Old Oct 15, 2012, 08:45 PM
AEMontoya is offline
Find More Posts by AEMontoya
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
So, is there a lightweight, non-permanent, non-electrically conductive, good heat conductive sealant (like some type of RTV) that can be spread over the ESC components?
AEMontoya is offline Find More Posts by AEMontoya
Old Oct 15, 2012, 08:54 PM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
The problem is for me and I am sure lots of others is that if I have a crash while on a commercial photo shoot I legally have to report this to the aviation authorities with all details of the crash. I wonder how it would seem to them if s800 if there proves to be a system with a documented history of unreliability. The authorities could easily decide not ever approve a flight with the S800 for any professional work.
Has DJI considered that possibility?
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Oct 15, 2012, 09:41 PM
Joined Apr 2012
Wasn't there something like that in the first version of the esc, I remember people complaining about having to remove it to replace the esc
Old Oct 15, 2012, 09:43 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Maybe I am missing something here. There have been several posts about having the esc mounted at the end of the arm and vibrations effecting the solder joints, if I am reading them right. But aren't the esc's and the wire vibrating at the same rate, they are part of the same arm? I replaced my esc's after the recall. I have not had an issue yet and I am not saying it will never happen. I did not put any shrink wrap on the varnished wires when I redid the esc's. I am hoping that was not a mistake since the wires do rub and vibration could cause them to short. I think that there needs to be more CSI work to determine the cause of many of these crashes.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Oct 15, 2012, 09:49 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
There was a thick conformnal coating that was a PITA to remove to do the esc mod. I just used a commercially available coating to cover the contacts after I was done.
Site Sponsor
Old Oct 15, 2012, 09:51 PM
UAV.Pilot is offline
Find More Posts by UAV.Pilot
Joined Sep 2012
OK so I flew mine all day today, 8 full batteries each flight getting aprox 14 mins. with the temps reaching 95 F.
Last flight in Attitude Mode it started feeling twitchy, started to get a lot of white flashes and for a second felt Like I was not in control...
For a gimbal test I flew it to the extremes of the gimbal, it got a ton of flashes, whites, reds..
As soon as I settled it down the flashes stopped and all resumed normal..
THIS SUCKS TO SEE SO MANY CRASHES...
You can view this test here, but watch it in 720 HD...
Gimbal and WKM Test
UAV.Pilot is offline Find More Posts by UAV.Pilot
Old Oct 15, 2012, 10:06 PM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
PolynÚsie franšaise, ╬les du Vent, Papeete
Joined Mar 2010
what props are using ?
flytahiti is offline Find More Posts by flytahiti
Old Oct 15, 2012, 10:17 PM
Joined Sep 2012
Very well balanced Stock DJI Carbon...
I cranked it so hard today i almost did a loop!
At this point I want it to fail in my controlled environment and not on a Set! That is if I can make it...
Old Oct 15, 2012, 11:00 PM
Mac176 is offline
Find More Posts by Mac176
The greatest pleasure in life.
Mac176's Avatar
United States, TX, Pflugerville
Joined Dec 2010
S800 specs for the temps on the motors and ESC.
Hello All,
Does anyone know what the specs are for the temps on the S800 motors and ESCs?
I did 3 run-ups today with my S800/WK-M and got what think are some high temp on 3 of my motor and ESCs. The odd thing is that they were the CCW or O motors.
I attached my chart if you would like to see it.
I weighted my aircraft down with sandbags and ran it up for 7 minutes at 60% throttle in manual mode. The amp and voltage draws were all in spec.
There was little to no wind.
I was running 2 new Gens Ace 5300 6S1P 30C batteries.
After shut down and within 2 minutes I logged all the temps.
Here is what I got: motor/ESC
Run-up Test 1
Ambient temp 80
High amp draw 35A
M1-135/123
M2-133/106
M3-163/123
M4-115/102
M5-159/120
M6-107/102
Run-up Test 2
Ambient temp 72
High amp draw 33A
M1-134/113
M2-108/100
M3-156/119
M4-109/95
M5-147/120
M6-102/97
Run-up Test 3
Moved arms 1 position CCW to see if temps followed motors (they did) i.e.
1-3, 2-4, 3-5, 4-6, 5-1, 6-2
Ambient temp 72
High amp draw 29A
M1-130/115
M2-100/93
M3-131/109
M4-107/97
M5-152/115
M6-107/99
Does anybody have any thoughts on why this might be happening with the CCW arms?
Thanks for your time!
Digitally,
Mac
Mac176 is offline Find More Posts by Mac176
Old Oct 15, 2012, 11:05 PM
blbills is offline
Find More Posts by blbills
Joined Jul 2008
Does anybody have and thoughts on why this might be happening with the CCW arms?
Yep, there is a yaw offset the the CCW arms are working hard to cancel out. This is usually caused when an arm/motor is twisted.
blbills is offline Find More Posts by blbills
Old Oct 15, 2012, 11:12 PM
Mac176 is offline
Mac176's Avatar
Joined Dec 2010
Wow! So out of the box it has a twisted arm(s)? Probably the one that is running hotter than the rest?
Digitally,
Mac
Old Oct 15, 2012, 11:18 PM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Digitally,
Mac
The motors are shimmed at a slight angle.
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Oct 15, 2012, 11:23 PM
Mac176 is offline
Mac176's Avatar
Joined Dec 2010
Hmm.. So tomorrow I should do the same test at a hover and see what the temps are?
Anybody got anything on the specs for the temps? Like what is too hot and my cause issues down the road?
Digitally,
Mac
Old Oct 16, 2012, 12:58 AM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
100C would be too hot. Better to be at 75C or less. We got one of the first batches of ESC and they ran very warm. Of course... we're in the Sonoran Desert where ambient can easily reach 47C. The v2 ESC we got did run about 30% cooler so that was good to see.
Photoship One is offline Find More Posts by Photoship One
Old Oct 16, 2012, 01:36 AM
flytahiti's Avatar
Joined Mar 2010
when used with 14x8 graupner ESCs stay really cold 40c because pitch is hight at the center and motors and ESCs are in the air flow
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
