Old Oct 10, 2012, 12:05 AM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
Guys all orders are sent, over a hundred now, but some may be finding a hold up in local customs.
It doesn't make sense to me that some have taken 4 days and some 2 weeks.... When I'm satisfied that any have gone AWOL I'll stand the loss and send out replacements.
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Oct 10, 2012, 12:31 AM
Joined Aug 2005
My own experiments have shown that the 14x4.7 APC's were the same duration as the S800 Carbon. The only slight loss was on the Graupners.which was offset by better stability than both. It is a tricky test to perform as any turbulence has quite an effect on the results. On the test rig the current drawn is pretty much the same for any given lift value. If duration is your goal then the more dia. you run the more efficient it will be, But at the expense of stability. If you want the best AP platform I would run a 14" prop.
Yesterdays big shoot was done in very windy conditions, The director said after seeing the footage that the last time he saw that level of raw footage it was from a AS350 Eurocopter fitted with a Cineflex.
Perfect stability and no vibration artifacts.
Old Oct 10, 2012, 01:33 AM
Capo Creative is offline
Find More Posts by Capo Creative
Joined May 2012
Thanks for the reply. I ordered mine 2 weeks ago so hopefully they will arrive soon. I'll keep checking the mail everyday and let you know if and when they do arrive!
Capo Creative is offline Find More Posts by Capo Creative
Old Oct 10, 2012, 03:58 AM
miza is offline
Find More Posts by miza
Joined Aug 2011
This weekend I was flying my S800+ z15 a lot. Over open waters and white waters. Didn't have any problem, some white flashes on 5.14, but altitude hold was quite ok.
At some points when flying near me, I noticed huge vibrations on the Z15. Not in the picture, but the whole mount shook like crazy. So today I will wrap arms into CF and adapters are on the way.
I hope to get solid frame. =)
*edit - When flying manual, can WKM flip if stick pushed to much? Like acro mode?
miza is offline Find More Posts by miza
Old Oct 10, 2012, 04:05 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
Yes, you can do flips in manual mode.
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Oct 10, 2012, 06:40 AM
jdm66 is offline
Find More Posts by jdm66
jdm66's Avatar
France, Pyrénées Orientales
Joined Feb 2009
Hi, dennyrowland@mac
not receive yet !
Grece and France are close !
jdm66
jdm66 is offline Find More Posts by jdm66
Old Oct 10, 2012, 09:52 AM
UAV.Pilot is offline
Find More Posts by UAV.Pilot
Joined Sep 2012
I flew mine yesterday all day, totaling 2.5 hours. I flew in all modes in aprox. 18 to 20kts wind, In Attitude mode it would circle counter clockwise. I tried increasing and decreasing the gain but couldn't really tell a difference, probably because of the high winds.
In manual mode it flies really aggressive and smooth, I am getting really good with it and cant wait to get some smooth weather.
I have one ECU still running hotter than the rest, but I will replace it as soon as I get a chance.
I can see a direct relation with flying in the wind and vibrations in the arms, resonating from the motors/props down the arm and through the gear legs. You can clearly see in low wind conditions it flies very smooth, but as soon as the wind gusts the props start flexing and the gear will start to shake.
I am getting 17 mins out of a 30c 8000 and putting back 6000, hovering in high winds, no payload, and a few high speed blasts up stairs.
Top speed so far is impressive in Manual, and pretty hard to get a handle on it, not recommended to the faint at heart.
I would like to get a set of Denny's adapters and give the apc's a try.
Still did not get a Battery tray, thinking I got screwed on this Kit, but will learn my lesson and never buy from the dealer again.
I have a few videos and will try to get them uploaded today...
UAV.Pilot is offline Find More Posts by UAV.Pilot
Old Oct 10, 2012, 10:30 AM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
Deny's prop adapters arrived just now. Very nice quality. Will try to get to them later this afternoon but very busy.
I have 8 sets left.
Darcy,
You need a battery tray? Email me.
UAVProducts is offline Find More Posts by UAVProducts
Old Oct 10, 2012, 11:15 AM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
Do you mean it circles counter clockwise in GPS mode?
If so, you just have to turn the GPS module clockwise to around 1 or 2 o'clock...
c3d76 is offline Find More Posts by c3d76
Old Oct 10, 2012, 11:17 AM
miza is offline
Joined Aug 2011
UAV.pilot, what is your total weight?
Old Oct 10, 2012, 11:23 AM
Joined Sep 2012
Ok I'll give it a try next. Thanks
Miza
I have not weighed it as of yet, but the only thing I am flying with is 1x 8000mah 6s battery zip tied to the bottom center. No payload yet.
Im downloading the short vid I just made, it looks like it will be uploaded in about an hour, so you will see how quick it is..
Old Oct 10, 2012, 12:07 PM
EndOfDays's Avatar
Joined Jan 2010
@UAV.Pilot
There are some small brackets below the motors (only on one side), which turn the motors to the side (just 1 or 2°) one of these brackets might be on the wrong side. But as you report one motor is getting hotter than the rest, it is also possible that this motor is defective (and therefore coming to its end).
best regards
Ferdinand
Old Oct 10, 2012, 12:18 PM
Joined Sep 2012
Originally Posted by EndOfDays View Post
@UAV.Pilot
best regards
Ferdinand
Good point Ferdinand, however I mistakenly said Motor, when I meant ECU, the ECU is whats Hotter than the rest, not the Motors.
The Shims under the Motors are in the correct places, I did check twice.
I will adjust the pcu/gps module and try again.
My video is almost uploaded...I have the second video ready to upload after this one is up...
Old Oct 10, 2012, 12:46 PM
Joined May 2012
Received my prop adaptors today, thanks Denny! Can't wait to get this bird in the air!
Joined Sep 2012
First flights Upstairs in Manual Mode...
S800 First flights upstairs in Manual Mode (2 min 17 sec)
Discussion My DJI Spreading Wings S800 just came in the mail and I think I'm in trouble jasper7821 Multirotor Talk 219 Oct 16, 2012 05:11 PM
New Product DJI Spreading Wings S-800 Hexa multi-rotor sidneyw Multirotor Talk 930 Jun 22, 2012 10:14 AM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
Discussion Dji Spreading Wings (S800) coming Huluhulu Multirotor Talk 7 Apr 27, 2012 03:11 AM
