Old Jul 06, 2012, 02:43 PM
RTRyder is offline
Find More Posts by RTRyder
Registered Lunatic
RTRyder's Avatar
Boston, MA
Joined Jul 2010
Originally Posted by sidneyw View Post
Longer motor leads and ESC leads have always present problem. That's why the leads are not as long as in S-800. The same apply to the ESC we use is not over the counter type. It is the combination of S-800 ESC and MC.
If WKM users have esc under the motor using original ESC wire length, I don't see a problem. What do you want DJI to do?
Replace ALL of the older units that may be affected, not just the ones currently on S800's. What if someone that has an older unit decided to buy an S800 six months from now, then they're screwed (as usual) because this "deal" only lasts for 60 days.
Both of my WKM are from last August/September timeframe, so I guess if I should buy a S800 I just have to take my chances? I guess I won't be buying one then, not going to risk having this problem crash it and then be told, sorry, too late. I'm certainly not going to pay out the price of a new WKM just to make sure it doesn't happen either...
RTRyder is offline Find More Posts by RTRyder
Old Jul 06, 2012, 03:03 PM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
I think what Sydney is saying is that all WKM users should just check and make sure everything is ok. I'm sure if you purchased an S800 (have to show proof) and you have a WKM that qualifies for a replacement, DJI will honor that. It's common sense guys, DJI is doing well with customer service and they will make it right.
shdwkeeper is offline Find More Posts by shdwkeeper
Old Jul 06, 2012, 03:49 PM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
PolynÚsie franšaise, ╬les du Vent, Papeete
Joined Mar 2010
i have just check my MC and F1 to M6 are all 0.61 not 0.93 as we can see in the video is it a problem?
flytahiti is offline Find More Posts by flytahiti
Old Jul 06, 2012, 04:09 PM
Spyde is offline
Find More Posts by Spyde
Denmark, Region Zealand, Jyderup
Joined Jun 2010
Yea all mine was 1.048
Spyde is offline Find More Posts by Spyde
Old Jul 06, 2012, 04:14 PM
skivvie is offline
Find More Posts by skivvie
skivvie's Avatar
United States, UT, Draper
Joined Aug 2011
I'm by no means an electrical engineer, but I just don't get this... As I was taking my ESC's off to send in for replacement I finally took a close look at something I noticed when I first got the S800. The wires coming out of the arm to the ESC are bare copper... and they cross and touch. Why go through the effort of separating them in the arm to just have them cross at the ESC? Is this normal or YAD (yet another defect)? If normal, can someone explain the current situation? If I have ground and positive crossing over here how does this function. Thanks =]
skivvie is offline Find More Posts by skivvie
Old Jul 06, 2012, 04:36 PM
hex junky is offline
Find More Posts by hex junky
Joined Jul 2012
They are not bare copper, they are coated....not conductive. The ends have the coating removed i.e. silver colour.
hex junky is offline Find More Posts by hex junky
Old Jul 06, 2012, 04:47 PM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
If you own S-800 requiring ESCs change you will get OSD transmitter free. Only the transmitter and only 5.8 Ghz 500mw; no receiver. Likely we will ship the transmitter with battery tray.
Thanks Sid. Do we have to do anything or you will ship to S-800 owners anyway.
My crash cost me one arm, and motor.
You do keep records on the S-800 owners?
bcollydas is offline Find More Posts by bcollydas
Old Jul 06, 2012, 05:28 PM
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
To ensure the MC is manufactured before February 2012, an instruction is attached for easy verification.
I got mine on 10/2/2012 is there a date stamp on the unit to verify when it was manufactured? or we just do the test like the video?
Cheers
Old Jul 06, 2012, 05:30 PM
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
Just make sure when you take them off with the tweezers you don't remove the coating and when you resolder the new ESC, make sure the wires don't touch each other and you should be fine..
Cheers
skivvie is offline
skivvie's Avatar
Joined Aug 2011
Indeed. I guess I should a: put my glasses on (I thought the silver was just solder) and b: have tried it with a multimeter. Thanks... feelin' dumb =]
Old Jul 06, 2012, 07:31 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
We are revising the manual in S800 to include checking WKM MC readouts, and advise S-800 owners to replace the MC. The 60-days is an attempt to fix all the current S-800 issues.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Jul 06, 2012, 07:44 PM
flytahiti's Avatar
Joined Mar 2010
hi sidney
i read always 0.61 with tester in diode mode on F1 to M6 .is it OK ?
.if it is i still don't have the explanation of all the problems we have with the S800
(sudden increase or loss of power and some time instability) .
ESCs are hot and we will change them but i'am not sure the problem wil be solved.
Old Jul 06, 2012, 07:50 PM
sidneyw is offline
Originally Posted by flytahiti View Post
hi sidney
Yes, the MC is the current version; no issue.
Problem you have or others have??
Change the ESC, before you can say that.
Site Sponsor
iheli22 is offline
Find More Posts by iheli22
Wings that Swing
iheli22's Avatar
United States, NC
Joined Jan 2012
To test the WKM - MC as previously posted, Do you First have to remove all the Servo and ESC leads to the MC, or can you leave them in while testing F1, F2 & M1 etc...
iheli22 is offline Find More Posts by iheli22
Old Jul 07, 2012, 12:08 AM
Hangerash is offline
Find More Posts by Hangerash
Orange County Ca
Joined Nov 2003
We have the exact same issue as do many others here we have checked with.
No stability in winds of any kind, as well as very erratic altitude behavior.
Have you found updated ESCs will remedy this ?
Hangerash is offline Find More Posts by Hangerash
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
