Old Nov 19, 2012, 05:30 AM
Aaalie is offline
Find More Posts by Aaalie
Aaalie's Avatar
Netherlands
Joined May 2006
Aaalie is offline Find More Posts by Aaalie
Old Nov 19, 2012, 07:39 AM
semich is offline
Find More Posts by semich
Portugal, Lisbon, Cascais
Joined Mar 2010
Discussed with DJI today and they say that 5.16 should be reliable even after what I have mentioned. They do mention that some people might have different versions of ESC's and that could cause the melody not to be in sync, and if the hexa is unstable, it shouldn't be because of the FW... I don't totally agree with that since people who confirmed this doesn't complain anymore while coming back to 5.14. But this is just FYI.
I'm related to programming, debugging software etc.. and in my point of view, I don't understand why adding new features like they do those new FW could cause issues, as they are probably adding new code and not modifying something that already work, of course change can bring regressions, but... we don't know what is being change...
semich is offline Find More Posts by semich
Old Nov 19, 2012, 07:50 AM
Iceman575 is offline
Find More Posts by Iceman575
Romania, TM, Timisoara
Joined Mar 2008
Well see and here is the problem. I have no issues at all with the new Firmware and it works quite a lot better then 5.14. Not to mention the fact that now i have no more white flashes.
I am working as a programmer full time and i can tell you that if the circumstances are correct pretty much any program can have issues. For them it seems that the different versions of ESC, compass, MCU and IMU is affecting their code somehow...
Iceman575 is offline Find More Posts by Iceman575
Old Nov 19, 2012, 07:54 AM
semich is offline
Joined Mar 2010
Possible... should we build a new table? lol
Old Nov 19, 2012, 07:57 AM
Joined Mar 2008
Well i am all stock. Never changed or send anything to be replaced. All ESC are V4. Old type GPS/Compass. MCU and IMU i have no idea but they work
Using Denny adapters with 15x5 XOAR. Reinforced arms (getting laminated with carbon sleeves this week )
Old Nov 19, 2012, 08:01 AM
semich is offline
Joined Mar 2010
Mine crashed, one motor stopped and start to spin and landed hard! Sent to DJI, got everything new... so I'm stock also and latest versions also (2 weeks ago). Will test this afternoon version 5.16. with Zenmuse and OSD.
Old Nov 19, 2012, 11:13 AM
Button2011 is offline
Find More Posts by Button2011
Austria, Wien, Vienna
Joined Jun 2011
I just read about the "out of sync" problem.
Are you guys, who have this Problem with M6 out of sync, having the V2 of the Wookong?
I just ask, because the "waiting 30 Minutes" indicates that there is something with electrical charging, like a capacitor, and as we know the resistor values of the V1 Wookong are different for some ports, including M6 as well, if I remember correctly...
I just ask before updating my S800 and F550
Button2011 is offline Find More Posts by Button2011
Old Nov 19, 2012, 11:15 AM
Mac176 is offline
Find More Posts by Mac176
The greatest pleasure in life.
Mac176's Avatar
United States, TX, Pflugerville
Joined Dec 2010
Has anybody upgraded to 5.16 firmware and had one of the arms (M1 in my case) have the led come on at power up (plug in the battery) and the beeps be out of sync or echoing?
I went beck to 5.14 firmware and the echoing goes away but the light still comes on no matter where I move the arm . i.e. M3 or M5.
Digitally,
Mac
Mac176 is offline Find More Posts by Mac176
Old Nov 19, 2012, 11:31 AM
jukusa is offline
Find More Posts by jukusa
Joined Aug 2012
i have v2 wookong, all value ports are around 1.10. If i have one port which has a different value, i think my s800 has already flipped
The issue out of sync for me happens only on 5.16, not on 5.14
jukusa is offline Find More Posts by jukusa
Old Nov 19, 2012, 11:36 AM
jukusa is offline
Joined Aug 2012
Originally Posted by Iceman575 View Post
So after reading about many problems with 5.16 i went out today to try it myself. My S800 has all 6 V4 from factory. Denny adapters and 15x5 XOAR props. Also square carbon silliconed under the arms.
My conclusion after about 30 min of flight.... BEST FIRMWARE so far.
No more white flashes. Well i got it once in 30 min but i was at max roll in GPS atti mode and let go suddenly. I kind of expected white flashes then. However when you let it go suddenly in GPS it brakes more smoothly. Also GPS and altitude is rock solid. Flew for 10 min only in GPS mode and no drifting at all.
Also the manual mode is much improved. Now i can actually fly it in manual mode. Before it had some very strange tendencies.
The whole copter feels more locked in. I really don't know what was changed in the firmware but for me it is a very big improvement. Not that it was bad before but now it is the best Flightcontroller i use.
I am using the gains that the manual states for the S800 without Zenmuse. I am flying with the Zen and some other gadgets. AUW 6.93 KG
So in short i am very very happy with the new firmware and so far have encountered no bugs what so ever.
PS. All the motors(esc's) are in perfect sync on powerup.
hi, want to know once you have upgraded to 5.16, you set on the default gain (autopliot) and adjust in fly or you set immediately on dji recommend gain?
Because for me, i set the 100 100 100 100 all, and i adjust in fly, is it correct?
Or should i set like 200 200 150 190 at first ?
Old Nov 19, 2012, 11:37 AM
Taszz is offline
Find More Posts by Taszz
The Netherlands, NH, Kudelstaart
Joined Jul 2012
Cool
Taszz is offline Find More Posts by Taszz
Old Nov 19, 2012, 11:45 AM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
PolynÚsie franšaise, ╬les du Vent, Papeete
Joined Mar 2010
nice but really expensive and no servos !!!! http://www.flashrc.com/dji_innovatio...ans_servo.html
flytahiti is offline Find More Posts by flytahiti
Old Nov 19, 2012, 11:48 AM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
I have to say that those 15x5 Xoars work well with my adapters. My dev. model here has more than 250 flights on it now and it's steady as a rock. and now running 5.16
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Nov 19, 2012, 11:50 AM
jukusa is offline
Joined Aug 2012
is it a joke 627 euros?
Old Nov 19, 2012, 11:52 AM
Taszz is offline
Joined Jul 2012
Yes verry expensive
with servo
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
