Joined Sep 2012
Will you also tell us exactly what you use, please? |
Found a alu case for s800 from RP Innovations
http://www.facebook.com/media/set/?s...7745924&type=1 looks like oem case like the ones on the preordered s800 |
Did they could do it for zenmuse ? Thanks |
Queens, NY and sometimes Orlando, FL
Joined Sep 2003
I run everything on 4s from land, sea or air, so I was hoping I wouldn't have to invest in new packs when I step up to an s800
It should work on 4s if you fly with two in parallel? they should provide enough lift, it depends on your payload I would imagine if you were carrying a camera and gimbal it would struggle, also you may find it not as stable on 4s as the motors wouldn`t react quick enough to error unless you bought some of Dennys prop adaptors and run 11 x 4.7 props..
Romania, TM, Timisoara
Joined Mar 2008
No 4S would not work. You would barely be able to lift the S800 alone if at all. Also you cannot use bigger props as there is not enough clearance. I am afraid the S800 is designed around 6S. On a custom build ship you can calculate the motor RPM and adjust the prop accordingly. There you have some room. But as soon as you set it up it will run best at a certain Voltage. There are no universal copters that run with the same setup on different cell counts. +- 1 cell might be doable to a certain degree but 2 cells difference is a lot. It's a lot even when you compare 10S to 12S in a big heli. But 4S to 6S is an increase of 50% which is HUGE. At least this is my experience. |
Joined Mar 2008
But to put it simple everything you just said in your last 2 posts is wrong. Sorry. |
| Thread Tools | |
| Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble | jasper7821 | Multirotor Talk | 219 | Oct 16, 2012 05:11 PM |
| New Product DJI Spreading Wings S-800 Hexa multi-rotor | sidneyw | Multirotor Talk | 930 | Jun 22, 2012 10:14 AM |
| Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! | tpnitro | Multirotor Talk | 120 | Jun 19, 2012 01:27 AM |
| Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters | QuadcoptersUk | Multirotor Talk | 8 | May 14, 2012 01:27 PM |
| Discussion Dji Spreading Wings (S800) coming | Huluhulu | Multirotor Talk | 7 | Apr 27, 2012 03:11 AM |
