Old Feb 02, 2013, 07:34 AM
Squawk is online now
Find More Posts by Squawk
Squawk's Avatar
The Netherlands
Joined Jan 2011
Originally Posted by helicoblast View Post
90% filming
10% photographing
Thanks Helicoblast!
So I guess it would be be better to use the GH2 since most of the jobs are filming.. (Instead of using a NEX7, which would be better for photo's.)
Squawk is online now Find More Posts by Squawk
Old Feb 02, 2013, 07:39 AM
helicoblast is offline
Find More Posts by helicoblast
Geneva, Switzerland
Joined Jan 2009
I personnaly use different camera, depending on the job: 5D, CX730, Nex5, gopro... and different multicopter.
helicoblast is offline Find More Posts by helicoblast
Old Feb 02, 2013, 08:14 AM
Squawk's Avatar
The Netherlands
Joined Jan 2011
Nice.. but I don't have that luxury yet.. :-)
I have to start with one and must decide between NEX7 and GH2 for now.
Old Feb 02, 2013, 08:21 AM
Geneva, Switzerland
Joined Jan 2009
I would start with the GH2 as it is better for filming, but you also should ask on the aerial photography section, there should be other opinion: http://m.rcgroups.com/aerial-photography-128/
Old Feb 02, 2013, 08:44 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
If you can get away with 30FPS, the GH2 makes the Nex7 video quality look sub-par.
Sid3ways is offline Find More Posts by Sid3ways
Old Feb 02, 2013, 09:12 AM
Squawk's Avatar
The Netherlands
Joined Jan 2011
Thanks guys! :-)
Old Feb 02, 2013, 09:27 AM
Go4it is offline
Find More Posts by Go4it
Go4it's Avatar
United States, FL
Joined Mar 2004
With regards to installing carbon fiber sleeves on the arms of the S800--What size of sleeve to order? It looks like a 1.5in sleeve has a 30% expansion in size and will reduce the size by 70% to help conform around the oject being covered.
So is it 1in or 1.5 or 2in that works the best the people have tried.
Go4it is offline Find More Posts by Go4it
Old Feb 02, 2013, 09:48 AM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
I think it was stated that the 40mm size, about 1.5".
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Feb 02, 2013, 10:06 AM
rc-mike is offline
Find More Posts by rc-mike
Stay airborne my friends
rc-mike's Avatar
USA, TN, Dickson
Joined Nov 2004
1.5" is what I just ordered. Now I just need to figure out the heatshrink size to get. I have some that will just fit over the arms but I think I'll have the problem someone else did where it pushes the CF around when you put it on.
rc-mike is offline Find More Posts by rc-mike
Old Feb 02, 2013, 11:13 AM
Squawk's Avatar
The Netherlands
Joined Jan 2011
People that are using the GH2 under their Zenmuse, what lens do you recommend?
The Lumix G14 F1.7 or the Lumix G20 F2.5?
Old Feb 02, 2013, 11:40 AM
rc-mike is offline
rc-mike's Avatar
USA, TN, Dickson
Joined Nov 2004
I have a problem that I can't seem to solve. I get an oscillation when flying at anything more than a walking speed or if it's windy. Sometimes it's not too bad and you can barely see it in the video. Other times it wobbles so much you can hear it and the video is totally unusable. I flew yesterday and it was pretty cold outside and it was terrible. Other days it will hardly happen at all. I normally would assume the gains are too high but I have tried all different settings and it's still there. I have tried putting the gains on a slider an can get it to go from severe to not too bad but it never goes away. Will covering the arms help this? Maybe mounting the IMU differently? I am using a PS1 3XPro V2 gimbal. I would like to have a zenmuse but the funds don't allow that right now. Here is a sample video showing the problem. The gimbal is taking out most of it but you can hear it.
oscillation (0 min 11 sec)
Old Feb 02, 2013, 11:46 AM
ChasB is offline
Find More Posts by ChasB
Joined Jan 2011
66mm PVC heat shrink (12 ft) for $10.90 on ebay is what I will use.
Haven't tried this technique yet, but once saturated carbon fiber is positioned on the arm one could temporarily secure it to the arm at both ends with small diameter rubber bands until the shrink wrap is properly positioned over the sheath and then partially shrunk in the center of the arm, securing the carbon fiber sheath onto the arm.
Then reach under the ends of the shrink wrap tubing and snip and remove the two rubber bands, and then finish the shrinking out to both ends of the sheath. No guarnatee, and not tested yet, but some means must be used to keep the sheath properly positioned while the shrink wrap is placed over it prior to shrinking, and this might work.
ChasB is offline Find More Posts by ChasB
Old Feb 02, 2013, 12:18 PM
rc-mike is offline
rc-mike's Avatar
USA, TN, Dickson
Joined Nov 2004
I just checked and that is the same size as the heatshrink I have that is pretty tight fitting around the base of the arm. I guess if I can get it over that without moving things I'll be okay since the rest of the arm is much smaller. I think I got what I have now at the hobby shop and it was used for covering batteries.
Michael
Old Feb 02, 2013, 12:28 PM
badbill is online now
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
I'm going to try THIShttp://www.experiencerc.com/store/qu...8-p-13854.html If it looks ok I will just leave it on there.
Bill Davenport
AMA 28141
badbill is online now Find More Posts by badbill
Old Feb 02, 2013, 04:54 PM
rancherpete is offline
Find More Posts by rancherpete
Joined Dec 2011
http://www.youtube.com/watch?v=PTxGFrisGJI
Have you performed a compass calibration recently? I had the same problem a couple of different times and I found that everything worked better after a fresh compass calibration. Just a though.
rancherpete is offline Find More Posts by rancherpete
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
