on the 6S 30c 8000mAh lipos. I'm going to try 2x of them and see how the temps get and my flight times. Frank from DJI is claiming near 25 minutes with the Z15.
(valid until September 03, 2012)
ZIPPY Flightmax 8000mAh 6S1P 30C (USA Warehouse) Save US$: 4.34
Sid3ways is offline Find More Posts by Sid3ways
Old Aug 21, 2012, 04:39 PM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
PolynÚsie franšaise, ╬les du Vent, Papeete
Joined Mar 2010
this one is just a bit more expensive but 110g more light so with two you get 220g less http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
flytahiti is offline Find More Posts by flytahiti
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 06:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 11:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 02:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 02:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 04:11 AM
