Old Feb 17, 2013, 05:23 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
Originally Posted by DroneBuilder View Post
Quadslo -
In the repair of your S800, did you buy new arms? I assume you did. If so, did you once again calibrate all six arms' esc's to your RX?
I hope my simple suggestion is not received the wrong way. But I can admit that I forgot to calibrate esc's on my S800 the first time I flew, and it exhibited similar flight characteristics.
Good luck -
Dronebuilder
Really? We need to calibrate the ESC's?
I assumed it was the same as the DJI Opto ESC's where no calibration is required
Can anyone else confirm this?
c3d76 is offline Find More Posts by c3d76
Old Feb 17, 2013, 06:07 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
From the S800 Manual:
DJI ESCs are specially designed for multi-rotors. When use with DJI autopilot systems, you do not have to setup any parameters or calibrate travel range.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Feb 17, 2013, 06:44 PM
c3d76 is offline
Joined Mar 2012
Thanks Ed! Thought I had read that somewhere...
Old Feb 17, 2013, 08:07 PM
dragant is offline
Find More Posts by dragant
dragant's Avatar
Belgrade, Serbia
Joined May 2010
My hometown Belgrade winter aerials.
Few first shots are with MK okto, all other with S800, Z15 and GH2.
Beograd iz vazduha (zima) (3 min 14 sec)
dragant is offline Find More Posts by dragant
Old Feb 17, 2013, 08:42 PM
UAV.Pilot is offline
Find More Posts by UAV.Pilot
Joined Sep 2012
http://www.youtube.com/watch?v=4y-lJiKEJHA
Bravo...dragant...very good!
I can see you fly very much like I do, fast and very long distances ..
Do you use a Hack with your GH2?
UAV.Pilot is offline Find More Posts by UAV.Pilot
Old Feb 17, 2013, 08:46 PM
Joined Sep 2012
This had me concerned as well..I was thinking did I miss something?
Nope..no need to calibrate the dji esc's
Old Feb 17, 2013, 09:17 PM
Bo Lorentzen is offline
Find More Posts by Bo Lorentzen
FPVpilots do it remotely
United States, CA, West Hollywood
@dragant - outstanding. very clean shots.
Bo Lorentzen is offline Find More Posts by Bo Lorentzen
Old Feb 18, 2013, 01:25 AM
Mac176 is offline
Find More Posts by Mac176
The greatest pleasure in life.
Mac176's Avatar
United States, TX, Pflugerville
Joined Dec 2010
Originally Posted by DJI INNOVATIONS View Post
thanks, exactly!
Thank you for clarifying that for me.
Digitally,
Mac
Mac176 is offline Find More Posts by Mac176
Old Feb 18, 2013, 03:10 AM
dragant is offline
dragant's Avatar
Belgrade, Serbia
Joined May 2010
I use Flowmotion 2.02.
Old Feb 18, 2013, 03:27 AM
jab is online now
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
RANCHER PETE...and anyone that has a gimbal other than the ZEN
Can you show me pictures of your setup, mounting, and results of your S800 video..
I am ready to pull the trigger and invest more money in this dam thing, I have a Sony Nex with some nice glass and accessories already, but I just got my hands on a 5D Mk3 and would love to fly it on my Hexa.
Looking for anyone that can show off their gimbal setup I would really appreciate it..
BTW these Arm Plates are the BOMB! really made a big difference in the way my ship feels and the vibs are gone!
If you are used to the Z-15, any other gimbal is going to feel inferior I am afraid. I spent a lot of time trying to get good results with the CineStar gimbal on a much better frame then the S800, and while I got acceptable results it never was anything close to the performance of a Z-15. And the CineStar gimbal is/was considered the best one, before Z-15 was released. The Z-15 is the one thing DJI got just right from the start..
jab is online now Find More Posts by jab
Old Feb 18, 2013, 03:51 AM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
Here is video of my strange power up beep from M6. Or is it ok like this?
I swapped the arms and I get the same sound from M6. It beeps later than other 5 arms.
(turn up the volume)
s800 power up M6 (0 min 9 sec)
quadslo is offline Find More Posts by quadslo
Old Feb 18, 2013, 04:37 AM
rwijnhov is offline
Find More Posts by rwijnhov
Netherlands
Joined Feb 2009
rwijnhov is offline Find More Posts by rwijnhov
Old Feb 18, 2013, 05:19 AM
HaxK is offline
Find More Posts by HaxK
HaxK's Avatar
Joined Dec 2012
I just re did a new set of arms and had to replace one ESC because I pulled just ever so slightly when I was de-soldering and it pulled the tab clean off. I mean i was shocked it didnt take much at all and it popped right off. If I hadent noticed it as I did it would have quit in the air.
This occurs when too much hot is applied to a trace, you also say that the cable insulation melted. this is a very clear signal of excessive hot applied to the cables itself and cables are much thicker (dissipate more heat) than a PCB trace.
You should lower the tip temperature if your solder has temperature control. If it hasn't , you should buy one specific for electronics with this capability. You have to check melting temperature of the tin also they are formulated for different uses and for delicate electronics you should use low temperature melting tin to avoid damaging traces or components.
I'm being using the JBC SL2020 (photo attached) for years very successfully and you have different tips to fit different tasks.
General use electrical solders are not good for electronics since they deliver too much hot.
HaxK is offline Find More Posts by HaxK
Old Feb 18, 2013, 06:07 AM
Marown is offline
Find More Posts by Marown
Austria, Vienna
Joined Sep 2012
Hello every one again.
I am pritty sad at the moment because my s800 doesnt worke like it should!
At first i am flying on 1.34 not 1.36 so its not the software i think.
When i fly the s800 in attitude mode and i move it in the air forward or in any directions it decents with throttle at 50% !!
This is real pain in the as because i have to push the throttel to 80 or even 100% to get the s800 back up again and prevent from crashing in the ground.
As you can see clearly in this video: you can see it even better in the second forward flight
s800 descent at 50% throttle (1 min 43 sec)
I Balanced my Motors I am flew with very different gains i played with vertical gains and no results.
I am getting really depresst, because i have some important jobs in the next vew months...
Marown
Marown is offline Find More Posts by Marown
Old Feb 18, 2013, 06:16 AM
Stjernefoto is offline
Find More Posts by Stjernefoto
Joined Jul 2012
http://www.youtube.com/watch?v=_SrdU6F3vN0
Marown
Exatly the same problem as i have had, i have replaced the imu with a new one, contact your dealer and let him know your problem, i am sure he will help you.
many has had this problem, and some off the problem can come from vibrations
Regards Lars
Stjernefoto is offline Find More Posts by Stjernefoto
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
