Old Nov 20, 2012, 09:10 AM
UAV.Pilot is offline
Find More Posts by UAV.Pilot
Joined Sep 2012
I flew mine in Big Bear CA, at 7000' msl 75 degrees F at 6.12kg flying weight and it struggled hard...I was embarrassed and was just hoping to get it back on the ground, you know its bad when your throttle stick is nearly full throttle to stop the decent. The only way I found I was comfortable flying it was unloading the 2x 8000's for 1x 5800.
Having told you of my experience I do believe a better set of props would certainly help out.
UAV.Pilot is offline Find More Posts by UAV.Pilot
Old Nov 20, 2012, 09:17 AM
Joined Sep 2012
Originally Posted by filmer View Post
I fly my hexa carbon frame with zenmuse but without landing gears.
Zero vibrations.
Total weight is 4,7kg with one 5000mah 6s and flight time 7 min.
Or with 2 lipos, total weight is 5,4kg and it can fly for 13-14 min.
... and landing at 20% battery remain.
For start I use a platform, for landing I mounted a very light weight hand-held on left copter arm, I take it easily and going down with motor stick, after 3 seconds copter will swtich off automatically!! Super easy.
http://www.youtube.com/watch?v=ZF5S_...1&feature=plcp
Very Nice! Indeed...
Old Nov 20, 2012, 09:20 AM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
There was talk about new props a few months back but nothing since. I think the GPS problem took more time than they anticipated.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Nov 20, 2012, 09:31 AM
AEMontoya is offline
Find More Posts by AEMontoya
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Originally Posted by Iceman575 View Post
It's not another 900gr. You remove the old landing gear which weight about 500gr. So the retracts add about 350gr. It is quite something but not as bad as 900...
According to hex junky, the weight of the battery tray would also need to be subtracted, making the the retract unit even lighter than ~350 g.
AEMontoya is offline Find More Posts by AEMontoya
Old Nov 20, 2012, 09:37 AM
Joined Sep 2012
I agree!
Old Nov 20, 2012, 09:39 AM
Iceman575 is offline
Find More Posts by Iceman575
Romania, TM, Timisoara
Joined Mar 2008
To be honest I did not weight my complete landgin gear with battery tray as i have everything mounted on it. I know that the complete landing gear is about 500. Might be more with battery tray. The main idea is that while the retracts add some weight it is not all that bad...
Besides we will only know the exact weight difference as soon as somebody get's his retracts. I am fighting with myself whether to get them or not... Not quite cheap but they are nice... If i get them i can write all the details next week
Iceman575 is offline Find More Posts by Iceman575
Old Nov 20, 2012, 10:38 AM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
Originally Posted by Tahoe Ed View Post
My friend in CO flies at 6500' and has issues with the AUW at 7kg. Now I have flow at that altitude but not fully loaded with Z15, iOSD, vTx, 2x6S 5000mAh lipos, I just got my scale back from Tahoe and I am going to check the weight. I am not sure if have room for another 900g.
I would be interested to know, it's one reason to go with a single battery?, what is the weight of your 2 6s?. I am using a single maxamps which is around 1.2 kgs
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Nov 20, 2012, 11:06 AM
Button2011 is offline
Find More Posts by Button2011
Austria, Wien, Vienna
Joined Jun 2011
Originally Posted by renricker7 View Post
as you might know, is it not the same to everyone ...
it depends on the position of the IMU where you mount your battery tray, the weight of your batteries and the position of the gimbal ...
it pretty much differ from copter to copter.
so, it might be better figure out where the COG is and to go from there
sorry not to be more of a help!
rené
Thanks for your reply.
I'm aware that the COG differs from Copter to Copter, but what is the most efficient way to get the Z-Value of the COG?
Button2011 is offline Find More Posts by Button2011
Old Nov 20, 2012, 12:20 PM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
Flip it on its side and do the same thing you would to get the cog with it flat.
If you have something connecting a top plate to a bottom I find getting a hook around that and moving it up and down as required is the easiest way.
The Recursion is offline Find More Posts by The Recursion
Old Nov 20, 2012, 12:21 PM
renricker7 is offline
Find More Posts by renricker7
Germany, SA, Halle Saale
Joined Nov 2012
you might find some help over here:
http://www.rcgroups.com/forums/showp...ostcount=11566
and here
http://www.rcgroups.com/forums/showp...ostcount=11562
rené
renricker7 is offline Find More Posts by renricker7
Old Nov 20, 2012, 12:57 PM
rsun77 is offline
Find More Posts by rsun77
Danmark, Sjælland, Gørlev
Joined Jul 2008
I do remember something about the size/class of you SD card. If it is to small the camera have to work to mush with its own memory.
I think the manuel says something about it.
Originally Posted by UAV.Pilot View Post
QUESTION FOR ALL THAT USE THE SONY NEX5N
Does anyone here see the over heat and their camera's shut down when recording video?
Mine does and I read all over the Net about this issue, this problem is what is holding me back from buying the Z-15 for Nex gimbal, and the GH2 has its own set of issues from what I read.
rsun77 is offline Find More Posts by rsun77
Old Nov 20, 2012, 01:16 PM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
I was wondering what would happen to the COG if the landing gear legs are uP?
Will it change?
If you hang the copter to its side with the legs extended the COG will be different than when the legs are retracted. Right?
Cheers
bcollydas is offline Find More Posts by bcollydas
Old Nov 20, 2012, 01:24 PM
Joined Nov 2012
should be, but i wouldn´t worry to much abou it, cause it won´t change to much ...
rené
Old Nov 20, 2012, 01:32 PM
Joined Mar 2008
This whole COG issue took a much more serios turn than it should have. It is not vital for the system to have 100% accurate values. At least that is my experience. The Z axis i always guesstimate. And so far my S800 flies very well...
Old Nov 20, 2012, 02:56 PM
Joined Sep 2012
THANK YOU, i have tried several sd cards, all class 10, now the latest one i just bought 32GB 45mbs class 10 Extreme, i was able to get 16 minutes before it got the over heat icon and shut down. This was in outside temps of 70 degrees F.
I just did the mod of removing the back sticker to reveal the vent holes behind the screen, it helped but still
My camera is a Brand New Nex 5N with the latest revision firmware.
I am ready to buy the z-15 gimbal but for this camera I am really concerned and would like to get this 5N figured out before i go any further...even tried calling sony..they were no help and just said send it in..
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
