Old Jun 26, 2012, 12:08 PM
Spyde is offline
Find More Posts by Spyde
Denmark, Region Zealand, Jyderup
Joined Jun 2010
i made a new one so i easily can remove the GPS
Spyde is offline Find More Posts by Spyde
Old Jun 26, 2012, 12:12 PM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
The 3X Pro can fit even a Red Epic so a 5D/7D/D800 is no problem.
http://photoshipone.com/3x-pro-v2/
The Zenmuse is 1.3kg The 3X Pro with mounting adapter is 1.1kg. A Canon 5D with 28mm prime is about 1.25kg
I just weighed the S800 with 3X Pro v2 mounted, two 6s4000 batteries, and simulated ballast (camera) weight. Total comes to 6.4kg. Just over the published max by .4kg. Will be interesting to see how the copter performs.
Photoship One is offline Find More Posts by Photoship One
Old Jun 26, 2012, 12:14 PM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
the max is 7kg
http://www.dji-innovations.com/produ...pecifications/
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Jun 26, 2012, 12:18 PM
by Alary Design
Joined May 2002
the max is 7kg
Ahhh yes. Thx for that. I was looking at the lower 6kg referenced in the flight time field. So it seems with 3X Pro v2 and 5D the copter would come in just under max.
Old Jun 26, 2012, 01:22 PM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
Polynésie française, Îles du Vent, Papeete
Joined Mar 2010
i see you drill the center plate to mount the GPS . is it safe to do that in the printed circuit board ?
flytahiti is offline Find More Posts by flytahiti
Old Jun 26, 2012, 01:36 PM
Spyde is offline
Joined Jun 2010
I have no problems . Iam not even sure iam hitting them
Old Jun 26, 2012, 02:17 PM
flytahiti's Avatar
Joined Mar 2010
because i think you have positive on one side and negative on the other and wires to esc i don't know were ( i would be great if we could have a diagram ) i you could short circuit the 2 sides with the screw . anyway your mounting is very nice but i won't do that until i will have a diagram of connections.
Old Jun 26, 2012, 02:26 PM
skivvie is offline
Find More Posts by skivvie
skivvie's Avatar
United States, UT, Draper
Joined Aug 2011
What would it cost me for you to make me one of those? Just using two set screws it looks like eh?
skivvie is offline Find More Posts by skivvie
Old Jun 26, 2012, 02:36 PM
Spyde is offline
Joined Jun 2010
I dont know. It took me about 30 min to make. Do you have access to Cnc
I have about 15 flights with my s800 and i had no trouble with the screws in the top plate but i would probably not Recommend you doing it
Old Jun 26, 2012, 02:38 PM
Spyde is offline
Joined Jun 2010
Sorry misunderstud your question . Iam not sure i can sorry
Old Jun 26, 2012, 02:46 PM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
How about 6s5000 batteries? Also I would like to see some examples of this thing loaded up. I was looking at a 5D mkIII, 50mm L series Prime (590 g), 24mm L series Prime (650g), 85mm L Prime (1.03 kg)
Looks like the non-L series lenses are half the weight so maybe thats the ticket.
shdwkeeper is offline Find More Posts by shdwkeeper
Old Jun 26, 2012, 04:11 PM
skivvie is offline
skivvie's Avatar
Joined Aug 2011
Ah too bad you could probably sell a few here =]. I don't have access to a CNC.
Old Jun 26, 2012, 05:54 PM
jdm66 is offline
Find More Posts by jdm66
jdm66's Avatar
France, Pyrénées Orientales
Joined Feb 2009
Hi
First " Rendez Vous " of 2 x S800 in France
you can easily see the vibrations of the engine mount and you may hear strange engine music !
2012 06 25 2S800 (6 min 52 sec)
the Ecs reached 70 ° C. After 10 min
after this meeting and all problems of this bird, my colleague decided to sell its S800
I risk do the same ...
jdm66
jdm66 is offline Find More Posts by jdm66
Old Jun 26, 2012, 08:34 PM
flytahiti's Avatar
Joined Mar 2010
what is the temperature the escs can handle without problem?
Old Jun 26, 2012, 08:51 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Spyde, I drilled a hole in the DJI mount and just used a 3mm screw that self tapped the hole. I mounted mine on the center screw and then drilled a hole forward of the center for the second mounting point. I also used double sided tape along with a nylon screw. No shorting issues.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
