Old Oct 12, 2012, 04:29 PM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
I am wondering what batteries people are flying with I would like too put 2 in parallel, but need the lightest weight to power ratio, anyone have any good suggestions
thanks
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Oct 12, 2012, 04:46 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
thanks
In my opinion the sweet spot for the S800 is a single 6S 8000 30C from HobbyKing. With the Z15 and 5N on board I still get 15-18 minutes of hovering for AP work. I had the battery plugged in for about 30 minutes of flying up and down and then physically moving the copter to a new spot to take off. I was very happy with the results. Having 4-5 of these charged and ready to go should be more than enough for the average shoot. Hell the sorry ass battery on the Sony 5N barely lasts an hour of use anyways.
Sid3ways is offline Find More Posts by Sid3ways
Old Oct 12, 2012, 04:50 PM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
You get 15 - 18min with a 6S 8000 30C? I have that same battery and setup with not the same result, what are you letting the voltage get down to?
Thanks.
Dolby is offline Find More Posts by Dolby
Old Oct 12, 2012, 04:52 PM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
I have the Quanum telemetry plugged into the balance port of the lipo and when 1 cell gets down to 3.4 volts I start to bring it in.
This was not with aggressive flying around. This was AP work as I stated, pretty much straight up and down flying.
Old Oct 12, 2012, 05:24 PM
Raggarn is offline
Find More Posts by Raggarn
Photographer in Stockholm
Raggarn's Avatar
Joined Sep 2012
@Sid3ways, 15+ minutes?
OMFG!
I have the same setup ( stock props) and get 9-10 min before safety landing. Then ive spend 6000 mAmps.
Raggarn is offline Find More Posts by Raggarn
Old Oct 12, 2012, 05:28 PM
Dolby is offline
Needs more bacon!
Dolby's Avatar
Joined Jan 2011
Huh yeah I do 3.4v as well and when I had my 16mm lens on the nex5 I got about 12min max. Now with the CZ 24mm I get about 8 - 10min. Wonder whats different with our rigs. I would get 15+min if I took the Z15 off and switched to my AV130.
Old Oct 12, 2012, 05:34 PM
c130pilot is offline
Find More Posts by c130pilot
c130pilot's Avatar
Joined Dec 2004
For those running two 5000MAH+- packs in parallel, have you used 12ga wire for the parallel harness? I ordered a parallel charging cable which I intended to cut and solder up to the S800, but it's 12ga for the main lead and 14ga for the wires going to each battery. The battery wires are also 12ga so I'm concerned that 14ga won't cut it. Any thoughts?
Tim
c130pilot is offline Find More Posts by c130pilot
Old Oct 12, 2012, 05:41 PM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
Originally Posted by UAV.Pilot View Post
Does it do it in Flight?
Yes, also in flight, on one motor.
Had the same problem on other copter, I changed the prop there and it was ok.
I have to switch the props from motor to motor and reduce gains to see if it helps.
Originally Posted by Paul@SCC View Post
Have you tried without the prop adaptor?
With DJI props I could go full throttle on the ground and no vibes
quadslo is offline Find More Posts by quadslo
Old Oct 12, 2012, 05:44 PM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
PolynÚsie franšaise, ╬les du Vent, Papeete
Joined Mar 2010
i don't know if it is the fact of the new 5.14 firmware but we don't have registered any new FOD in this thread . i hope i'm not wrong! even if many people have many white flashes
flytahiti is offline Find More Posts by flytahiti
Old Oct 12, 2012, 06:32 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
Tim
I used 12 awg for everything and got rid of the main connector to be on the safe side...
c3d76 is offline Find More Posts by c3d76
Old Oct 12, 2012, 06:35 PM
Capo Creative is offline
Find More Posts by Capo Creative
Joined May 2012
Originally Posted by c3d76 View Post
I'm sure you mean 23.69, not 13.69
I fly 2x 5000mah 6S 25c Zippy, and this is what I have mine set at for now (see attachment). I set my timer for 12 min and have not hit second level protection yet. First level starts around 10min...
It seems that your loss is also around .60v since you get the first level warning at 23.1v and after landing/checking you are actually at 23.69v...
Yep, I meant 23.69. Thank you for the screenshot! I just went out and tested your exact settings on my rig, only with 1 battery to see how that would do. I still saw the first level warning come on super early, something like 2.2 minutes in. At that point, I hovered for an additional 4 minutes in first level warning, before it switched to second level and landed itself (i was hovering VERY close to the ground in home position for safety). It just seems like the 1 level warning is coming on WAY too early. Any suggestions?
Capo Creative is offline Find More Posts by Capo Creative
Old Oct 12, 2012, 06:49 PM
c3d76 is offline
Joined Mar 2012
Hmm, I don't know, that is strange...
How many C are your lipos? 30, 20, 15? Maybe the discharge rate is too low??
In the mean time I guess you could lower the first warning slightly so you don't get annoyng flashes all the time. Second warning seems ok to me since you get 6+ minutes on one 5000mah pack...
Old Oct 12, 2012, 07:17 PM
Joined May 2012
40-50C discharge... The problem with lowering the first warning, it seems that the warning LED lights are coming on MUCH earlier than the set voltage... Would it really be going from 25 v to 22.8 in 2 minutes? Can't be... It just seems the first warning is coming to early... But i agree, the actually flight times seem right on track.
Old Oct 13, 2012, 01:22 AM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
I am using the WKM warning, but I rely on the Spectrum telemetry to see what is going on at a glance.
When I see that RED light it needs to come down quick..
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Oct 13, 2012, 01:42 AM
Joined Aug 2005
Originally Posted by UAVProducts View Post
Denny Denny Denny,
We do think a like.
Time to open up the UAVProducts.com Skunkworks.
This is our ZenHeliCam with the Zenmuse. We are using PH boom (frame mounts) and Paul made us a set of Boom to Z15 adapters.
This is based on the Henseleit TDR that we modify. We have 3 in stock. The platform is for the larger Zenmuse to come. The one in the video is only a 700mm but all the others are 800mm versions. By far the smoothest heli and the most Industrial high quality design heli we have ever used. The simplicity of the design and low parts count is amazing. The head as you mentioned is great at low head speeds. Our custom battery try can take 12s 5000mah (2 lipos) or 4 for long duration (10,000mah or more).
We abandoned the VarioCam we designed and now just offer the ZenHeliCam.
We will post more once we finish a few little things. The booms still need to be trimmed down and our electronics box slightly modified to handle the can bus from the Zenmuse. The funny thing is these don't cost that much more (and sometimes less) than Multi rotors.
They are special order.
http://www.youtube.com/watch?v=ef21fKriEVE&feature=plcp
Nice one
I'm still working on production molds for the carbon swinging arm mount adapter. Buggy shocks. But more or less the same layout as yours. The unit also supports the two 11 amp. maxamp batteries to add a little mass the assembly. Any idea when you might see the Zen big brother?
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
