Old Feb 03, 2013, 11:40 AM
rruiz is offline
Find More Posts by rruiz
rruiz's Avatar
Joined Oct 2012
Originally Posted by UAVProducts View Post
Here ya go.
Less than 2 weeks we will have some. Price later in the week.
Anti-vibration pad for S800 (Total Weight with bolt : 27.0g One pair)
Robert
I sent you a PM, put me in the list, I want to buy a set ...
rruiz is offline Find More Posts by rruiz
Old Feb 03, 2013, 11:42 AM
toscatara is offline
Find More Posts by toscatara
toscatara's Avatar
Spain, Murcia, Cartagena
Joined Nov 2012
Originally Posted by consoleworld View Post
That is 6K no 3K .
The weight for 1m is 27.2g ( for 22cm the weight is 6g plus the epoxy )
Christian
which is better 6K or 3K
Option A: http://www.easycomposites.co.uk/carb...eeve-40mm.aspx
Option B: https://shop1.r-g.de/4DCGI/ezshop?ac...COUNT=58304523
thank
toscatara is offline Find More Posts by toscatara
Old Feb 03, 2013, 12:02 PM
consoleworld is online now
Find More Posts by consoleworld
consoleworld's Avatar
Greece, Athina
Joined Nov 2012
Originally Posted by toscatara View Post
For me 3k .
Christian
consoleworld is online now Find More Posts by consoleworld
Old Feb 03, 2013, 12:15 PM
flycoso is offline
Find More Posts by flycoso
Joined Dec 2012
Originally Posted by rruiz View Post
Robert
Idem
L.
flycoso is offline Find More Posts by flycoso
Old Feb 03, 2013, 12:32 PM
apvxtreme is offline
Find More Posts by apvxtreme
aka RacingFPV aka HAMM3RDOWN
Canada, ON, Toronto
Joined Sep 2012
Put me on the list too, I'll take a set!
Here ya go.
apvxtreme is offline Find More Posts by apvxtreme
Old Feb 03, 2013, 05:42 PM
Vlodek9 is offline
Find More Posts by Vlodek9
Vlodek9's Avatar
United States, AZ, Chandler
Joined Sep 2010
Hi all,
Got a quick battery question for the s800 users. I'm looking to get the most flight time out of the S800 so I'm looking for 2 6s batteries with the most mAh to put into parallel. So far I found the Gen Ace 6s 25c 5500 that are the most reasonably priced. But I'm not sure if 25C is the way to go. I'm thinking 40C but the selection is limited and usually by manufacturers that I never used before. For me, this is more of a hobby and I don't see myself opening up a aerial video/photography business so I'm not looking for extremely high end, high price batteries.
So I'm wondering if anyone has flown the S800 on the Gen Ace 25C 5500 batteries and compared it to other batteries with higher C rating. If so please let me know your opinion on the flight time and performance. Was/is there a huge difference?
Also I'm looking for advice from others as to what brand of batteries they recommend and via what reputable vendor they bought them through.
Rob
Vlodek9 is offline Find More Posts by Vlodek9
Old Feb 03, 2013, 06:22 PM
Go4it is online now
Find More Posts by Go4it
Go4it's Avatar
United States, FL
Joined Mar 2004
6300mah is what I use
[/QUOTE]http://www.flying-hobby.com/shop/apl...r-p-10623.html
or
http://www.hobbyking.com/hobbyking/s...dproduct=18210
Go4it is online now Find More Posts by Go4it
Old Feb 03, 2013, 06:41 PM
Squawk is offline
Find More Posts by Squawk
Squawk's Avatar
The Netherlands
Joined Jan 2011
For flight time, lightest solution (not cheap!): http://www.maxamps.com/proddetail.ph...2-Pack&cat=363
That also rises a question.. Is it any safer to use 2x5000 than 1x 10000, or does that not matter?
Squawk is offline Find More Posts by Squawk
Old Feb 03, 2013, 06:57 PM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
Here ya go.
Interesting solution, have you tried it? Does it work well? Would be cool to have 2 red anodized ones and 4 black so it could have the added use of helping with orientation in the day time.
Dolby is offline Find More Posts by Dolby
Old Feb 03, 2013, 09:02 PM
Squawk is offline
Squawk's Avatar
The Netherlands
Joined Jan 2011
Question for GH2 users: which lens do you use with your zenmuse?
The Lumix G14mm/F2.5 or the Lumix G20mm/F1.7 ?
Old Feb 03, 2013, 09:05 PM
rc-mike is offline
Find More Posts by rc-mike
Stay airborne my friends
rc-mike's Avatar
USA, TN, Dickson
Joined Nov 2004
Originally Posted by rc-mike View Post
I have a problem that I can't seem to solve. I get an oscillation when flying at anything more than a walking speed or if it's windy. Sometimes it's not too bad and you can barely see it in the video. Other times it wobbles so much you can hear it and the video is totally unusable. I flew yesterday and it was pretty cold outside and it was terrible. Other days it will hardly happen at all. I normally would assume the gains are too high but I have tried all different settings and it's still there. I have tried putting the gains on a slider an can get it to go from severe to not too bad but it never goes away. Will covering the arms help this? Maybe mounting the IMU differently? I am using a PS1 3XPro V2 gimbal. I would like to have a zenmuse but the funds don't allow that right now. Here is a sample video showing the problem. The gimbal is taking out most of it but you can hear it.
I think I fixed my problem. I moved my IMU to the top of the frame and it is flying much better now. I still need to do a little adjusting but I could tell a huge difference. It was pretty windy after the change and it flew better than it had been in calmer conditions. Later on it calmed down and it flew very well.
rc-mike is offline Find More Posts by rc-mike
Old Feb 03, 2013, 09:59 PM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
That battery is 5C, it works but barely
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Feb 03, 2013, 10:15 PM
banga is offline
Find More Posts by banga
banga's Avatar
Croatia, Slavonski Brod-Posavina, Slavonski Brod
Joined Nov 2009
nice solution
even though carbon reinforced arms looks better. For now i don't have problems with jello but carbon and this look even better then heat shrink tube that i have
what will be the price for solution from picture
banga is offline Find More Posts by banga
Old Feb 03, 2013, 10:50 PM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Doesn't really matter (as long as you know what your doing with lipo's).. 2 x 5000 will be a lot cheaper!
5c is the max charge rate, its a 40c discharge.
topgearuk is offline Find More Posts by topgearuk
Old Feb 04, 2013, 12:41 AM
zzr is offline
zzr
Find More Posts by zzr
zzr
DEAF-POWER
zzr's Avatar
United States, CA, Los Gatos
Joined Feb 2006
Interested! PM you
Here ya go.
zzr is offline Find More Posts by zzr
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 06:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 11:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 02:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 02:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 04:11 AM
