Old Nov 20, 2012, 03:12 AM
rsun77 is offline
Find More Posts by rsun77
Danmark, Sjælland, Gørlev
Joined Jul 2008
What is the X60 power wire for... ???
Originally Posted by paul.guo View Post
The retracting landing gear is designed for the S800 frame in order to provide a better perspective in aerial-filming / photography work. By using a 2-position switch channel of the R/C transmitter, users can control the landing gear to retract remotely. The retracting landing gear will not block the view of the camera lens, making smooth shooting in all directions possible. Includes Servos and control PCB.
Specifications
Working Voltage: 3S~6S (LiPo)
Input Signal: PWM (High-Pulse Width 800us~2200us)
Working Current: Max 1A@6S
Output Signal: PWM(Neutral Position is 1520us) in 90Hz
Working Temperature: -20~70oC
Output Voltage: 7.2V (For HV Servo Only)
Total Weight: 875g
Servo Travel:150 o (Minimum120 o)
rsun77 is offline Find More Posts by rsun77
Old Nov 20, 2012, 03:20 AM
hex junky is offline
Find More Posts by hex junky
Joined Jul 2012
It is power to the onboard control board. See my earlier post.
hex junky is offline Find More Posts by hex junky
Old Nov 20, 2012, 04:00 AM
zzr is offline
zzr
Find More Posts by zzr
zzr
DEAF-POWER
zzr's Avatar
United States, CA, Los Gatos
Joined Feb 2006
Controller calibrates is very cool. Where you ordered it?
Originally Posted by hex junky View Post
The retracts come with 2 HV servos fitted and a very small neat controller that automatically calibrates the end points and also switches servo power off after 3 seconds of reaching the end position. If it senses a high servo current while retracting then it will lower the legs again. I had a long chat to DJI about this...now mine are ordered
zzr is offline Find More Posts by zzr
Old Nov 20, 2012, 05:26 AM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
So If we are limited to 7Kg of AUW then with the gear it will be much higher if it weighs 900Gr.
Then we have to eliminate on e battery if we are running parallel, right?
bcollydas is offline Find More Posts by bcollydas
Old Nov 20, 2012, 05:30 AM
banga is offline
Find More Posts by banga
banga's Avatar
Croatia, Slavonski Brod-Posavina, Slavonski Brod
Joined Nov 2009
Finding CG on S800+Zenmuse+GH2+6S 10000mAH. I suppose that zenmuse need to be power up if not it will hang and distrub CG( I will get inaccurate postion of CG)?
Where is the best way to tie a rope?
Tnx
banga is offline Find More Posts by banga
Old Nov 20, 2012, 05:56 AM
Joined Jul 2012
The AUW with GH2 will be just over 7kg
Old Nov 20, 2012, 06:13 AM
Button2011 is offline
Find More Posts by Button2011
Austria, Wien, Vienna
Joined Jun 2011
What values do you guys have for the imu mounting position with gh2 zenmuse?
Button2011 is offline Find More Posts by Button2011
Old Nov 20, 2012, 08:05 AM
renricker7 is offline
Find More Posts by renricker7
Germany, SA, Halle Saale
Joined Nov 2012
as you might know, is it not the same to everyone ...
it depends on the position of the IMU where you mount your battery tray, the weight of your batteries and the position of the gimbal ...
it pretty much differ from copter to copter.
so, it might be better figure out where the COG is and to go from there
sorry not to be more of a help!
rené
renricker7 is offline Find More Posts by renricker7
Old Nov 20, 2012, 08:39 AM
wingo1 is offline
Find More Posts by wingo1
Joined Aug 2012
My crystal ball says by the new year DJI will have V3 out with new stronger arms...here we go again!
wingo1 is offline Find More Posts by wingo1
Old Nov 20, 2012, 09:28 AM
UAV.Pilot is offline
Find More Posts by UAV.Pilot
Joined Sep 2012
So I reworked the cheesy xcraft gopro gimbal and ditched the little futaba servos for some Futaba S9350, what a difference!
Flew it yesterday which marks the 94th flight on my S800...
Today will upgrade the firmware and give it a go...wish me luck!
UAV.Pilot is offline Find More Posts by UAV.Pilot
Old Nov 20, 2012, 09:37 AM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
DJi states max weight for s800 is 7 KGs
Have they tested this at 5000 asl in the mountains? Will it fly?
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Nov 20, 2012, 09:38 AM
Joined Sep 2012
QUESTION FOR ALL THAT USE THE SONY NEX5N
Does anyone here see the over heat and their camera's shut down when recording video?
Mine does and I read all over the Net about this issue, this problem is what is holding me back from buying the Z-15 for Nex gimbal, and the GH2 has its own set of issues from what I read.
Old Nov 20, 2012, 09:42 AM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
My friend in CO flies at 6500' and has issues with the AUW at 7kg. Now I have flow at that altitude but not fully loaded with Z15, iOSD, vTx, 2x6S 5000mAh lipos, I just got my scale back from Tahoe and I am going to check the weight. I am not sure if have room for another 900g.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Nov 20, 2012, 09:51 AM
Iceman575 is offline
Find More Posts by Iceman575
Romania, TM, Timisoara
Joined Mar 2008
It's not another 900gr. You remove the old landing gear which weight about 500gr. So the retracts add about 350gr. It is quite something but not as bad as 900...
Iceman575 is offline Find More Posts by Iceman575
Old Nov 20, 2012, 10:00 AM
filmer is offline
Find More Posts by filmer
Joined Oct 2011
I fly my hexa carbon frame with zenmuse but without landing gears.
Zero vibrations.
Total weight is 4,7kg with one 5000mah 6s and flight time 7 min.
Or with 2 lipos, total weight is 5,4kg and it can fly for 13-14 min.
... and landing at 20% battery remain.
For start I use a platform, for landing I mounted a very light weight hand-held on left copter arm, I take it easily and going down with motor stick, after 3 seconds copter will swtich off automatically!! Super easy.
DroneFly D6 (5 min 4 sec)
filmer is offline Find More Posts by filmer
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 06:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 11:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 02:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 02:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 04:11 AM
